2412025_en-US
2412025_en-US
2412025_en-US
88W8887 RF compliance testing
Dear,
We are using a wifi/bluetooth module based on the 88W8887 chipset. For product compliance, we need to do a number of RF testing (tx continious packets, rx mode etc.). For another module 88W8997, we have followed the following application node: AN14114. However, the application note does not mention the 88W8887 as supported.
The application notes uses mwifiex driver. Looking at the code, the 88W8887 should be supported by the driver. Unfortunately, the driver requires a firmware file sd8887_wlan_a2.bin which we were not able to find.
What is the recommended way to run RF tests (similar as described in the AN) on the 88W8887? Does NXP still support this usecase?
Kind regards,
Yoshi
Re: 88W8887 RF compliance testing
Hi @shaun_wu
I do not have access to the provided link. Anything I need to do on my side to get access?
Kind regards,
Yoshi
Hello @YoshiDev
8887 do not support rf_test_mode. you could use mfg_mode. You could refer to following link: https://www.nxp.com/webapp/Download?colCode=88W8887-LABTOOL-USER-GUIDER0_1&appType=license
Best Regards
Shaun
Hello @YoshiDev
The document is confidential. You could submit a ticket to NDA team get access.
Best Regards
Shaun
No ratings
Version history
Last update:
3 weeks ago
Updated by:
