2414759_en-US
2414759_en-US
2414759_en-US
i.MX6ULL ethernet disconnect when joint temperature is higher than 95℃
Hi NXP,
       We has designed our production with i.mx6ull 08AB version, and found a question shown below.
       1>Part No.: MCIMX6Y2CVM08AB
       2>Question:
            When the joint temperature is higher than 95℃, some boards will occur the ethernet disconnection issue.
        Do you have some tips for us to fix this problem ?
        Thanks very much.
i.MX6ULRe: i.MX6ULL ethernet disconnect when joint temperature is higher than 95℃
how many boards do your customer find this issue? any what bsp version did they test?
No ratings
Version history
Last update:
Tuesday
Updated by:
