2406028_en-US
2406028_en-US
2406028_en-US
How to switch OD/ND/LD mode of i.MX 95
Background: The i.MX95 introduces a system manager firmware, which is responsible for power, clock, resource isolation, security management, and system-level control between kernels, essentially acting as the "backend manager" for the entire SoC. Switching between different driver modes is necessary to change the VDD_SOC voltage of the i.MX 95. But, Unlike the i.MX 93, the i.MX 95 does not support DVFS and the i.MX 95 has only one fixed DDR frequency point., it is not possible to switch between OD, ND, and LD modes under userspace.
This article will explain how to switch from OD to ND mode.
1. Test environment
HW: i.MX95 EVK board
SW: imx-oei, imx-sm
2. Voltage and frequency of i.MX 95 series processors in different modes
The voltage VDD_SOC varies in different modes.
pengyong_zhang_2-1787043053405.pngpengyong_zhang_2-1787043053405.pngpengyong_zhang_2-1787043053405.pngMaximum frequency of i.MX 95 series processor modules in different modes.
pengyong_zhang_1-1787043037623.pngpengyong_zhang_1-1787043037623.pngpengyong_zhang_1-1787043037623.png
3. Code change(Switching to ND mode as an example)
3.1. imx-sm
https://github.com/nxp-imx/imx-sm/blob/master/boards/mcimx95evk/sm/brd_sm.c#L107
index 077fa06..023a580 100755
--- a/boards/mcimx95evk/sm/brd_sm.c
+++ b/boards/mcimx95evk/sm/brd_sm.c
@@ -104,7 +104,7 @@
     BRD_SM_REC_VLD_MASK)
 /* Performance parameters */
-#define BOARD_PERF_LEVEL  DEV_SM_PERF_LVL_ODV  /* Target perf level */
+#define BOARD_PERF_LEVEL  DEV_SM_PERF_LVL_NOM  /* Target perf level */
 #if BOARD_VOLT_SOC >= ES_ODV_UV_VDD_SOC
 #define BOARD_BOOT_LEVEL  DEV_SM_PERF_LVL_ODV  /* Boot perf overdrive */
 #elif BOARD_VOLT_SOC >= ES_NOM_UV_VDD_SOC
diff --git a/configs/mx95evk.cfg b/configs/mx95evk.cfg
index 8ac5392..5f19d42 100755
--- a/configs/mx95evk.cfg
+++ b/configs/mx95evk.cfg
@@ -459,7 +459,7 @@ PD_A55C2            stop=5
 PD_A55C3            stop=4
 PD_A55C4            stop=3
 PD_A55C5            stop=2
-PERF_A55            start=3|3
+PERF_A55            start=3|2
 CPU_A55C0           start=4
 CPU_A55P            stop=1
@@ -473,7 +473,7 @@ PD_A55C2            msel=1, stop=5
 PD_A55C3            msel=1, stop=4
 PD_A55C4            msel=1, stop=3
 PD_A55C5            msel=1, stop=2
-PERF_A55            msel=1, start=3|3
+PERF_A55            msel=1, start=3|2
 CPU_A55C0           msel=1, start=4
 CPU_A55P            msel=1, stop=1
@@ -487,7 +487,7 @@ PD_A55C2            msel=2, stop=5
 PD_A55C3            msel=2, stop=4
 PD_A55C4            msel=2, stop=3
 PD_A55C5            msel=2, stop=2
-PERF_A55            msel=2, start=3|3
+PERF_A55            msel=2, start=3|2
 CPU_A55C0           msel=2, start=4
 CPU_A55P            msel=2, stop=1
diff --git a/configs/mx95evk/config_lmm.h b/configs/mx95evk/config_lmm.h
index 3e3f508..999a4a1 100755
--- a/configs/mx95evk/config_lmm.h
+++ b/configs/mx95evk/config_lmm.h
@@ -152,11 +152,11 @@
     {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_PD, .rsrc=DEV_SM_PD_A55P}, \
     {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_PD, .rsrc=DEV_SM_PD_A55P}, \
     {.lmId = 2U, .mSel = 0U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \
-     .numArg = 1, .arg[0] = 3U, }, \
+     .numArg = 1, .arg[0] = 2U, }, \
     {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \
     {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_PERF, .rsrc=DEV_SM_PERF_A55, \
     {.lmId = 2U, .mSel = 0U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0}, \
     {.lmId = 2U, .mSel = 1U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0}, \
     {.lmId = 2U, .mSel = 2U, .ss = LMM_SS_CPU, .rsrc=DEV_SM_CPU_A55C0},
3.2. imx-oei
Add the timing.c file for different DRAM frequencies under different modes to the following file, and then recompile imx-oei:
https://github.com/nxp-imx/imx-oei/tree/master/boards/mx952lp5-19/ddr
pengyong_zhang_1-1787035595967.pngpengyong_zhang_1-1787035595967.pngpengyong_zhang_1-1787035595967.png
4. Boot log: The boot log shows that the CPU frequency had dropped to 1404MHz at this point.
pengyong_zhang_3-1787035619561.pngpengyong_zhang_3-1787035619561.pngpengyong_zhang_3-1787035619561.png
Note: Ensure that you are using the DRAM timing.c file corresponding to the specified mode and that the compilation is error-free. To guarantee a complete error-free compilation, it is recommended to create a new timing.c file in the directory corresponding to imx-oei, complete the configuration in the Makefile, and then compile. Do not completely overwrite the contents of the current timing.c file.
For instructions on how to use Config Tool and how to update the timing.c file, please refer to the Config Tool User Guide.
IMX95EVK
タグ(1)
評価なし
バージョン履歴
最終更新日:
1週間前
更新者:
