619743_en-US
619743_en-US
619743_en-US
We use the MPXV7025DP in our application, our question: The sensor is sealed, hermetic?
Raul
Re: We use the MPXV7025DP in our application, our question: The sensor is sealed, hermetic?
Hi Raul,
Leakage is an unspecified and therefore not guaranteed performance characteristic of our devices. However, NXP does perform a 100% leakage test on all ported devices after assembly, with a maximum allowable leakage rate (for these devices) of 0.133kPa/sec (with 100kPa applied by a no-added-volume test system). This maximum rate can be considered "worst case" (prior to any handling/processing by the customer which may induce package stresses which affect port-to-package sealing) and the typical production distribution for leakage rate is much better. That said however, our current process and equipment capabilities do not allow us to build and test to (or guarantee) a tighter requirement.
I hope you find this information useful.
Tomas
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-04-2026 03:51 AM
更新者:
