Hello Team,
In my project, i am trying to do arithmetic operation using float data, but calculation is not happening as expected.
#define macro -31.374
when i try to print in macro value using UTILS PRINTF, i am getting -32.374, similarly for other values, value get incremented by 1.
Because of this, my calculations not happening as expected.
Is there any cfg i need to do for this?
My current target setting
Could you please clarify what you mean by "UTILS PRINTF"?
How are you performing the calculations? Are the results stored in a float variable? If yes, does the variable already contain the wrong value when viewed in the debugger, or is the issue only observed when printing it?
BR, VaneB
Hello @VaneB ,
Thank you for your support, yes issue was in PRINTF function, while debugging i was able to read the proper data.
