1. S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Template\S32K344_DemoAppTemplate\drivers\dcm_register\hse_dcm_register.c
2. AN13465_S32K3xx Secure Boot.pdf
The description of the "Active Region" is inconsistent between the documentation and the code. Who is correct?
It appears that Dcm_ActiveAddressOTARegion() has reversed the mapping from DCMOTAR=0/1 to the low/high value.
We've discussed DCMSTAT[DCMOTAR] before: https://community.nxp.com/t5/S32K/s32k312/td-p/1697583
Robin
