2420344_en-US
2420344_en-US
2420344_en-US
PortPinMode of mcal port module could not be select in EB tresos 30.0
I find EB tresos 30.0 is very different from 29.0. Everything go smoothly in 29.0, but has many problem on 30.0.
As for the configuration item "PortPin Mode" of port module, I could not see any option except GPIO.
Such as this one for UART TX pin, I could not modify it to UART TX option.
What's the reason for this? How to solve it?
Re: PortPinMode of mcal port module could not be select in EB tresos 30.0
Could any one give some advice?
Hi, Can you pls provide the Chip and RTD version you are using?
Besides, have you tried in legacy editor?:
1. Shutdown EB。
2. Edit defaultPreferences.properties in C:\EB\tresos_32_1_4\configuration
setLegacyEditorAsDefault: true
3. save, reopen EB and Module and try your configuration
タグ(1)
評価なし
バージョン履歴
最終更新日:
16 時間前
更新者:
