2403501_zh-CN
2403501_zh-CN
2403501_zh-CN
IMX8MP自主设计板在系统启动后崩溃
大家好,
我们设计了一款定制电路板,采用 i.MX8M Plus (IMX8MP) CPU、 4GB LPDDR4 RAM128GB eMMC存储。
以下是我们的启动日志。如您所见,启动 Linux 后,我们可以短暂地在控制台中输入命令,但系统几乎立即冻结并完全无响应。
我们怀疑这个问题可能是由日志中显示的 EXT4-fs 错误引起的。
有没有人遇到过类似的问题?或者能否给我们一些排查此问题的建议?非常感谢您的帮助!
先行致谢。
U-Boot SPL 2020.04 (Aug 10 2026 - 12:59:20 +0800)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3200MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC2
Authentication key not yet programmed
keyslot package magic error, do nothing here!
NOTICE:  BL31: v2.2(release):fc5b00e8fa-dirty
NOTICE:  BL31: Built : 12:59:31, Aug 10 2026
welcome to lk/MP
boot args 0x2000000 0x56000000 0x2000 0x0
initializing trusty (Built: 12:16:06 Nov 19 2020)
Initializing Trusted OS SMC handler
avb: Initializing AVB App
hwcrypto: Initializing
hwrng_caam: Init HWRNG service provider
hwrng_srv: Start HWRNG service
hwcrypto_caam: Init HWCRYPTO service provider
hwcrypto_srv: Start HWCRYPTO service
hwkey_caam: Init HWKEY service provider
hwkey_caam: 183: Invalid magic, unpack key package fail.
hwkey_srv: Start HWKEY service
hwcrypto: enter main event loop
trusty_gatekeeper: Initializing
U-Boot 2020.04 (Aug 10 2026 - 12:59:20 +0800)
CPU:   i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
Model: NXP i.MX8MPlus abcd LPDDR4 EVK board
DRAM:  4 GiB
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port2 init failed, err=-19
setup_typec: tcpc port1 init failed, err=-19
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... *** Warning - bad CRC, using default environment
[*]-Video Link 0Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
fail to get display timings
probe video device failed, ret -19
        [0] lcd-controller@32e80000, video
        [1] mipi_dsi@32e60000, video_bridge
        [2] adv7535@3d, panel
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - ATF
  - U-Boot 2020.04
flash target is MMC:2
Net:
Error: ethernet@30bf0000 address not set.
No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
ss: get_rpmb_auth_key: failed to get key: -2
ss: proxy_connect: can't get storage auth key: (-2)
ss-ipc: 105: do_connect: failure initializing channel state (1001)
rpmb_proxy.c:312: ERROR rpmb_storage_proxy_init: unexpected proxy channel close
libtipc.c:92: ERROR Initlializing RPMB storage proxy service failed (-8)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot:  0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:900: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
avb_slot_verify.c:482: ERROR: dtbo_a: Hash of data does not match digest in descriptor.
Writing A/B metadata to disk.
 verify FAIL, state: UNLOCK
 boot 'boot_a' still
kernel   @ 40480000 (36925952)
ramdisk  @ 44680000 (7268024)
fdt      @ 44480000 (65027)
Device is unlocked, press power key to skip warning logo...
no video device found!
can't show unlock warning.
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
ipc_dev.c:306: ERROR trusty_ipc_dev_close: secure OS returned (-7)
## Flattened Device Tree blob at 44480000
   Booting using the fdt blob at 0x44480000
   Using Device Tree in place at 0000000044480000, end 0000000044492e02
Found /vpu_g1@38300000 node
Modify /vpu_g1@38300000:status disabled
Found /vpu_g2@38310000 node
Modify /vpu_g2@38310000:status disabled
Found /vpu_vc8000e@38320000 node
Modify /vpu_vc8000e@38320000:status disabled
Found /vipsi@38500000 node
Modify /vipsi@38500000:status disabled
Found /soc@0/bus@32c00000/camera/isp@32e10000 node
Modify /soc@0/bus@32c00000/camera/isp@32e10000:status disabled
Found /soc@0/bus@32c00000/camera/isp@32e20000 node
Modify /soc@0/bus@32c00000/camera/isp@32e20000:status disabled
Found /dsp@3b6e8000 node
Modify /dsp@3b6e8000:status disabled
Starting kernel ...
unable to select a mode
device_remove: Device '[email protected]' failed to remove, but children are gone
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.70 (forenex@forenex20) (Android (5271481 based on r349610) clang version 8.0.8 (https://android.googlesource.com/toolchain/clang 4dba9ad555eabb40b39dc53c12d09423e9faea7b) (https://android.googlesource.com/toolchain/llvm ab552995647d484a712bf15f77e6c6f4e8ac532b) (based on LLVM 8.0.8svn), GNU ld (binutils-2.27-44492f8e) 2.27.0.20170315) #96 SMP PREEMPT Mon Aug 10 12:43:56 CST 2026
[    0.000000] Machine model: NXP i.MX8MPlus EVK board
[    0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[    0.000000] printk: bootconsole [ec_imx6q0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[    0.000000] cma: Reserved 800 MiB at 0x0000000060000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000017fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x17f7cc500-0x17f7cdfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000557fffff]
[    0.000000]   node   0: [mem 0x0000000058000000-0x00000000923fffff]
[    0.000000]   node   0: [mem 0x0000000094410000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000017fffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 32 pages/cpu s93400 r8192 d29480 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1014032
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboot.hardware=freescale firmware_class.path=/vendor/firmware loop.max_part=7 transparent_hugepage=never androidboot.lcd_density=240 androidboot.primary_display=imx-drm androidboot.wificountrycode=CN androidboot.selinux=permissive cma=800M@0x400M-0xb80M buildvariant=userdebug androidboot.serialno=0926980055347a54 androidboot.btmacaddr=09:26:98:00:55:34 androidboot.soc_type=imx8mp androidboot.boot_device_root=mmcblk2 androidboot.boottime=1BLL:0,1BLE:4332,KL:0,KD:0,AVB:671,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=orange androidboot.flash.locked=0 androidboot.slot_suffix=_a androidboot.vbmeta.device=PARTUUID=a670210c-8754-426c-a5b2-440a72068e31 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3456 androidboot.vbmeta.digest=6f86b17aea6
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0xbc000000-0xc0000000] (64MB)
[    0.000000] Memory: 3110948K/4120512K available (19388K kernel code, 1884K rwdata, 10296K rodata, 4416K init, 589K bss, 190364K reserved, 819200K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 160 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] random: get_random_bytes called from start_kernel+0x1e0/0x3a4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[    0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[    0.008586] Console: colour dummy device 80x25
[    0.012580] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.022843] pid_max: default: 32768 minimum: 301
[    0.027543] LSM: Security Framework initializing
[    0.032144] SELinux:  Initializing.
[    0.035679] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043064] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.052153] ASID allocator initialised with 32768 entries
[    0.056453] rcu: Hierarchical SRCU implementation.
[    0.062588] EFI services will not be available.
[    0.065940] smp: Bringing up secondary CPUs ...
[    0.070740] Detected VIPT I-cache on CPU1
[    0.070762] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.070788] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.071277] Detected VIPT I-cache on CPU2
[    0.071293] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.071308] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.071758] Detected VIPT I-cache on CPU3
[    0.071772] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.071787] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.071847] smp: Brought up 1 node, 4 CPUs
[    0.126892] SMP: Total of 4 processors activated.
[    0.131607] CPU features: detected: 32-bit EL0 Support
[    0.136784] CPU features: detected: CRC32 instructions
[    0.141964] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.150345] CPU: All CPU(s) started at EL2
[    0.154458] alternatives: patching kernel code
[    0.160090] CPU3: update max cpu_capacity 1024
[    0.161162] devtmpfs: initialized
[    0.171950] CPU3: update max cpu_capacity 1024
[    0.177065] Initilizing CustomIPI irq domain
[    0.181854] Registered cp15_barrier emulation handler
[    0.186900] Registered setend emulation handler
[    0.191752] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.201261] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.230348] pinctrl core: initialized pinctrl subsystem
[    0.233519] DMI not present or invalid.
[    0.236972] NET: Registered protocol family 16
[    0.241723] schedtune: configured to support 5 boost groups
[    0.253931] DMA: preallocated 256 KiB pool for atomic allocations
[    0.257232] audit: initializing netlink subsys (disabled)
[    0.262846] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.270434] cpuidle: using governor menu
[    0.275031] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.282334] Serial: AMBA PL011 UART driver
[    0.285353] imx mu driver is registered.
[    0.289231] imx rpmsg driver is registered.
[    0.330534] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.355197] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.359088] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.365812] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.372548] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.380290] cryptd: max_cpu_qlen set to 1000
[    0.386907] ACPI: Interpreter disabled.
[    0.389749] iommu: Default domain type: Translated
[    0.392979] vgaarb: loaded
[    0.395797] SCSI subsystem initialized
[    0.399630] usbcore: registered new interface driver usbfs
[    0.404821] usbcore: registered new interface driver hub
[    0.410185] usbcore: registered new device driver usb
[    0.416258] mc: Linux media interface: v0.10
[    0.419511] videodev: Linux video capture interface: v2.00
[    0.425062] pps_core: LinuxPPS API ver. 1 registered
[    0.429985] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[    0.439183] PTP clock support registered
[    0.443476] trusty trusty: trusty version: Built: 12:16:06 Nov 19 2020
[    0.449684] trusty trusty: selected api version: 3 (requested 3)
[    0.462140] EDAC MC: Ver: 3.0.0
[    0.463513] FPGA manager framework
[    0.465936] Advanced Linux Sound Architecture Driver Initialized.
[    0.472339] Bluetooth: Core ver 2.22
[    0.475559] NET: Registered protocol family 31
[    0.480018] Bluetooth: HCI device and connection manager initialized
[    0.486408] Bluetooth: HCI socket layer initialized
[    0.491305] Bluetooth: L2CAP socket layer initialized
[    0.496381] Bluetooth: SCO socket layer initialized
[    0.502651] clocksource: Switched to clocksource arch_sys_counter
[    0.581807] VFS: Disk quotas dquot_6.6.0
[    0.582934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.589959] pnp: PnP ACPI: disabled
[    0.599613] thermal_sys: Registered thermal governor 'step_wise'
[    0.599616] thermal_sys: Registered thermal governor 'power_allocator'
[    0.603184] NET: Registered protocol family 2
[    0.614167] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.622368] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.630475] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.638103] TCP: Hash tables configured (established 32768 bind 32768)
[    0.644288] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.650996] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.658273] NET: Registered protocol family 1
[    0.662906] PCI: CLS 0 bytes, default 64
[    0.666612] Trying to unpack rootfs image as initramfs...
[    0.969042] Freeing initrd memory: 7096K
[    0.971205] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.978368] kvm [1]: IPA Size Limit: 40bits
[    0.982977] kvm [1]: GICv3: no GICV resource entry
[    0.986931] kvm [1]: disabling GICv2 emulation
[    0.991384] kvm [1]: GIC system register CPU interface enabled
[    0.997313] kvm [1]: vgic interrupt IRQ1
[    1.001294] kvm [1]: Hyp mode initialized successfully
[    1.009715] Initialise system trusted keyrings
[    1.011415] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.023899] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.027035] Registering sdcardfs 0.1
[    1.030681] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.036976] fuse: init (API version 7.31)
[    1.040947] 9p: Installing v9fs 9p2000 file system support
[    1.061195] Key type asymmetric registered
[    1.062439] Asymmetric key parser 'x509' registered
[    1.067377] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.074786] io scheduler mq-deadline registered
[    1.079335] io scheduler kyber registered
[    1.086444] /ubuntu20/imx8_data/imx8_an10/android_build/vendor/nxp-opensource/kernel_imx/drivers/gpio/dido.c dido_get_of_properties() line 65, cannot get device_node
[    1.109693] i.MX8MP clock driver probe done
[    1.115607] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[    1.120533] mxs-dma 33000000.dma-apbh: initialized
[    1.123274] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[    1.129738] Bus freq driver module loaded
[    1.145963] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.151900] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
[    1.158772] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
[    1.167481] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
[    1.175960] printk: console [ttymxc1] enabled
[    1.184631] printk: bootconsole [ec_imx6q0] disabled
[    1.215387] brd: module loaded
[    1.225099] loop: module loaded
[    1.228659] zram: Added device: zram0
[    1.245575] imx ahci driver is registered.
[    1.253618] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    1.260560] spi-nor: probe of spi0.0 failed with error -2
[    1.267745] libphy: Fixed MDIO Bus: probed
[    1.272662] tun: Universal TUN/TAP device driver, 1.6
[    1.278971] thunder_xcv, ver 1.0
[    1.282228] thunder_bgx, ver 1.0
[    1.285499] nicpf, ver 1.0
[    1.290093] hclge is initializing
[    1.293427] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.300654] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.306006] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.313062] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.318842] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.324682] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.330695] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.337666] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.343278] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.351114] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.357260] sky2: driver version 1.30
[    1.361899] PPP generic driver version 2.4.2
[    1.366319] PPP BSD Compression module registered
[    1.371035] PPP Deflate Compression module registered
[    1.376113] PPP MPPE Compression module registered
[    1.380912] NET: Registered protocol family 24
[    1.385361] PPTP driver version 0.8.5
[    1.389257] usbcore: registered new interface driver r8152
[    1.394782] usbcore: registered new interface driver asix
[    1.400239] usbcore: registered new interface driver ax88179_178a
[    1.406370] usbcore: registered new interface driver cdc_ether
[    1.412238] usbcore: registered new interface driver net1080
[    1.417931] usbcore: registered new interface driver cdc_subset
[    1.423885] usbcore: registered new interface driver zaurus
[    1.429508] usbcore: registered new interface driver cdc_ncm
[    1.435352] VFIO - User Level meta-driver version: 0.3
[    1.445715] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.452309] ehci-pci: EHCI PCI platform driver
[    1.456815] ehci-platform: EHCI generic platform driver
[    1.462338] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.468535] ohci-pci: OHCI PCI platform driver
[    1.473034] ohci-platform: OHCI generic platform driver
[    1.479307] usbcore: registered new interface driver uas
[    1.484672] usbcore: registered new interface driver usb-storage
[    1.490764] usbcore: registered new interface driver usbserial_generic
[    1.497316] usbserial: USB Serial support registered for generic
[    1.503356] usbcore: registered new interface driver ftdi_sio
[    1.509129] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.516472] usbcore: registered new interface driver usb_serial_simple
[    1.523022] usbserial: USB Serial support registered for carelink
[    1.529140] usbserial: USB Serial support registered for zio
[    1.534827] usbserial: USB Serial support registered for funsoft
[    1.540859] usbserial: USB Serial support registered for flashloader
[    1.547233] usbserial: USB Serial support registered for google
[    1.553176] usbserial: USB Serial support registered for libtransistor
[    1.559725] usbserial: USB Serial support registered for vivopay
[    1.565755] usbserial: USB Serial support registered for moto_modem
[    1.572042] usbserial: USB Serial support registered for motorola_tetra
[    1.578677] usbserial: USB Serial support registered for novatel_gps
[    1.585051] usbserial: USB Serial support registered for hp4x
[    1.590818] usbserial: USB Serial support registered for suunto
[    1.596762] usbserial: USB Serial support registered for siemens_mpi
[    1.603158] usbcore: registered new interface driver usb_ehset_test
[    1.612942] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[    1.626318] usbcore: registered new interface driver xpad
[    1.631778] usbcore: registered new interface driver usb_acecad
[    1.637740] usbcore: registered new interface driver aiptek
[    1.643351] usbcore: registered new interface driver gtco
[    1.648784] usbcore: registered new interface driver hanwang
[    1.654478] usbcore: registered new interface driver kbtab
[    1.661884] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[    1.668105] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    1.677317] i2c /dev entries driver
[    1.682145] uvcvideo: Unable to create debugfs directory
[    1.687515] usbcore: registered new interface driver uvcvideo
[    1.693270] USB Video Class driver (1.1.1)
[    1.698293] __power_supply_register: Expected proper parent device for 'battery'
[    1.706033] __power_supply_register: Expected proper parent device for 'usb'
[    1.721398] trusty-virtio trusty:trusty-virtio: initializing
[    1.727285] trusty_ipc virtio0: vring0: va(pa)  (____ptrval____)(0) qsz 32 notifyid 1
[    1.735140] trusty_ipc virtio0: vring1: va(pa)  (____ptrval____)(0) qsz 32 notifyid 2
[    1.743200] trusty-virtio trusty:trusty-virtio: initializing done
[    1.743335] trusty_ipc virtio0: is online
[    1.750259] device-mapper: uevent: version 1.0.3
[    1.758225] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[    1.766887] Bluetooth: HCI UART driver ver 2.3
[    1.771348] Bluetooth: HCI UART protocol H4 registered
[    1.776497] Bluetooth: HCI UART protocol BCSP registered
[    1.781837] Bluetooth: HCI UART protocol LL registered
[    1.786983] Bluetooth: HCI UART protocol ATH3K registered
[    1.792407] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.798892] Bluetooth: HCI UART protocol Broadcom registered
[    1.804577] Bluetooth: HCI UART protocol QCA registered
[    1.810129] EDAC MC: ECC not enabled
[    1.816509] sdhci: Secure Digital Host Controller Interface driver
[    1.822704] sdhci: Copyright(c) Pierre Ossman
[    1.827336] Synopsys Designware Multimedia Card Interface Driver
[    1.834244] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.840630] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    1.852990] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    1.860139] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    1.872837] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    1.880695] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    1.920203] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    1.931108] ledtrig-cpu: registered to indicate activity on CPUs
[    1.937923] hidraw: raw HID events driver (C) Jiri Kosina
[    1.945993] usbcore: registered new interface driver usbhid
[    1.951586] usbhid: USB HID core driver
[    1.956991] mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
[    1.964353] mxc-mipi-csi2-sam 32e40000.csi: 32e40000.csi supply mipi-phy not found, using dummy regulator
[    1.974260] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
[    1.986232] ashmem: initialized
[    1.993860] optee: probing for conduit method from DT.
[    1.999031] optee: api uid mismatch
[    2.004745] Galcore version 6.4.3.p1.305572
[    2.051739] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    2.059265] mmcblk2: mmc2:0001 AKL11X 115 GiB
[    2.063988] mmcblk2boot0: mmc2:0001 AKL11X partition 1 4.00 MiB
[    2.070180] mmcblk2boot1: mmc2:0001 AKL11X partition 2 4.00 MiB
[    2.077029] mmcblk2rpmb: mmc2:0001 AKL11X partition 3 4.00 MiB, chardev (236:0)
[    2.090822] Alternate GPT is invalid, using primary GPT.
[    2.096206]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    2.115512] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[    2.126011] usbcore: registered new interface driver snd-usb-audio
[    2.134183] OF: /sound-bt-sco/simple-audio-card,cpu: could not get #sound-dai-cells for /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000
[    2.146639] asoc-simple-card sound-bt-sco: parse error -22
[    2.152158] asoc-simple-card: probe of sound-bt-sco failed with error -22
[    2.164837] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    2.172301] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    2.179588] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    2.186746] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    2.193608] imx-xcvr sound-xcvr: ASoC: failed to init link XCVR PCM: -517
[    2.200412] imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
[    2.206794] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.218070] drop_monitor: Initializing network drop monitor service
[    2.224432] NET: Registered protocol family 26
[    2.228889] netem: version 1.3
[    2.231955] u32 classifier
[    2.234668]     input device check on
[    2.238328]     Actions configured
[    2.242384] xt_time: kernel timezone is -0000
[    2.246881] gre: GRE over IPv4 demultiplexor driver
[    2.251769] IPv4 over IPsec tunneling driver
[    2.256576] Initializing XFRM netlink socket
[    2.260876] IPsec XFRM device driver
[    2.264908] NET: Registered protocol family 10
[    2.270517] Segment Routing with IPv6
[    2.274279] mip6: Mobile IPv6
[    2.278148] NET: Registered protocol family 17
[    2.282622] NET: Registered protocol family 15
[    2.288131] Bluetooth: RFCOMM TTY layer initialized
[    2.293026] Bluetooth: RFCOMM socket layer initialized
[    2.298177] Bluetooth: RFCOMM ver 1.11
[    2.301934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.307254] Bluetooth: BNEP filters: protocol multicast
[    2.312488] Bluetooth: BNEP socket layer initialized
[    2.317458] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.323406] Bluetooth: HIDP socket layer initialized
[    2.328414] l2tp_core: L2TP core driver, V2.0
[    2.332789] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.337591] 8021q: 802.1Q VLAN Support v1.8
[    2.341797] lib80211: common routines for IEEE802.11 drivers
[    2.347864] 9pnet: Installing 9P2000 support
[    2.352169] tsn generic netlink module v1 init...
[    2.357961] registered taskstats version 1
[    2.362078] Loading compiled-in X.509 certificates
[    2.367003] Key type ._fscrypt registered
[    2.371023] Key type .fscrypt registered
[    2.374950] Key type fscrypt-provisioning registered
[    2.384645] i2c i2c-0: IMX I2C adapter registered
[    2.390402] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator
[    2.397803] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator
[    2.405134] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator
[    2.412464] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator
[    2.419883] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator
[    2.427227] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator
[    2.436243] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e60000' disabled
[    2.444589] i2c i2c-1: IMX I2C adapter registered
[    2.450457] pca953x 2-0020: using no AI
[    2.455251] pca953x 2-0020: failed writing register
[    2.467882] nvmem pcf85063_nvram0: nvmem: invalid reg on /soc@0/bus@30800000/i2c@30a40000/rtc@51/clock
[    2.483902] rtc rtc1: Power loss detected, invalid time
[    2.489497] rtc-pcf85063 2-0051: registered as rtc1
[    2.494436] i2c i2c-2: IMX I2C adapter registered
[    2.500085] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    2.512449] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    2.519598] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    2.532318] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    2.540175] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    2.548202] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    2.554176] imx-dwmac 30bf0000.ethernet: no reset control found
[    2.560913] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    2.567720] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    2.572522] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[    2.579667] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[    2.586808] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    2.593518] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    2.599647] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.607321] imx-dwmac 30bf0000.ethernet: device MAC address 7e:46:32:ef:7e:37
[    2.614471] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    2.620843] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.628566] libphy: stmmac: probed
[    2.632216] mdio_bus stmmac-1: MDIO device at address 1 is missing.
[    2.654401] imx8mq-usb-phy 381f0040.usb-phy: 381f0040.usb-phy supply vbus not found, using dummy regulator
[    2.664384] imx8mq-usb-phy 382f0040.usb-phy: 382f0040.usb-phy supply vbus not found, using dummy regulator
[    2.674860] pwm-backlight lvds_backlight: aaaaaaaaaaaaaaaaaaaaaa
[    2.680888] pwm-backlight lvds_backlight: bbbbbbbbbbbbbbbbbbbbbbb
[    2.686988] pwm-backlight lvds_backlight: cccccccccccccccccccccccc
[    2.693178] pwm-backlight lvds_backlight: dddddddddddddddddddddd
[    2.699211] pwm-backlight lvds_backlight: eeeeeeeeeeeeeeeeeeee
[    2.705061] pwm-backlight lvds_backlight: lvds_backlight supply power not found, using dummy regulator
[    2.714430] pwm-backlight lvds_backlight: gggggggggggggggggggggg
[    2.720500] pwm-backlight lvds_backlight: hhhhhhhhhhhhhhhhhhhhhhh
[    2.726606] pwm-backlight lvds_backlight: iiiiiiiiiiiiiiiiiiiiiii
[    2.732715] pwm-backlight lvds_backlight: jjjjjjjjjjjjjjjjjjjjj
[    2.738674] pwm-backlight lvds_backlight: kkkkkkkkkkkkkkkkkkkkk
[    2.744663] pwm-backlight lvds_backlight: llllllllllllllllll
[    2.756906] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.763562] [drm] No driver support for vblank timestamp query.
[    2.769555] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    2.777523] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    2.785486] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    2.793504] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    2.800520] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    2.808799] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    2.816470] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    2.828193] panel-lvds lvds0_panel: 11111111111111 width-mm DT property
[    2.834866] panel-lvds lvds0_panel: 22222222222 width-mm DT property
[    2.841242] panel-lvds lvds0_panel: 333333333333 width-mm DT property
[    2.847738] panel-lvds lvds0_panel: 44444444444 width-mm DT property
[    2.854127] panel-lvds lvds0_panel: 55555555555555 width-mm DT property
[    2.860765] panel-lvds lvds0_panel: 6666666666666 width-mm DT property
[    2.867895] OF: graph: no port node found in /usb-phy@381f0040
[    2.874515] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.880033] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    2.888052] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002001810010
[    2.897492] xhci-hcd xhci-hcd.1.auto: irq 69, io mem 0x38200000
[    2.903561] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.911848] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.919083] usb usb1: Product: xHCI Host Controller
[    2.923969] usb usb1: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.929376] usb usb1: SerialNumber: xhci-hcd.1.auto
[    2.934977] hub 1-0:1.0: USB hub found
[    2.938762] hub 1-0:1.0: 1 port detected
[    2.942938] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.948445] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    2.956134] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.962730] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.970936] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    2.979208] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.986439] usb usb2: Product: xHCI Host Controller
[    2.991330] usb usb2: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.996735] usb usb2: SerialNumber: xhci-hcd.1.auto
[    3.002458] hub 2-0:1.0: USB hub found
[    3.006247] hub 2-0:1.0: 1 port detected
[    3.010740] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[    3.020530] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    3.027944] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    3.035275] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    3.042426] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    3.049774] imx-xcvr sound-xcvr: snd-soc-dummy-dai <-> 30cc0000.xcvr mapping ok
[    3.057106] imx-xcvr sound-xcvr: ASoC: no DMI vendor name!
[    3.067515] spi_imx 30830000.spi: probed
[    3.073457] pca9450 0-0025: Device ID=0x31
[    3.077570] pca9450 0-0025: gpio_intr = 3
[    3.081588] pca9450 0-0025: chip_irq=74
[    3.155658] random: fast init done
[    3.175508] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_GPIO1_IO15 already requested by 30670000.pwm; cannot claim for 1-003c
[    3.187356] imx8mp-pinctrl 30330000.pinctrl: pin-20 (1-003c) status -22
[    3.193987] imx8mp-pinctrl 30330000.pinctrl: could not request pin 20 (MX8MP_IOMUXC_GPIO1_IO15) from group csi_mclk_grp  on device 30330000.pinctrl
[    3.207206] ov5640 1-003c: Error applying setting, reverse things back
[    3.213754] ov5640: probe of 1-003c failed with error -22
[    3.225436] wm8960 2-0034: Failed to issue reset
[    3.235935] rpmsg-audio-codec-wm8960 2-0034: Failed to issue reset
[    3.243295] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[    3.278992] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.280297] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    3.298940] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 45
[    3.304195] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 46
[    3.309441] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 47
[    3.314688] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 48
[    3.323324] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
[    3.323334] reg-fixed-voltage regulator-usb4-vbus: nonexclusive access to GPIO for regulator-usb4-vbus
[    3.332729] imx6q-pcie 33800000.pcie: EXT REF_CLK is used!.
[    3.341994] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb3-vbus
[    3.347966] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked.
[    3.360859] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb3-vbus) status -22
[    3.360865] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.360870] reg-fixed-voltage regulator-usb3-vbus: Error applying setting, reverse things back
[    3.360884] reg-fixed-voltage: probe of regulator-usb3-vbus failed with error -22
[    3.404582] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb2-vbus
[    3.415777] pcie phy pipe clk is not ready
[    3.418075] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb2-vbus) status -22
[    3.422161] phy phy-32f00000.pcie-phy.5: phy init failed --> -110
[    3.429993] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.429997] reg-fixed-voltage regulator-usb2-vbus: Error applying setting, reverse things back
[    3.436117] imx6q-pcie 33800000.pcie: Waiting for PHY PLL ready timeout!
[    3.448887] reg-fixed-voltage: probe of regulator-usb2-vbus failed with error -22
[    3.472322] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb1-vbus
[    3.478038] imx6q-pcie 33800000.pcie: PCIe PLL lock timeout
[    3.485811] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb1-vbus) status -22
[    3.491464] imx6q-pcie 33800000.pcie: host bridge /pcie@33800000 ranges:
[    3.499220] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.505958] imx6q-pcie 33800000.pcie:   No bus range found for /pcie@33800000, using [bus 00-ff]
[    3.518724] reg-fixed-voltage regulator-usb1-vbus: Error applying setting, reverse things back
[    3.527842] imx6q-pcie 33800000.pcie:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[    3.528112] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.528120] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.536116] reg-fixed-voltage: probe of regulator-usb1-vbus failed with error -22
[    3.543526] imx6q-pcie 33800000.pcie:   MEM 0x18000000..0x1fefffff -> 0x18000000
[    3.552546] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_SS0 already requested by 30830000.spi; cannot claim for regulator-rtc-en
[    3.571709] hub 1-1:1.0: USB hub found
[    3.573724] imx8mp-pinctrl 30330000.pinctrl: pin-127 (regulator-rtc-en) status -22
[    3.587067] hub 1-1:1.0: 4 ports detected
[    3.590172] imx8mp-pinctrl 30330000.pinctrl: could not request pin 127 (MX8MP_IOMUXC_ECSPI2_SS0) from group rtcreggrp  on device 30330000.pinctrl
[    3.614781] reg-fixed-voltage regulator-rtc-en: Error applying setting, reverse things back
[    3.623164] reg-fixed-voltage: probe of regulator-rtc-en failed with error -22
[    3.631132] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_MISO already requested by 30830000.spi; cannot claim for regulator-sd2-vsel
[    3.644102] imx8mp-pinctrl 30330000.pinctrl: pin-126 (regulator-sd2-vsel) status -22
[    3.651862] imx8mp-pinctrl 30330000.pinctrl: could not request pin 126 (MX8MP_IOMUXC_ECSPI2_MISO) from group sd2vselgrp  on device 30330000.pinctrl
[    3.665086] reg-fixed-voltage regulator-sd2-vsel: Error applying setting, reverse things back
[    3.673626] reg-fixed-voltage: probe of regulator-sd2-vsel failed with error -22
[    3.683227] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.689860] [drm] No driver support for vblank timestamp query.
[    3.695843] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    3.703798] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    3.711761] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    3.719811] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    3.726396] Hot alarm is canceled. GPU3D clock will return to 64/64
[    3.726844] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    3.741328] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    3.749001] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    3.756928] imx-drm display-subsystem: bound 32c00000.bus:ldb@32ec005c (ops imx8mp_ldb_ops)
[    3.765498] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
[    3.776543] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.787290] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
[    3.795561] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[    3.854942] Console: switching to colour frame buffer device 160x50
[    3.876866] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
[    3.894739] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30ca0000.micfil mapping ok
[    3.902602] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[    3.909889] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30cb0000.aud2htx mapping ok
[    3.916973] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[    3.923539] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card2/input1
[    3.936137] isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
[    3.943234] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.956605] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.963238] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.971866] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    3.988180] mx8-img-md: Registered mxc_isi.0.capture as /dev/video1
[    3.994611] unregister ISI channel: mxc_isi.0
[    3.999832] ALSA device list:
[    4.002832]   #0: imx-audio-xcvr
[    4.006061]   #1: imx-audio-micfil
[    4.009500]   #2: audio-hdmi
[    4.559295] imx6q-pcie 33800000.pcie: Phy link never came up
[    4.564996] imx6q-pcie 33800000.pcie: failed to initialize host
[    4.570954] imx6q-pcie 33800000.pcie: unable to add pcie port.
[    4.579502] Freeing unused kernel memory: 4416K
[    4.584124] Run /init as init process
[    4.615576] init: init first stage started!
[    4.620061] init: Switching root to '/first_stage_ramdisk'
[    4.627770] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.666891] init: [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
[    4.675120] init: [libfs_mgr]Skipping zero-length logical partition: system_b
[    4.684424] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    4.692721] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    4.700948] init: [libfs_mgr]Created logical partition product_a on device /dev/block/dm-2
[    4.709248] init: [libfs_mgr]Skipping zero-length logical partition: product_b
[    4.719499] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.731226] EXT4-fs (mmcblk2p6): warning: mounting unchecked fs, running e2fsck is recommended
[    4.740441] EXT4-fs (mmcblk2p6): mounted filesystem without journal. Opts: discard
[    4.758741] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.770638] EXT4-fs (dm-3): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.789439] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.801749] EXT4-fs (dm-4): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.813824] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.827263] EXT4-fs (dm-5): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.855174] printk: init: 21 output lines suppressed due to ratelimiting
[    4.873812] random: init: uninitialized urandom read (40 bytes read)
[    5.030090] random: init: uninitialized urandom read (40 bytes read)
[    5.055733] init: Loading SELinux policy
[    5.096641] SELinux:  Permission nlmsg_readpriv in class netlink_route_socket not defined in policy.
[    5.106121] SELinux: the above unknown classes and permissions will be denied
[    5.113311] SELinux:  policy capability network_peer_controls=1
[    5.119234] SELinux:  policy capability open_perms=1
[    5.124200] SELinux:  policy capability extended_socket_class=1
[    5.130122] SELinux:  policy capability always_check_network=0
[    5.135956] SELinux:  policy capability cgroup_seclabel=0
[    5.141356] SELinux:  policy capability nnp_nosuid_transition=1
[    5.229817] audit: type=1403 audit(13.056:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    5.229854] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    5.229854]
[    5.257929] selinux: SELinux: Loaded file_contexts
[    5.257929]
[    5.269706] random: init: uninitialized urandom read (40 bytes read)
[    5.309469] init: init second stage started!
[    5.341372] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.353855] selinux: SELinux: Loaded file_contexts
[    5.353855]
[    5.360210] init: Running restorecon...
[    5.384418] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'quicken'
[    5.396721] init: Couldn't load property file '/product_services/build.prop': open() failed: No such file or directory: No such file or directory
[    5.409834] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
[    5.424334] init: Setting product property ro.product.brand to 'Android' (from ro.product.product.brand)
[    5.433862] init: Setting product property ro.product.device to 'evk_8mp' (from ro.product.product.device)
[    5.443560] init: Setting product property ro.product.manufacturer to 'freescale' (from ro.product.product.manufacturer)
[    5.588309] ueventd: ueventd started!
[    5.595405] selinux: SELinux: Loaded file_contexts
[    5.595405]
[    5.601997] ueventd: Parsing file /ueventd.rc...
[    5.607871] ueventd: Parsing file /vendor/ueventd.rc...
[    5.614863] ueventd: Parsing file /odm/ueventd.rc...
[    5.620044] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.620658] apexd: Bootstrap subcommand detected
[    5.629864] ueventd: Parsing file /ueventd.freescale.rc...
[    5.640068] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[    5.823101] ueventd: firmware: loading 'regulatory.db' for '/devices/platform/regulatory.0/firmware/regulatory.db'
[    5.830381] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/soc@0/30800000.bus/30bd0000.dma-controller/firmware/imx!sdma!sdma-imx7d.bin'
[    5.842111] apexd: wait for '/dev/loop-control' took 170ms
[    5.854176] apexd: Pre-allocated 9 loopback devices
[    5.857406] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[    5.859661] apexd: Scanning /system/apex for embedded keys
[    5.873197] apexd: Scanning /product/apex for embedded keys
[    5.879013] apexd: ... does not exist. Skipping
[    5.883675] apexd: Scanning /system/apex looking for APEX packages.
[    5.890177] apexd: Found /system/apex/com.android.conscrypt.apex
[    5.896773] apexd: Skipped when bootstrapping
[    5.901300] apexd: Found /system/apex/com.android.runtime.debug.apex
[    5.990229] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
[    6.065499] EXT4-fs (loop1): mounted filesystem without journal. Opts: (null)
[    6.078921] printk: apexd: 13 output lines suppressed due to ratelimiting
[    6.194159] Registered swp emulation handler
[    6.229608] Console: switching to colour dummy device 80x25
[    6.245412] watchdogd: watchdogd started (interval 10, margin 20)!
[    6.252055] watchdogd: Failed to open /dev/watchdog: No such file or directory
[    6.292389] logd.auditd: start
[    6.297725] logd.klogd: 6187058250
[    6.344294] usbcore: registered new interface driver rtk_btusb
[    6.400504] zram0: detected capacity change from 0 to 629145600
[    6.403018] vvcam_video: loading out-of-tree module taints kernel.
[    6.413714] enter viv_video_init_module
[    6.430540] mkswap: Swapspace size: 614396k, UUID=1839bbda-a0e1-41ad-b8fd-80cf76215e06
[    6.455206] enter viv_isp_init_module
[    6.458752] Adding 614396k swap on /dev/block/zram0.  Priority:-2 extents:1 across:614396k SS
[    6.489640] enter viv_dwe_init_module
[    6.572752] type=1400 audit(14.400:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    6.592182] type=1400 audit(14.400:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    6.611451] type=1400 audit(14.400:4): avc: denied { search } for comm="android.hardwar" name="gsi" dev="mmcblk2p6" ino=16 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:gsi_metadata_file:s0 tclass=dir permissive=1
[    9.301272] random: crng init done
[    9.304683] random: 7 urandom warning(s) missed due to ratelimiting
[   11.166976] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
[   11.196453] init: /dev/block/by-name/userdata is not dm device: No such file or directory
[   11.205523] type=1400 audit(14.400:4): avc: denied { search } for comm="android.hardwar" name="gsi" dev="mmcblk2p6" ino=16 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:gsi_metadata_file:s0 tclass=dir permissive=1
[   11.225437] type=1400 audit(19.032:5): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.241480] type=1400 audit(19.032:5): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.257240] type=1400 audit(19.032:6): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=259 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.261452] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   11.282321] init: [libfs_mgr]Filesystem on /dev/block/dm-6 was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x10046
[   11.295483] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   11.308061] EXT4-fs (dm-6): recovery complete
[   11.312460] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[   11.322803] init: [libfs_mgr]check_fs(): mount(/dev/block/dm-6,/data,ext4)=0: Success
[   11.344142] init: [libfs_mgr]check_fs(): unmount(/data) succeeded
[   11.350511] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/dm-6
[   12.208005] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
[   12.208005]
[   12.214257] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   12.214257]
[   12.221593] e2fsck: Pass 2: Checking directory structure
[   12.221593]
[   12.228397] e2fsck: Pass 3: Checking directory connectivity
[   12.228397]
[   12.235483] e2fsck: Pass 4: Checking reference counts
[   12.235483]
[   12.242027] e2fsck: Pass 5: Checking group summary information
[   12.242027]
[   12.249412] e2fsck: /dev/block/dm-6: 11/383520 files (0.0% non-contiguous), 43458/1531904 blocks
[   12.249412]
[   12.262962] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   12.270187] init: [libfs_mgr]Reserved blocks 32768 is too large; capping to 30638
[   12.278488] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   12.289376] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[   12.300575] init: [libfs_mgr]__mount(source=/dev/block/dm-6,target=/data,type=ext4)=0: Success
[   12.326738] watchdogd: watchdogd started (interval 10, margin 20)!
[   12.333094] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   12.351440] device-mapper: bow: Switching to state Checkpoint
[   12.824103] init (pid 1) is setting deprecated v1 encryption policy; recommend upgrading to v2.
[   12.873926] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
[   12.952712] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
[   12.965509] apexd: Marking APEXd as starting
[   12.971175] apexd: Scanning /system/apex for embedded keys
[   12.980847] apexd: Scanning /product/apex for embedded keys
[   13.054212] EXT4-fs (loop2): mounted filesystem without journal. Opts: (null)
[   13.121384] EXT4-fs (loop3): mounted filesystem without journal. Opts: (null)
[   13.201140] EXT4-fs (loop4): mounted filesystem without journal. Opts: (null)
[   13.278465] EXT4-fs (loop5): mounted filesystem without journal. Opts: (null)
[   13.369859] EXT4-fs (loop6): mounted filesystem without journal. Opts: (null)
[   13.446070] EXT4-fs (loop7): mounted filesystem without journal. Opts: (null)
[   13.540168] EXT4-fs (loop8): mounted filesystem without journal. Opts: (null)
[   17.487386] init: Command 'load_persist_props' action=load_persist_props_action (/init.rc:306) took 1573ms and succeeded
[   17.498409] init: starting service 'watchdogd'...
[   17.504934] init: Service 'exec 9 (/system/bin/recovery-persist)' (pid 292) exited with status 0
[   17.514329] init: starting service 'logd-reinit'...
[   17.515365] watchdogd: watchdogd started (interval 10, margin 20)!
[   17.521007] init: processing action (load_persist_props_action) from (/system/etc/init/flags_health_check.rc:1)
[   17.525576] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   17.543363] init: Setting policy on /data/server_configurable_flags
[   17.549900] init: Policy for /data/server_configurable_flags set to 15cd3c2eedde1152 modes 1/4
[   17.558841] init: Service 'watchdogd' (pid 294) exited with status 1
[   17.564727] logd.daemon: reinit
[   17.565318] init: Sending signal 9 to service 'watchdogd' (pid 294) process group...
[   17.576279] libprocessgroup: Successfully killed process cgroup uid 0 pid 294 in 0ms
[   17.727752] update_verifier: Started with arg 1: nonencrypted
[   17.737000] update_verifier: Booting slot 0: isSlotMarkedSuccessful=0
[   17.743599] update_verifier: /data/ota_package/care_map.pb doesn't exist
[   17.750332] update_verifier: Failed to parse the care map file, skipping verification
[   17.759028] update_verifier: Deferred marking slot 0 as booted successfully.
[   17.766136] update_verifier: Leaving update_verifier.
[   17.801249] type=1400 audit(19.032:6): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=259 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   17.819167] type=1400 audit(25.628:7): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.837972] type=1400 audit(25.628:7): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.855959] type=1400 audit(25.628:8): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.873981] type=1400 audit(25.628:8): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.891921] type=1400 audit(25.636:9): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=16347 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.288744] Mass Storage Function, version: 2009/09/11
[   18.293986] LUN: removable file: (no medium)
[   18.300648] using random self ethernet address
[   18.305189] using random host ethernet address
[   18.312666] file system registered
[   18.785370] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   18.814364] watchdogd: watchdogd started (interval 10, margin 20)!
[   18.833075] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   18.854269] type=1400 audit(25.636:9): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=16347 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.890064] init: Setting policy on /data/eGalax
[   18.901792] init: Policy for /data/eGalax set to 15cd3c2eedde1152 modes 1/4
[   18.951266] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   18.975692] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.012033] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.063087] type=1400 audit(26.680:10): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=16327 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
evk_8mp:/ $ [   19.743098] type=1400 audit(26.680:10): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=16327 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
[   19.855768] read descriptors
[   19.868579] read strings
[   20.553363] printk: Binder:260_1: 99 output lines suppressed due to ratelimiting
[   20.564030] binder: release 320:320 transaction 809 in, still active
[   20.568042] kvm: exiting hardware virtualization
[   20.570716] binder: send failed reply for transaction 809 to 337:337
[   20.606405] trusty-virtio trusty:trusty-virtio: removing
Androidi.MX 8 系列 | i.MX 8QuadMax (8QM) | 8QuadPlusi.MX 8M | i.MX 8M Mini | i.MX 8M NanoRe: IMX8MP Self Designed Board system crash after booting in the system
日志显示的是首次启动时的日志。
但是当我再次重启系统时,它会生成如下所示的另一个日志。
Normal Boot
welcome to lk/MP
Reset cause: POR
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - ATF
  - U-Boot 2020.04
Net:
No ethernet found.
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
fdt      @ 44480000 (65023)
   Using Device Tree in place at 0000000044480000, end 0000000044492dfe
Starting kernel ...
[    0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboot.hardware=freescale firmware_class.path=/vendor/firmware loop.max_part=7 transparent_hugepage=never androidboot.lcd_density=240 androidboot.primary_display=imx-drm androidboot.wificountrycode=CN androidboot.selinux=permissive cma=800M@0x400M-0xb80M buildvariant=userdebug androidboot.serialno=0926980055347a54 androidboot.btmacaddr=09:26:98:00:55:34 androidboot.soc_type=imx8mp androidboot.boot_device_root=mmcblk2 androidboot.boottime=1BLL:0,1BLE:4324,KL:0,KD:0,AVB:664,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=orange androidboot.flash.locked=0 androidboot.slot_suffix=_a androidboot.vbmeta.device=PARTUUID=a670210c-8754-426c-a5b2-440a72068e31 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3456 androidboot.vbmeta.digest=6f86b17aea6
[    0.008572] Console: colour dummy device 80x25
[    0.012575] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.027545] LSM: Security Framework initializing
[    0.032145] SELinux:  Initializing.
[    0.035678] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043065] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.052141] ASID allocator initialised with 32768 entries
[    0.056458] rcu: Hierarchical SRCU implementation.
[    0.062537] EFI services will not be available.
[    0.070748] Detected VIPT I-cache on CPU1
[    0.070770] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.070796] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.071291] Detected VIPT I-cache on CPU2
[    0.071306] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.071322] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.071770] Detected VIPT I-cache on CPU3
[    0.071786] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.071801] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.071861] smp: Brought up 1 node, 4 CPUs
[    0.126891] SMP: Total of 4 processors activated.
[    0.131608] CPU features: detected: 32-bit EL0 Support
[    0.136786] CPU features: detected: CRC32 instructions
[    0.150343] CPU: All CPU(s) started at EL2
[    0.154457] alternatives: patching kernel code
[    0.161163] devtmpfs: initialized
[    0.171948] CPU2: update max cpu_capacity 1024
[    0.178462] Initilizing CustomIPI irq domain
[    0.181852] Registered cp15_barrier emulation handler
[    0.186898] Registered setend emulation handler
[    0.191748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.201257] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.230326] pinctrl core: initialized pinctrl subsystem
[    0.233494] DMI not present or invalid.
[    0.236946] NET: Registered protocol family 16
[    0.241705] schedtune: configured to support 5 boost groups
[    0.253909] DMA: preallocated 256 KiB pool for atomic allocations
[    0.257210] audit: initializing netlink subsys (disabled)
[    0.262826] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.270413] cpuidle: using governor menu
[    0.275007] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.282273] Serial: AMBA PL011 UART driver
[    0.285327] imx mu driver is registered.
[    0.289209] imx rpmsg driver is registered.
[    0.330552] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.354998] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.358882] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.365610] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.372351] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.380069] cryptd: max_cpu_qlen set to 1000
[    0.386706] ACPI: Interpreter disabled.
[    0.389562] iommu: Default domain type: Translated
[    0.392773] vgaarb: loaded
[    0.395630] SCSI subsystem initialized
[    0.399402] usbcore: registered new interface driver usbfs
[    0.404626] usbcore: registered new interface driver hub
[    0.410157] usbcore: registered new device driver usb
[    0.416056] mc: Linux media interface: v0.10
[    0.419305] videodev: Linux video capture interface: v2.00
[    0.424850] pps_core: LinuxPPS API ver. 1 registered
[    0.429781] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[    0.438979] PTP clock support registered
[    0.443266] trusty trusty: trusty version: Built: 12:16:06 Nov 19 2020
[    0.449481] trusty trusty: selected api version: 3 (requested 3)
[    0.461975] EDAC MC: Ver: 3.0.0
[    0.463348] FPGA manager framework
[    0.465802] Advanced Linux Sound Architecture Driver Initialized.
[    0.472177] Bluetooth: Core ver 2.22
[    0.475398] NET: Registered protocol family 31
[    0.479853] Bluetooth: HCI device and connection manager initialized
[    0.486240] Bluetooth: HCI socket layer initialized
[    0.491140] Bluetooth: L2CAP socket layer initialized
[    0.496213] Bluetooth: SCO socket layer initialized
[    0.502473] clocksource: Switched to clocksource arch_sys_counter
[    0.581760] VFS: Disk quotas dquot_6.6.0
[    0.582890] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.589906] pnp: PnP ACPI: disabled
[    0.599523] thermal_sys: Registered thermal governor 'step_wise'
[    0.599527] thermal_sys: Registered thermal governor 'power_allocator'
[    0.603101] NET: Registered protocol family 2
[    0.614092] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.622278] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.630391] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.638013] TCP: Hash tables configured (established 32768 bind 32768)
[    0.644197] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.650910] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.658183] NET: Registered protocol family 1
[    0.662794] PCI: CLS 0 bytes, default 64
[    0.666544] Trying to unpack rootfs image as initramfs...
[    0.968860] Freeing initrd memory: 7096K
[    0.971029] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.978177] kvm [1]: IPA Size Limit: 40bits
[    0.982797] kvm [1]: GICv3: no GICV resource entry
[    0.986748] kvm [1]: disabling GICv2 emulation
[    0.991201] kvm [1]: GIC system register CPU interface enabled
[    0.997133] kvm [1]: vgic interrupt IRQ1
[    1.001111] kvm [1]: Hyp mode initialized successfully
[    1.009394] Initialise system trusted keyrings
[    1.011102] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.023604] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.026737] Registering sdcardfs 0.1
[    1.030372] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.036685] fuse: init (API version 7.31)
[    1.040636] 9p: Installing v9fs 9p2000 file system support
[    1.060571] Key type asymmetric registered
[    1.061815] Asymmetric key parser 'x509' registered
[    1.066755] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.074159] io scheduler mq-deadline registered
[    1.078713] io scheduler kyber registered
[    1.085722] /ubuntu20/imx8_data/imx8_an10/android_build/vendor/nxp-opensource/kernel_imx/drivers/gpio/dido.c dido_get_of_properties() line 65, cannot get device_node
[    1.108788] i.MX8MP clock driver probe done
[    1.114677] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[    1.120214] mxs-dma 33000000.dma-apbh: initialized
[    1.122338] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[    1.128691] Bus freq driver module loaded
[    1.145031] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.150879] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 28, base_baud = 5000000) is a IMX
[    1.157844] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 29, base_baud = 5000000) is a IMX
[    1.166555] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 30, base_baud = 1500000) is a IMX
[    1.175023] printk: console [ttymxc1] enabled
[    1.183706] printk: bootconsole [ec_imx6q0] disabled
[    1.214047] brd: module loaded
[    1.223859] loop: module loaded
[    1.227381] zram: Added device: zram0
[    1.244283] imx ahci driver is registered.
[    1.252219] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    1.259130] spi-nor: probe of spi0.0 failed with error -2
[    1.266262] libphy: Fixed MDIO Bus: probed
[    1.271224] tun: Universal TUN/TAP device driver, 1.6
[    1.277448] thunder_xcv, ver 1.0
[    1.280720] thunder_bgx, ver 1.0
[    1.283992] nicpf, ver 1.0
[    1.288493] hclge is initializing
[    1.291822] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.299048] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.304400] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.311457] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.317246] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.323083] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.329075] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.336049] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.341660] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.349497] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.355640] sky2: driver version 1.30
[    1.360226] PPP generic driver version 2.4.2
[    1.364657] PPP BSD Compression module registered
[    1.369372] PPP Deflate Compression module registered
[    1.374450] PPP MPPE Compression module registered
[    1.379250] NET: Registered protocol family 24
[    1.383697] PPTP driver version 0.8.5
[    1.387587] usbcore: registered new interface driver r8152
[    1.393116] usbcore: registered new interface driver asix
[    1.398569] usbcore: registered new interface driver ax88179_178a
[    1.404697] usbcore: registered new interface driver cdc_ether
[    1.410567] usbcore: registered new interface driver net1080
[    1.416266] usbcore: registered new interface driver cdc_subset
[    1.422228] usbcore: registered new interface driver zaurus
[    1.427847] usbcore: registered new interface driver cdc_ncm
[    1.433690] VFIO - User Level meta-driver version: 0.3
[    1.443948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.450523] ehci-pci: EHCI PCI platform driver
[    1.455026] ehci-platform: EHCI generic platform driver
[    1.460530] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.466725] ohci-pci: OHCI PCI platform driver
[    1.471217] ohci-platform: OHCI generic platform driver
[    1.477425] usbcore: registered new interface driver uas
[    1.482795] usbcore: registered new interface driver usb-storage
[    1.488880] usbcore: registered new interface driver usbserial_generic
[    1.495435] usbserial: USB Serial support registered for generic
[    1.501487] usbcore: registered new interface driver ftdi_sio
[    1.507259] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.514605] usbcore: registered new interface driver usb_serial_simple
[    1.521158] usbserial: USB Serial support registered for carelink
[    1.527273] usbserial: USB Serial support registered for zio
[    1.532954] usbserial: USB Serial support registered for funsoft
[    1.538985] usbserial: USB Serial support registered for flashloader
[    1.545364] usbserial: USB Serial support registered for google
[    1.551306] usbserial: USB Serial support registered for libtransistor
[    1.557859] usbserial: USB Serial support registered for vivopay
[    1.563890] usbserial: USB Serial support registered for moto_modem
[    1.570178] usbserial: USB Serial support registered for motorola_tetra
[    1.576814] usbserial: USB Serial support registered for novatel_gps
[    1.583185] usbserial: USB Serial support registered for hp4x
[    1.588954] usbserial: USB Serial support registered for suunto
[    1.594898] usbserial: USB Serial support registered for siemens_mpi
[    1.601294] usbcore: registered new interface driver usb_ehset_test
[    1.610921] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[    1.624304] usbcore: registered new interface driver xpad
[    1.629762] usbcore: registered new interface driver usb_acecad
[    1.635721] usbcore: registered new interface driver aiptek
[    1.641330] usbcore: registered new interface driver gtco
[    1.646767] usbcore: registered new interface driver hanwang
[    1.652467] usbcore: registered new interface driver kbtab
[    1.659881] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[    1.666103] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    1.675320] i2c /dev entries driver
[    1.680139] uvcvideo: Unable to create debugfs directory
[    1.685501] usbcore: registered new interface driver uvcvideo
[    1.691258] USB Video Class driver (1.1.1)
[    1.696261] __power_supply_register: Expected proper parent device for 'battery'
[    1.704023] __power_supply_register: Expected proper parent device for 'usb'
[    1.719391] trusty-virtio trusty:trusty-virtio: initializing
[    1.725244] trusty_ipc virtio0: vring0: va(pa)  (____ptrval____)(0) qsz 32 notifyid 1
[    1.733105] trusty_ipc virtio0: vring1: va(pa)  (____ptrval____)(0) qsz 32 notifyid 2
[    1.741162] trusty-virtio trusty:trusty-virtio: initializing done
[    1.741297] trusty_ipc virtio0: is online
[    1.748265] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0)
[    1.758108] device-mapper: uevent: version 1.0.3
[    1.762979] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[    1.771659] Bluetooth: HCI UART driver ver 2.3
[    1.776122] Bluetooth: HCI UART protocol H4 registered
[    1.781269] Bluetooth: HCI UART protocol BCSP registered
[    1.786614] Bluetooth: HCI UART protocol LL registered
[    1.791760] Bluetooth: HCI UART protocol ATH3K registered
[    1.797185] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.803657] Bluetooth: HCI UART protocol Broadcom registered
[    1.809341] Bluetooth: HCI UART protocol QCA registered
[    1.814878] EDAC MC: ECC not enabled
[    1.821131] sdhci: Secure Digital Host Controller Interface driver
[    1.827337] sdhci: Copyright(c) Pierre Ossman
[    1.831984] Synopsys Designware Multimedia Card Interface Driver
[    1.838884] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.845231] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    1.857594] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    1.864741] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    1.877442] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    1.885297] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    1.924707] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    1.935293] ledtrig-cpu: registered to indicate activity on CPUs
[    1.942052] hidraw: raw HID events driver (C) Jiri Kosina
[    1.950140] usbcore: registered new interface driver usbhid
[    1.955731] usbhid: USB HID core driver
[    1.961117] mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
[    1.968481] mxc-mipi-csi2-sam 32e40000.csi: 32e40000.csi supply mipi-phy not found, using dummy regulator
[    1.978376] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
[    1.990351] ashmem: initialized
[    1.997949] optee: probing for conduit method from DT.
[    2.003122] optee: api uid mismatch
[    2.008786] Galcore version 6.4.3.p1.305572
[    2.055455] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    2.062951] mmcblk2: mmc2:0001 AKL11X 115 GiB
[    2.067666] mmcblk2boot0: mmc2:0001 AKL11X partition 1 4.00 MiB
[    2.073836] mmcblk2boot1: mmc2:0001 AKL11X partition 2 4.00 MiB
[    2.080685] mmcblk2rpmb: mmc2:0001 AKL11X partition 3 4.00 MiB, chardev (236:0)
[    2.093403] Alternate GPT is invalid, using primary GPT.
[    2.098799]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    2.120362] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[    2.130834] usbcore: registered new interface driver snd-usb-audio
[    2.139047] OF: /sound-bt-sco/simple-audio-card,cpu: could not get #sound-dai-cells for /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000
[    2.151502] asoc-simple-card sound-bt-sco: parse error -22
[    2.157006] asoc-simple-card: probe of sound-bt-sco failed with error -22
[    2.169543] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    2.176958] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    2.184216] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    2.191366] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    2.198239] imx-xcvr sound-xcvr: ASoC: failed to init link XCVR PCM: -517
[    2.205040] imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
[    2.211425] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.221559] drop_monitor: Initializing network drop monitor service
[    2.227921] NET: Registered protocol family 26
[    2.232386] netem: version 1.3
[    2.235459] u32 classifier
[    2.238166]     input device check on
[    2.241834]     Actions configured
[    2.245894] xt_time: kernel timezone is -0000
[    2.250369] gre: GRE over IPv4 demultiplexor driver
[    2.255256] IPv4 over IPsec tunneling driver
[    2.260056] Initializing XFRM netlink socket
[    2.264358] IPsec XFRM device driver
[    2.268398] NET: Registered protocol family 10
[    2.273902] Segment Routing with IPv6
[    2.277657] mip6: Mobile IPv6
[    2.281532] NET: Registered protocol family 17
[    2.286005] NET: Registered protocol family 15
[    2.290912] Bluetooth: RFCOMM TTY layer initialized
[    2.295807] Bluetooth: RFCOMM socket layer initialized
[    2.300956] Bluetooth: RFCOMM ver 1.11
[    2.304719] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.310036] Bluetooth: BNEP filters: protocol multicast
[    2.315270] Bluetooth: BNEP socket layer initialized
[    2.320245] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.326191] Bluetooth: HIDP socket layer initialized
[    2.331192] l2tp_core: L2TP core driver, V2.0
[    2.335565] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.340362] 8021q: 802.1Q VLAN Support v1.8
[    2.344574] lib80211: common routines for IEEE802.11 drivers
[    2.350654] 9pnet: Installing 9P2000 support
[    2.354962] tsn generic netlink module v1 init...
[    2.360756] registered taskstats version 1
[    2.364872] Loading compiled-in X.509 certificates
[    2.369791] Key type ._fscrypt registered
[    2.373811] Key type .fscrypt registered
[    2.377742] Key type fscrypt-provisioning registered
[    2.387356] i2c i2c-0: IMX I2C adapter registered
[    2.393083] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator
[    2.400481] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator
[    2.407832] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator
[    2.415162] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator
[    2.422575] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator
[    2.429923] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator
[    2.438658] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e60000' disabled
[    2.446987] i2c i2c-1: IMX I2C adapter registered
[    2.452859] pca953x 2-0020: using no AI
[    2.457041] pca953x 2-0020: failed writing register
[    2.464232] nvmem pcf85063_nvram0: nvmem: invalid reg on /soc@0/bus@30800000/i2c@30a40000/rtc@51/clock
[    2.475722] rtc rtc1: Power loss detected, invalid time
[    2.481668] rtc-pcf85063 2-0051: registered as rtc1
[    2.486611] i2c i2c-2: IMX I2C adapter registered
[    2.492243] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    2.504608] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    2.511760] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    2.524464] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    2.532338] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    2.540344] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    2.546330] imx-dwmac 30bf0000.ethernet: no reset control found
[    2.552775] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    2.559581] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    2.564388] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[    2.571534] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[    2.578679] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    2.585385] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    2.591518] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.599191] imx-dwmac 30bf0000.ethernet: device MAC address e6:c8:4a:db:83:6d
[    2.606338] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    2.612708] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.620431] libphy: stmmac: probed
[    2.624079] mdio_bus stmmac-1: MDIO device at address 1 is missing.
[    2.646673] imx8mq-usb-phy 381f0040.usb-phy: 381f0040.usb-phy supply vbus not found, using dummy regulator
[    2.656589] imx8mq-usb-phy 382f0040.usb-phy: 382f0040.usb-phy supply vbus not found, using dummy regulator
[    2.667021] pwm-backlight lvds_backlight: aaaaaaaaaaaaaaaaaaaaaa
[    2.673050] pwm-backlight lvds_backlight: bbbbbbbbbbbbbbbbbbbbbbb
[    2.679156] pwm-backlight lvds_backlight: cccccccccccccccccccccccc
[    2.685345] pwm-backlight lvds_backlight: dddddddddddddddddddddd
[    2.691385] pwm-backlight lvds_backlight: eeeeeeeeeeeeeeeeeeee
[    2.697234] pwm-backlight lvds_backlight: lvds_backlight supply power not found, using dummy regulator
[    2.706611] pwm-backlight lvds_backlight: gggggggggggggggggggggg
[    2.712686] pwm-backlight lvds_backlight: hhhhhhhhhhhhhhhhhhhhhhh
[    2.718791] pwm-backlight lvds_backlight: iiiiiiiiiiiiiiiiiiiiiii
[    2.724894] pwm-backlight lvds_backlight: jjjjjjjjjjjjjjjjjjjjj
[    2.730835] pwm-backlight lvds_backlight: kkkkkkkkkkkkkkkkkkkkk
[    2.736819] pwm-backlight lvds_backlight: llllllllllllllllll
[    2.749185] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.755846] [drm] No driver support for vblank timestamp query.
[    2.761849] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    2.769812] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    2.777777] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    2.785795] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    2.792804] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    2.801080] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    2.808753] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    2.820444] panel-lvds lvds0_panel: 11111111111111 width-mm DT property
[    2.827103] panel-lvds lvds0_panel: 22222222222 width-mm DT property
[    2.833481] panel-lvds lvds0_panel: 333333333333 width-mm DT property
[    2.839956] panel-lvds lvds0_panel: 44444444444 width-mm DT property
[    2.846331] panel-lvds lvds0_panel: 55555555555555 width-mm DT property
[    2.852978] panel-lvds lvds0_panel: 6666666666666 width-mm DT property
[    2.860119] OF: graph: no port node found in /usb-phy@381f0040
[    2.866780] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.872297] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    2.880315] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002001810010
[    2.889753] xhci-hcd xhci-hcd.1.auto: irq 70, io mem 0x38200000
[    2.895825] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.904100] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.911333] usb usb1: Product: xHCI Host Controller
[    2.916217] usb usb1: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.921624] usb usb1: SerialNumber: xhci-hcd.1.auto
[    2.927206] hub 1-0:1.0: USB hub found
[    2.931002] hub 1-0:1.0: 1 port detected
[    2.935166] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.940672] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    2.948341] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.954954] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.963154] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    2.971428] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.978660] usb usb2: Product: xHCI Host Controller
[    2.983548] usb usb2: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.988960] usb usb2: SerialNumber: xhci-hcd.1.auto
[    2.994495] hub 2-0:1.0: USB hub found
[    2.998272] hub 2-0:1.0: 1 port detected
[    3.002762] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[    3.012521] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    3.019936] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    3.027248] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    3.034399] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    3.041709] imx-xcvr sound-xcvr: snd-soc-dummy-dai <-> 30cc0000.xcvr mapping ok
[    3.049041] imx-xcvr sound-xcvr: ASoC: no DMI vendor name!
[    3.056399] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_MOSI already requested by 30280000.watchdog; cannot claim for 30830000.spi
[    3.069306] imx8mp-pinctrl 30330000.pinctrl: pin-125 (30830000.spi) status -22
[    3.076542] imx8mp-pinctrl 30330000.pinctrl: could not request pin 125 (MX8MP_IOMUXC_ECSPI2_MOSI) from group ecspi2grp  on device 30330000.pinctrl
[    3.089677] spi_imx 30830000.spi: Error applying setting, reverse things back
[    3.096833] spi_imx: probe of 30830000.spi failed with error -22
[    3.104008] pca9450 0-0025: Device ID=0x31
[    3.108122] pca9450 0-0025: gpio_intr = 3
[    3.112145] pca9450 0-0025: chip_irq=75
[    3.146015] random: fast init done
[    3.150358] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_GPIO1_IO15 already requested by 30670000.pwm; cannot claim for 1-003c
[    3.162202] imx8mp-pinctrl 30330000.pinctrl: pin-20 (1-003c) status -22
[    3.168830] imx8mp-pinctrl 30330000.pinctrl: could not request pin 20 (MX8MP_IOMUXC_GPIO1_IO15) from group csi_mclk_grp  on device 30330000.pinctrl
[    3.182072] ov5640 1-003c: Error applying setting, reverse things back
[    3.188620] ov5640: probe of 1-003c failed with error -22
[    3.197068] wm8960 2-0034: Failed to issue reset
[    3.204584] rpmsg-audio-codec-wm8960 2-0034: Failed to issue reset
[    3.211913] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[    3.247183] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    3.260582] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 46
[    3.265841] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 47
[    3.270802] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.271089] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 48
[    3.282891] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 49
[    3.291199] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
[    3.291234] reg-fixed-voltage regulator-usb4-vbus: nonexclusive access to GPIO for regulator-usb4-vbus
[    3.300617] imx6q-pcie 33800000.pcie: EXT REF_CLK is used!.
[    3.309860] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb3-vbus
[    3.315838] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked.
[    3.328757] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb3-vbus) status -22
[    3.342858] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.355642] reg-fixed-voltage regulator-usb3-vbus: Error applying setting, reverse things back
[    3.364271] reg-fixed-voltage: probe of regulator-usb3-vbus failed with error -22
[    3.372454] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb2-vbus
[    3.383918] pcie phy pipe clk is not ready
[    3.385952] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb2-vbus) status -22
[    3.390031] phy phy-32f00000.pcie-phy.5: phy init failed --> -110
[    3.390036] imx6q-pcie 33800000.pcie: Waiting for PHY PLL ready timeout!
[    3.397889] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.423465] reg-fixed-voltage regulator-usb2-vbus: Error applying setting, reverse things back
[    3.424486] imx6q-pcie 33800000.pcie: PCIe PLL lock timeout
[    3.432107] reg-fixed-voltage: probe of regulator-usb2-vbus failed with error -22
[    3.437706] imx6q-pcie 33800000.pcie: host bridge /pcie@33800000 ranges:
[    3.445800] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb1-vbus
[    3.451851] imx6q-pcie 33800000.pcie:   No bus range found for /pcie@33800000, using [bus 00-ff]
[    3.451870] imx6q-pcie 33800000.pcie:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[    3.465372] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb1-vbus) status -22
[    3.474158] imx6q-pcie 33800000.pcie:   MEM 0x18000000..0x1fefffff -> 0x18000000
[    3.474451] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.474459] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.481549] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.524928] reg-fixed-voltage regulator-usb1-vbus: Error applying setting, reverse things back
[    3.533569] reg-fixed-voltage: probe of regulator-usb1-vbus failed with error -22
[    3.541497] hub 1-1:1.0: USB hub found
[    3.544112] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.551912] [drm] No driver support for vblank timestamp query.
[    3.552207] hub 1-1:1.0: 4 ports detected
[    3.557909] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    3.569820] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    3.577801] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    3.585856] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    3.592859] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    3.601147] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    3.608838] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    3.616772] imx-drm display-subsystem: bound 32c00000.bus:ldb@32ec005c (ops imx8mp_ldb_ops)
[    3.625366] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
[    3.636270] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.646497] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
[    3.654770] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[    3.714197] Console: switching to colour frame buffer device 160x50
[    3.726141] Hot alarm is canceled. GPU3D clock will return to 64/64
[    3.742385] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
[    3.757814] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30ca0000.micfil mapping ok
[    3.765684] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[    3.773594] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30cb0000.aud2htx mapping ok
[    3.780673] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[    3.787847] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card2/input1
[    3.800414] isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
[    3.807510] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.819216] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.825875] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.834524] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    3.844672] mx8-img-md: Registered mxc_isi.0.capture as /dev/video1
[    3.851321] unregister ISI channel: mxc_isi.0
[    3.856848] ALSA device list:
[    3.859839]   #0: imx-audio-xcvr
[    3.863093]   #1: imx-audio-micfil
[    3.866503]   #2: audio-hdmi
[    4.483422] imx6q-pcie 33800000.pcie: Phy link never came up
[    4.489122] imx6q-pcie 33800000.pcie: failed to initialize host
[    4.495078] imx6q-pcie 33800000.pcie: unable to add pcie port.
[    4.503316] Freeing unused kernel memory: 4416K
[    4.507936] Run /init as init process
[    4.539282] init: init first stage started!
[    4.543755] init: Switching root to '/first_stage_ramdisk'
[    4.551461] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.590101] init: [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
[    4.598440] init: [libfs_mgr]Skipping zero-length logical partition: system_b
[    4.606853] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    4.615122] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    4.623959] init: [libfs_mgr]Created logical partition product_a on device /dev/block/dm-2
[    4.632256] init: [libfs_mgr]Skipping zero-length logical partition: product_b
[    4.642553] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.653330] EXT4-fs (mmcblk2p6): warning: mounting unchecked fs, running e2fsck is recommended
[    4.662603] EXT4-fs (mmcblk2p6): mounted filesystem without journal. Opts: discard
[    4.670348] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.681057] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.701152] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.713628] EXT4-fs (dm-3): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.731825] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.745097] EXT4-fs (dm-4): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.757210] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.771831] EXT4-fs (dm-5): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.783872] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.796143] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.824474] printk: init: 21 output lines suppressed due to ratelimiting
[    4.845592] random: init: uninitialized urandom read (40 bytes read)
[    4.987323] random: init: uninitialized urandom read (40 bytes read)
[    5.010594] init: Loading SELinux policy
[    5.048657] SELinux:  Permission nlmsg_readpriv in class netlink_route_socket not defined in policy.
