I am trying to implement a UWB TDoA system using the following configuration:
The SR250 anchors need to receive blink messages transmitted periodically by the SR040 tag. The master and slave anchors will then use the received timestamps to calculate the tag position using TDoA.
I would like to confirm the following:
Currently, I have an SR250 TDoA anchor application running on a QN9090 host. However, I could not find clear documentation or an example showing how to configure the SR040 as a compatible TDoA tag.
Any information regarding the required firmware, session configuration, blink frame format, and timestamp synchronization would be greatly appreciated.
Best regards.
