2405980_en-US
2405980_en-US
2405980_en-US
Impact of i.MX6ULL REFTOP_VBGADJ on Internal PLL and Clock Output
Hi all, / Dear Community,
We are using i.MX6ULL in our product and would like to clarify the behavior of REFTOP_VBGADJ.
Issue & Solution:
We previously experienced a USB device recognition failure on our board. Changing REFTOP_VBGADJ on CCM_ANALOG_MISC0n register from the default value (0b000) to 0b110 successfully resolved the issue.
Question:
Our customer asked whether modifying REFTOP_VBGADJ has any side effects on the i.MX6ULL's internal PLL or clock output.
Could someone please clarify whether this setting affects the PLL/clock circuitry? If it does, what specific impacts or changes in analog behavior should we expect?
Any insights or documentation references would be greatly appreciated.
Thanks in advance,
Re: Impact of i.MX6ULL REFTOP_VBGADJ on Internal PLL and Clock Output
Hi @Ichitaro_K
On the i.MX6ULL, the LDO 1.2V bandgap voltage is 30 mV higher. Therefore, the REFTOP_VBGADJ (CCM_ANALOG_MISC0n register) bit needs to be set to 2b'110 for adjustment. And It has no impact on PLL.
B.R
タグ(1)
評価なし
バージョン履歴
最終更新日:
水曜日
更新者:
