I am designing a board with i.MX93 (MIMX9332CVVXMAC) that has to drive a RGB display with parallel interface. From config tool the data bit are lebelled data0-23 without reference to R,G,B channel. I have also looked at evb FRDM and TM050RDH03-41, unfortunately on FRDM the data are as in config tool and the schematic of TM050RDH03-41 is not provided.
Is it possible to have such schematic for confirmig the pinout?
Or can you confirm me that the 24 bits can be muxed between channels R G and B freely?
Thank you,
Enrico
Thank you for your interest in NXP Semiconductor products,
Please see the TM050RDH03-41 display connector schematic, if you are interested in the full schematic, please create a technical case.
