Hello, I want to replace the S32K314 with the S32K348, but the hardware circuit remains the same. What software changes are required? Can I directly replace the chip in my existing project, or is there a simpler method? Thank you.
OK, thanks
Hi@ Joker_Y
The S32K314 and S32K348 are pin-incompatible in hardware, so it's unrealistic to say that the hardware will remain unchanged.
Secondly, the chip cannot be directly modified or replaced in the software; you need to create an S32K348 project from scratch.
