Would it be possible to get the design files for the FRMD-i.MX95 exported to Altium Designer format?
https://www.nxp.com/webapp/Download?colCode=FRDM-IMX95-DESIGNFILES&location=null
Works fine for me too.
Many Thanks!
See attached Allegro ascii-format for the FRDM-IMX95.
The original design is made in 16.6, so there was some fiddling to get it converted. Imports to Altium just fine on my end. Hope this helps!
Correct, but you need a Cadence license for that import to work. Unless the imported files are in Allegro ascii-format (which they are not)
Hello, You may need to convert the provided CAD files into Altium format, depending on what source format NXP included
Altium can import the OrCad / Allegro formats. I have done it several times. Check out the docs here: https://www.altium.com/documentation/altium-designer/design-tools-interfacing/allegro-import
