2409462_en-US
2409462_en-US
2409462_en-US
Question About SD2_VSEL and SD2_RST_B Connections on i.MX95 19x19 EVK
Dear NXP Support Team,
While reviewing the i.MX95 19x19 CPU EVK board schematic, I noticed that the SD2_VSEL and SD2_RST_B signals are connected to the FP09 GPIO1 and GPIO2 pins.
Could you please explain the purpose of these connections in more detail?
In particular, I would like to understand why these two signals are connected to the GPIO pins and how they are intended to be controlled or used in the system.
Walter
Re: Question About SD2_VSEL and SD2_RST_B Connections on i.MX95 19x19 EVK
The intent is to let the i.MX95 uSDHC2 block control the SD-card power rails through the PF09 PMIC, rather than treating those nets as ordinary board GPIOs.
  • SD2_VSEL → PF09 GPIO1 : this is for SD/SDIO voltage switching. The i.MX95 uSDHC VSELECT output is defined as a signal used to change the external power-supply voltage, and the controller supports voltage selection through VEND_SPEC[VSELECT] . In PF09, GPIO1 can be configured as a dedicated VSELECT input ; when enabled, GPIO1 selects LDO2 = 3.3 V when low and LDO2 = 1.8 V when high . This matches the SD3.0 requirement that the platform implement both 3.3 V and 1.8 V signaling.
  • SD2_RST_B → PF09 GPIO2 : this is for card power/reset control. The i.MX95 RESET_B signal is described as optional, active-low, and for a removable card it can be used “instead of hardware reset to enable/disable Card power during warm reset.” PF09 GPIO2 can be configured as an LDO1EN input , where the pin enables or disables the LDO1 output by hardware. So the EVK connection gives the uSDHC2 reset/power-control signal a direct path to the PMIC-controlled SD-card supply.
In practical terms, these PF09 pins are not being used as random expansion GPIOs on the EVK. They are multi-function PMIC pins wired so the SD host controller can request the correct SD-card rail behavior:
Signal
PF09 pin role
System purpose
SD2_VSEL
PF09 GPIO1 in VSELECT mode
Switch NVCC_SD2 /SD I/O supply between 3.3 V and 1.8 V for SD3.0 operation.
SD2_RST_B
PF09 GPIO2 in LDO1EN mode or equivalent card-power control role
Enable/disable SD-card power, especially around reset/warm-reset behavior.
So the control path is typically: uSDHC2 driver/U-Boot configures the SD host controller → uSDHC2 drives SD2_VSEL and/or SD2_RST_B → PF09 interprets those pins according to its OTP/configuration → PF09 changes the SD-related LDO state . PF09’s GPIO modes/default behavior are OTP-configurable, and its GPIO outputs can also be controlled in system-on states when configured as GPOs, but the EVK wiring is intended to use the PMIC’s dedicated SD power-management functions rather than manual bit-banging.
Bottom line: SD2_VSEL and SD2_RST_B are routed to PF09 GPIO1/GPIO2 so the i.MX95 uSDHC2 interface can perform SD-card voltage switching and card power/reset control through the PMIC.
Yes. Those connections are intentional SD2_VSEL and SD2_RST_B are used to let the i.MX95 USDHC2 interface control the SD-card power/reset behavior through the PF09 PMIC, rather than being ordinary GPIO signals.
SD2_VSEL → PF09 GPIO1: controls the SD-card I/O voltage switching, typically between 3.3 V and 1.8 V for SD 3.0 operation.
SD2_RST_B → PF09 GPIO2: provides SD-card power/reset control, particularly useful during reset or power-cycle sequences.
So the intended path is essentially:
i.MX95 USDHC2 → SD2_VSEL / SD2_RST_B → PF09 → SD-card power rails
The Linux device tree also shows SD2_VSELECT being used by USDHC2 and SD2_RESET_B being used for SD-card power control, which confirms these are part of the normal SD-card design rather than spare GPIOs.
タグ(1)
評価なし
バージョン履歴
最終更新日:
3 週間前
更新者:
