2425195_en-US
2425195_en-US
2425195_en-US
Unable to Open .mex File in S32DS 3.5.8 – "PlatformSDK_S32K3 version is not supported by the current
Hi Community,
I am facing an issue while opening a .mex configuration file for an S32K312, and S32K344 project.
Error Message:
Error during opening configuration .mex
Processor S32K344, the PlatformSDK_S32K3 version is not supported by the current version of the tool.
Development Environment:
  • S32 Design Studio (S32DS) 3.5.8
  • SW32K3_S32M27x_RTD_R21-11_4.0.0_P19_D2403
  • SW32K3_S32M27x_RTD_R21-11_4.0.0_D2311
Additional Observations:
  • The project previously opened successfully in the same development environment.
  • I have successfully developed and generated example code for peripherals such as CAN, I2C, DIO, and PIT using the same S32DS installation and RTD packages.
  • No intentional changes were made to the project configuration before this issue appeared.
  • The project builds/generated files are present, but the Configuration Tool cannot open the .mex file.
Request:
Could anyone please advise:
  1. What could cause a previously working .mex file to suddenly report that the PlatformSDK_S32K3 version is not supported?
  2. Is there a way to verify which SDK/RTD version the .mex expects?
  3. Could this be related to SDK registration, workspace metadata corruption, or an S32 Configuration Tool issue?
  4. Are there any recommended recovery steps for restoring access to the .mex configuration?
Thank you for your support.
Veer
Re: Unable to Open .mex File in S32DS 3.5.8 – "PlatformSDK_S32K3 version is not supported by th
Hi Robin,
Thank you for the suggestion.
I checked RTD/src/Clock_Ip.c and confirmed the build version is:
S32K3_RTD_4_0_0_P19_D2403
This matches the installed RTD package, and the corresponding S32DS version (3.5.8) also matches the RTD release note requirements.
Since the project was previously working in the same environment, could you please advise what else might cause the following error?
Are there any known issues related to Configuration Tool cache, SDK registration, or project metadata that could trigger this behavior?
Veer
Hi Veer,
Please check the Build Version of project/RTD/src/Clock_Ip.c. This will tell us which version of the S32K3 RTD is actually being used in the project.
Then check the release note for that version of the S32K3 RTD to verify whether the corresponding version of S32DS is correctly installed.
Robin
Resolved: PlatformSDK_S32K3 Version Not Supported When Opening .mex File
Hi Community,
Issue resolved after reinstalling S32DS and following the RTD installation procedure from the release documentation.
The .mex file now opens correctly and the Configuration Tool works as expected.
I would be interested to understand the specific condition that triggers this error (e.g., SDK registration, Configuration Tool cache, installation issue, workspace metadata, etc.), as it may help others facing the same problem.
Veer
タグ(1)
評価なし
バージョン履歴
最終更新日:
3 週間前
更新者:
