438828_en-US
438828_en-US
438828_en-US
Special receiver is needed for FXTH87?
I try to use CC1101 as the receiver for FXTH87, but failed. But I check the datagrame ,freq, datarate, it can be matched.
Why? the hardware not match?
Pressure SensorsRe: Special receiver is needed for FXTH87?
Hi Yaping Wang,
Is not that the FXTH87 needs a special receiver, is just that it look like the CC1101 is a transceiver, not a receiver.
Personally, I would recommend you to use the Freescale KW01 as the receiver for the FXTH87 instead.
The application note AN5136 is a guideline about how to set the KW01 as the receiver for the FXTH87. I would recommend you to take a look at this document.
Jose Reyes
No ratings
Version history
Last update:
‎02-04-2026 08:06 AM
Updated by:
