2416054_en-US
2416054_en-US
2416054_en-US
Recommendation for NXP i.MX Processor for 1080p RTSP IP Camera
Hi everyone,
Could anyone suggest the lowest cost NXP i.MX processor that can handle a 1080p RTSP IP camera stream?
My requirements are:
    1 RTSP IP camera input
   2 1080p resolution
   3 Around 25–30 FPS
   4 Looking for the lowest-cost i.MX processor/board that can handle this reliably
The main goal is to receive and process/display a  1080p RTSP camera stream at the lowest possible hardware cost.
If anyone has tested a low-cost i.MX processor for a similar use case, please share your recommendation and experience.
Thanks!
Re: Recommendation for NXP i.MX Processor for 1080p RTSP IP Camera
For a pure receive/display application using an IP Camera, you can consider i.MX8MM since includes a dedicated hardware VPU capable of 1080p60 decode.
Best regards.
タグ(1)
評価なし
バージョン履歴
最終更新日:
1週間前
更新者:
