2410771_en-US
2410771_en-US
2410771_en-US
MIFARE Plus EV1 (SL3) Wrong Sector Trailer access byte, Plain Communication broken
Hi everyone,
I'm working with a Mifare Plus EV1 card in SL3. While configuring the sector trailer access bytes, I accidentally set an incorrect value, and now plain communication no longer works for that sector.
If the access bit pattern (C1/C2/C3) itself is still valid and only Byte 5 (PlainAC) is misconfigured, is re-authenticating and rewriting Byte 5 enough to fix plain communication? Or does a plain-communication failure alone also risk triggering the format-violation lock?
Has anyone dealt with this before — any workaround, or is treating the sector as permanently unusable the only realistic option?
Thanks in advance for any insight.
#MIFARE_PLUS_EV1   #  MIFARE PLUS EV2MIFARE_PLUS_SE_1K
MIFARE
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎09-04-2026 04:31 AM
更新者:
