2417029_en-US
2417029_en-US
2417029_en-US
GPIO218 emulator mode output error
The GPIO218 output level toggles correctly when running at full speed. However, after using Lauterbach's Attach connection, the port level goes low and stops toggling. How can I analyze this problem?
Re: GPIO218仿真器模式下输出异常
Hello @liyongfeng,
What do you mean by "can no longer flip"? When you go over the Siul2_Dio_Ip_WritePin() function, does GPDO218 not change to '1'? How are you testing this?
If you select 'Go' or disconnect the debugger, does the GPIO toggle?
I have made a simple test, and I can see GPDO switch when debugger is attached.
Julián
タグ(1)
評価なし
バージョン履歴
最終更新日:
昨日
更新者:
