732054_en-US
732054_en-US
732054_en-US
FXOS8700CQ High Pass Filter Table question
Table 64 in data sheet rev 8.0 for the FXOS8700CQ seems corrupted.  Two bits in the [sel] field should permit four selections.  The table appears to repeat the ODR values in its bottom half, with table entries several powers of two lower.  Do these rows represent the remaining two possibilities for the [sel] field values?  Could you provide a corrected table if so?
MPW
AccelerometersRe: FXOS8700CQ High Pass Filter Table question
Hi Mike,
You are right, thanks for pointing it out. We will correct it in the next revision of the datasheet.
Tomas
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-04-2026 11:00 AM
更新者:
