2414383_en-US
2414383_en-US
2414383_en-US
Suitable SBC for S32K3 with 24V supply
Which SBC is the most suitable for supplying an S32k3 in a 24 V environment?
I have been researching the FS264x family, but I found some sources stating that the FS26 should not be exposed to voltages above 24 V for extended periods. Would it be more appropriate to design the system using the FS8500 instead?
FS85&FS84Re: Suitable SBC for S32K3 with 24V supply
Hello DavidSilva
Good day!
You're right, the FS26 is one of the best options available due to everything it has integrated, but if you plan to use it for extended periods, the FS85 and FS86 are better choices, as they can handle 24V without any issues.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
No ratings
Version history
Last update:
Friday
Updated by:
