I configured the FRDM-KL25Z board according to KTFRDMPT2001EVMUG.pdf and connected it to my PC with a cable. The blue LED on the FRDM-KL25Z board turns on. After loading the *.spi file in SPIGen on the host PC, I can download normally and read/write registers. However, the DRVEN and RESETB pins remain in their default state. I cannot use the buttons in the SPIGen panel/GUI to drive the corresponding pins on the board high or low.
How should I solve this issue? Thank you for your reply!
Hi Lex (@LexLiu),
Could you please help with this question regarding the problem with driving both the DRVEN and RESETB pins on FRDMPT2001EVM using SPIGen SW?
Thanks!
BRs, Tomas
