2419091_en-US
2419091_en-US
2419091_en-US
Help Required: HSE Firmware Flashing on S32K312
Hi NXP Team,
I am currently working on HSE firmware on the S32K312. I have the HSE firmware BIN file, but I am unable to understand the correct procedure to flash it onto the S32K312.
I tried flashing the BIN using PEmicro, but it failed. I also tried using the IVT configuration in S32 Design Studio, but when I selected S32K312, it showed “No processor supported.”
I have already gone through the available examples and posts, but I am still stuck at the HSE firmware flashing step.
Could you please provide me with the correct and shortest procedure to flash the HSE BIN firmware on S32K312 and make HSE operational?
Please guide me specifically on how and where the BIN file needs to be flashed and what needs to be done after flashing.
(I have attached the Bin File in Zip File )so check it
@nxp
Thanks & Regards,
Sohel Jakati
Re: Help Required: HSE Firmware Flashing on S32K312
Hi @Mohmedsohel
Have you already checked the S32K344_HSE_FW_INSTALL demo provided in the S32K3 MCUs for General Purpose HSE Demo Examples?
Also, you mentioned that you tried using the IVT Tool from S32 Config Tools. However, this tool does not support S32K3 devices. For S32K3, the IVT can be modified directly in the S32DS project under Project_Settings → Startup_Code → startup_cm7.s
BR, VaneB
タグ(1)
評価なし
バージョン履歴
最終更新日:
18 時間前
更新者:
