2415133_en-US
2415133_en-US
2415133_en-US
Re: i.MX RT1064 - PEmicro Connection Assistant Error
This is a follow up to a previously raised query. The link has been attached to the previous query, and the link has the required details which was requested. Kindly reply and help us address the issue at the earliest.
Thanks and Regards
Subhasri
https://community.nxp.com/t5/i-MX-RT-Crossover-MCUs/i-MX-RT1064-PEmicro-Connection-Assistant-Error-a...
i.MXRT 106xRe: i.MX RT1064 - PEmicro Connection Assistant Error
Hi @Subhasri_S,
On the measurements you shared, are the pull-up voltages powered before POR_B is released?
In your application, is there any point at which the MCU enters a low-power state?
Does any fault or error occur before the issue appears?
Pablo
Hi @Pablo_Ramos , thank you for your response.
The pull-up voltages are not powered before POR_B is released. Signals of the pull -up wrt. POR_B behavior is attached below.
There is no point in our application where MCU Enters low power mode.
Also, no fault or error occurs before this issue.
I would also like to know whether there is any way to recover the board through software when this issue occurs.
Thanks and Regards
Subhasri
No ratings
Version history
Last update:
Saturday
Updated by:
