2412199_en-US
2412199_en-US
2412199_en-US
S32K312 SM implementation
‘DCF_CLIENT_TVF' This SM describes TVF in case of discrepancies, the client reports errors to DCM, but I did not see the corresponding fault in DCM.
F
Re: S32K312 SM implementation
The statement "client reports errors to DCM" does not imply a dedicated FCCU/DCM fault-map entry. According to the Safety Manual, DCF client TVF/parity discrepancies are reported to the Device Configuration Module through the DCMEC (DCF Error Count) and DCMSRRx (DCF Scan Report) registers.
Therefore, the expected diagnostic visibility appears to be through DCMEC/DCMSRRx rather than through the FCCU fault map.
petervlna_0-1788935708237.pngpetervlna_0-1788935708237.pngpetervlna_0-1788935708237.png
Peter
タグ(1)
評価なし
バージョン履歴
最終更新日:
13 時間前
更新者:
