Hello NXP Community,
I am working with an i.MX8M Plus EVK running an NXP Debian Linux image built using FlexBuild/LSDK.
My board uses the following Wi-Fi module:
I am unable to bring up and connect the Wi-Fi interface on the Debian image.
I tried checking the available network interfaces, but I am not able to successfully turn on the Wi-Fi.
Could you please provide the correct steps to enable and connect Wi-Fi for the AzureWave AW-CM276NF (88W8997) module on the i.MX8M Plus Debian/FlexBuild image?
I would like to know:
modprobe moal mod_para=nxp/wifi_mod_para.confPlease let me know the recommended step-by-step procedure to bring up Wi-Fi and connect to an access point.
Thank you.
refer to the release note, current bsp supports the NXP SDIO 88W8997 (tested with Murata LBEE5XV1YM) on i.MX 8MPlus. for how to enable WI-FI in debain, pls refer to the 3.4.6 Enabling the Wi-Fi module on the i.MX platform of enclosed file
