2416252_en-US
2416252_en-US
2416252_en-US
Coupon not valid for FRDM-MCXN236
NXP website advertises this free board to get started. But the coupon code returns invalid when applying at checkout.
I feel NXP should honor current advertisements, or, take them offline.
Development BoardFRDM-TrainingRe: Coupon not valid for FRDM-MCXN236
Glad to hear that!
You can submit the request as a hobbyist. A
Does the button appear greyed out? If yes, could you please try logging in using an Incognito window in Chrome, a Private window in Firefox, or a different browser?
Sometimes browser cookies can prevent the login process from working correctly. Please also try clearing your browser cache and cookies, then attempt to log in again.
Let me know if the issue persists, and I'll be happy to help further.
Alondra
Thank you for the quick fix!
Coupon works now. However, the checkout stage has several form entries like company name, url etc. Since I am a inidividual and intend to use the board for self learning, I have marked NA for these fields.
Unfortunately the next button at end of the form does not respond.
Thank you for contacting us.
Could you please try again? We have updated the coupon, and you should now be able to use it successfully.
Please let me know if the issue persists, and I will be happy to assist further.
Alondra Olvera
  It's not working for me either, may I know if it's still available or is their any other coupon code for the same ?
Anukul Anand
I ran into a similar promo error on checkout when applying regional codes. Usually, promo vouchers like ADCWFBXT are restricted by geographical region or distributor inventory allocations. If you are ordering from certain regions—such as developers connected through fiwfans - asia (fiwfan. app) or other local tech hubs—the NXP direct cart often flags the voucher as invalid due to regional shipping rules.
The best solution is to open a direct support ticket with NXP Customer Care or contact your local regional distributor. They can either manually issue a regional promo code or release the order allocation for your account.
Now it's back to invalid coupon.
Greetings,
I tried all the steps you mentioned above, cleared the cookies and logged in through an incognito window on Chrome, yet it shows invalid coupon.
Would be glad to use this for my upcoming project so need some help with this coupon thing
标记 (1)
无评分
版本历史
最后更新:
昨天
更新人:
