2405094_en-US
2405094_en-US
2405094_en-US
An error occurred when importing the Zephyr SDK into VS Code.
Hi NXP,
As shown in the image, importing the Zephyr SDK keeps failing. What could be the reason, and how can I troubleshoot it?
I also tested opening the magic, and the result was the same.
MCXARe: VS Code 导入Zephyr SDK出现error
Hi @hayden178
I just tested it on my MCUXpresso for VS Code.
I was able to import it successfully, which means there's nothing wrong with the GitHub repository.
Based on your log
remote: Enumerating objects: 3105, done.
remote: Counting objects: 100% (1405/1405)
remote: Compressing objects: 100% (433/433)
error: RPC failed; curl 56 Recv failure: Connection was reset
I think it's most likely a network connection problem.
You can try running `west update` in your `nxp\frdm_mcxa156` folder to manually update the repository.
Harry
No ratings
Version history
Last update:
‎08-15-2026 03:31 AM
Updated by:
