2411359_en-US
2411359_en-US
2411359_en-US
GoPoint, fail to download models in Multistream yolo launcher, nxp/YOLOv8 missing
I have the FRDM i.MX95 + ARA240 M2 16G GT
And installed the image version LF_v6.18.20-2.0.0_images_IMX95EVK
imx-boot-imx95-15x15-lpddr4x-frdm-sd.bin-flash_all
imx-image-full-imx95evk.wic
When starting the gopoint application and trying to download the models in Multistream YOLO configuration following exception is caught:
Downloading nxp/YOLOv8 to /usr/share/cnn/...
Error downloading model: 404 Client Error. (Request ID: Root=1-6a9ab518-05ebf76418b2dfcc0855cb40;a0fa833c-b8ba-4d7f-8595-0e157e194afd)
Repository Not Found for url: https://huggingface.co/api/models/nxp/YOLOv8/revision/r2.0.4.
Please make sure you specified the correct `repo_id` and `repo_type`.
If you are trying to access a private or gated repo, make sure you are authenticated and your token has the required permissions.
For more details, see https://huggingface.co/docs/huggingface_hub/authentication
Sample videos are downloaded correctly.
Any ideas what to do now?
Re: GoPoint, fail to download models in Multistream yolo launcher, nxp/YOLOv8 missing
Hello, A model repository/version issue rather than a problem with the image or sample videos. The application is trying to download nxp/YOLOv8 at revision r2.0.4, but Hugging Face is returning 404, so I’d first verify that this repository/revision actually exists and that the GoPoint app version matches the installed LF_v6.18.20 image.
タグ(1)
評価なし
バージョン履歴
最終更新日:
3 週間前
更新者:
