I’ve tried many times, but I still can’t get the license to install successfully. What could be causing this?
Invalid license file. Feature AUTOSAR_MCAL_S32K14X version 4.2 is required.
Hello @xiaomingchen,
In order to use the SW32K14-SMCL431-RTMC-1.0.1 package, a license.dat file is required. You can download the required licenses in the 'License Keys' tab, select the license to download (in your case, I can see you are using AUTOSAR 4.3 RTM 1.0.3 release for the S32K1XX platform / SW32K14-SMCL431-RTMC-1.0.1), scroll down and select 'View', then finally, 'Save All'.
This will generate a license.dat file for you to enter on the installation wizard:
However, this SW is not supported and maintained anymore. We recommend using latest RTD drivers instead: Real-Time Drivers (RTD) | NXP Semiconductors.
Julián
