Hi Team,
Could you please help to check and confirm that below mentioned 15W receiver kit is EMI/EMC compliant.
P/N: WPR1500-HV
Description - High Voltage Wireless Charging Receiver
Parth Bhavsar
Hello @P907 ,
Thanks for your post. This EVK is mainly for evaluation and pass basic EMI/EMC test to be CE compliance. In general there aren't any major different between our solution and general solution on market.
Hope it helps.
Celeste
Hi Celeste,
Thank you for the reply.
Could you please help us to share the test report and its results. So, from that we will check which are the basic EMI/EMC test is performed on this EVK.
Parth Bhavsar
Hello @P907 ,
Of course, I can share them with you. However, these materials are not suitable for sharing on public platforms such as the Community. I will send them to you via private email shortly. Please keep an eye on your inbox.
Celeste
Hi Celeste,
Thank you for sharing EMI/EMC test report for the requested EVM.
Parth Bhavsar