[    5.058130] SELinux: the above unknown classes and permissions will be denied
[    5.065335] SELinux:  policy capability network_peer_controls=1
[    5.071258] SELinux:  policy capability open_perms=1
[    5.076250] SELinux:  policy capability extended_socket_class=1
[    5.082178] SELinux:  policy capability always_check_network=0
[    5.088052] SELinux:  policy capability cgroup_seclabel=0
[    5.093472] SELinux:  policy capability nnp_nosuid_transition=1
[    5.181619] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    5.181619]
[    5.181622] audit: type=1403 audit(13.012:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    5.210320] selinux: SELinux: Loaded file_contexts
[    5.210320]
[    5.222363] random: init: uninitialized urandom read (40 bytes read)
[    5.262211] init: init second stage started!
[    5.294525] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.307148] selinux: SELinux: Loaded file_contexts
[    5.307148]
[    5.313510] init: Running restorecon...
[    5.337875] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'quicken'
[    5.349533] init: Couldn't load property file '/product_services/build.prop': open() failed: No such file or directory: No such file or directory
[    5.362648] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
[    5.377155] init: Setting product property ro.product.brand to 'Android' (from ro.product.product.brand)
[    5.386703] init: Setting product property ro.product.device to 'evk_8mp' (from ro.product.product.device)
[    5.396406] init: Setting product property ro.product.manufacturer to 'freescale' (from ro.product.product.manufacturer)
[    5.470744] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    5.551985] ueventd: ueventd started!
[    5.559108] selinux: SELinux: Loaded file_contexts
[    5.559108]
[    5.565679] ueventd: Parsing file /ueventd.rc...
[    5.571500] apexd: Bootstrap subcommand detected
[    5.572588] ueventd: Parsing file /vendor/ueventd.rc...
[    5.582424] ueventd: Parsing file /odm/ueventd.rc...
[    5.587529] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.597399] ueventd: Parsing file /ueventd.freescale.rc...
[    5.602952] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[    5.773052] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/soc@0/30800000.bus/30bd0000.dma-controller/firmware/imx!sdma!sdma-imx7d.bin'
[    5.787758] ueventd: firmware: loading 'regulatory.db' for '/devices/platform/regulatory.0/firmware/regulatory.db'
[    5.789442] apexd: wait for '/dev/loop-control' took 191ms
[    5.804387] apexd: Pre-allocated 9 loopback devices
[    5.810451] apexd: Scanning /system/apex for embedded keys
[    5.818133] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[    5.820667] apexd: Scanning /product/apex for embedded keys
[    5.830259] apexd: ... does not exist. Skipping
[    5.834912] apexd: Scanning /system/apex looking for APEX packages.
[    5.841436] apexd: Found /system/apex/com.android.conscrypt.apex
[    5.848043] apexd: Skipped when bootstrapping
[    5.852559] apexd: Found /system/apex/com.android.runtime.debug.apex
[    5.944272] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
[    6.033780] EXT4-fs (loop1): mounted filesystem without journal. Opts: (null)
[    6.047251] printk: apexd: 13 output lines suppressed due to ratelimiting
[    6.185804] Registered swp emulation handler
[    6.217701] Console: switching to colour dummy device 80x25
[    6.236828] watchdogd: watchdogd started (interval 10, margin 20)!
[    6.252843] logd.auditd: start
[    6.259590] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.263556] logd.klogd: 6185073500
[    6.271990] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.293012] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.306361] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.319633] usbcore: registered new interface driver rtk_btusb
[    6.377240] vvcam_video: loading out-of-tree module taints kernel.
[    6.384991] enter viv_video_init_module
[    6.397209] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm vold: deleted inode referenced: 16
[    6.434220] zram0: detected capacity change from 0 to 629145600
[    6.434222] enter viv_isp_init_module
[    6.469312] mkswap: Swapspace size: 614396k, UUID=7977a225-d8ae-44c0-856b-35e5f3c7cd0c
[    6.477597] enter viv_dwe_init_module
[    6.502594] Adding 614396k swap on /dev/block/zram0.  Priority:-2 extents:1 across:614396k SS
[    6.594117] type=1400 audit(14.424:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    9.333839] random: crng init done
[    9.337248] random: 6 urandom warning(s) missed due to ratelimiting
[   11.052162] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
[   11.082738] init: /dev/block/by-name/userdata is not dm device: No such file or directory
[   11.091763] type=1400 audit(14.424:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[   11.111065] type=1400 audit(18.924:4): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.127099] type=1400 audit(18.924:4): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.142897] type=1400 audit(18.924:5): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=2623 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.147871] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   11.168067] init: [libfs_mgr]Filesystem on /dev/block/dm-6 was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x10046
[   11.181011] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   11.191665] EXT4-fs (dm-6): recovery complete
[   11.196048] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[   11.206324] init: [libfs_mgr]check_fs(): mount(/dev/block/dm-6,/data,ext4)=0: Success
[   11.224886] init: [libfs_mgr]check_fs(): unmount(/data) succeeded
[   11.231260] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/dm-6
[   12.055154] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
[   12.055154]
[   12.061376] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   12.061376]
[   12.068716] e2fsck: Pass 2: Checking directory structure
[   12.068716]
[   12.075517] e2fsck: Pass 3: Checking directory connectivity
[   12.075517]
[   12.082578] e2fsck: Pass 4: Checking reference counts
[   12.082578]
[   12.089130] e2fsck: Pass 5: Checking group summary information
[   12.089130]
[   12.096455] e2fsck: /dev/block/dm-6: 11/383520 files (0.0% non-contiguous), 43458/1531904 blocks
[   12.096455]
[   12.110022] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   12.117235] init: [libfs_mgr]Reserved blocks 32768 is too large; capping to 30638
[   12.125742] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   12.137066] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[   12.148282] init: [libfs_mgr]__mount(source=/dev/block/dm-6,target=/data,type=ext4)=0: Success
[   12.157755] EXT4-fs error: 11 callbacks suppressed
[   12.157762] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[   12.211235] device-mapper: bow: Switching to state Checkpoint
[   12.687278] init (pid 1) is setting deprecated v1 encryption policy; recommend upgrading to v2.
[   12.736174] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
[   12.817697] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
[   12.830521] apexd: Marking APEXd as starting
[   12.836092] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm Binder:215_2: deleted inode referenced: 12
[   12.847794] apexd: Scanning /system/apex for embedded keys
[   12.857712] apexd: Scanning /product/apex for embedded keys
[   12.944911] EXT4-fs (loop2): mounted filesystem without journal. Opts: (null)
[   13.033454] EXT4-fs (loop3): mounted filesystem without journal. Opts: (null)
[   13.101408] EXT4-fs (loop4): mounted filesystem without journal. Opts: (null)
[   13.193804] EXT4-fs (loop5): mounted filesystem without journal. Opts: (null)
[   13.289426] EXT4-fs (loop6): mounted filesystem without journal. Opts: (null)
[   13.372860] EXT4-fs (loop7): mounted filesystem without journal. Opts: (null)
[   13.454231] EXT4-fs (loop8): mounted filesystem without journal. Opts: (null)
[   17.191207] init: Command 'load_persist_props' action=load_persist_props_action (/init.rc:306) took 1382ms and succeeded
[   17.202241] init: Service 'exec 9 (/system/bin/recovery-persist)' (pid 291) exited with status 0
[   17.211551] init: starting service 'logd-reinit'...
[   17.218311] init: processing action (load_persist_props_action) from (/system/etc/init/flags_health_check.rc:1)
[   17.231005] init: Setting policy on /data/server_configurable_flags
[   17.237613] init: Policy for /data/server_configurable_flags set to c5db7d5efd01df3f modes 1/4
[   17.246839] init: starting service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)'...
[   17.259332] init: SVC_EXEC service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)' pid 293 (uid 1000 gid 1000+0 context default) started; waiting...
[   17.275469] logd.daemon: reinit
[   17.278776] init: Service 'logd-reinit' (pid 292) exited with status 0
[   17.867637] init: Service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)' (pid 293) exited with status 0 waiting took 0.608000 seconds
[   17.915069] update_verifier: Started with arg 1: nonencrypted
[   17.923696] update_verifier: Booting slot 0: isSlotMarkedSuccessful=0
[   17.930282] update_verifier: /data/ota_package/care_map.pb doesn't exist
[   17.937036] update_verifier: Failed to parse the care map file, skipping verification
[   17.945629] update_verifier: Deferred marking slot 0 as booted successfully.
[   17.952744] update_verifier: Leaving update_verifier.
[   17.997383] type=1400 audit(18.924:5): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=2623 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   18.015458] type=1400 audit(25.828:6): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.033953] type=1400 audit(25.828:6): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.052070] type=1400 audit(25.828:7): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.070346] type=1400 audit(25.828:7): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.088377] type=1400 audit(25.832:8): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=228507 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.596543] Mass Storage Function, version: 2009/09/11
[   18.601843] LUN: removable file: (no medium)
[   18.611636] using random self ethernet address
[   18.616182] using random host ethernet address
[   18.622366] file system registered
[   18.908336] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.004762] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.085698] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.193446] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.254622] type=1400 audit(25.832:8): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=228507 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   19.283218] init: Setting policy on /data/eGalax
[   19.296075] init: Policy for /data/eGalax set to c5db7d5efd01df3f modes 1/4
[   19.355259] type=1400 audit(27.084:9): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=228487 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
evk_8mp:/ $ [   19.512630] type=1400 audit(27.084:9): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=228487 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
[   19.596086] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm gsid: deleted inode referenced: 16
[   19.840037] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   20.246930] read descriptors
[   20.262966] read strings
[   20.618795] EXT4-fs error (device dm-6): ext4_find_dest_de:2030: inode #228492: block 918033: comm Binder:296_3: bad entry in directory: rec_len is smaller than minimal - offset=0, inode=0, rec_len=0, lblk=0, size=4096 fake=1
[   20.620421] printk: Binder:260_2: 99 output lines suppressed due to ratelimiting
[   20.637013] binder: release 318:352 transaction 680 in, still active
[   20.637019] binder: send failed reply for transaction 680 to 334:334
[   20.647166] Aborting journal on device dm-6-8.
[   20.678647] Kernel panic - not syncing: EXT4-fs (device dm-6): panic forced after error
[   20.686666] CPU: 2 PID: 296 Comm: Binder:296_3 Tainted: G           O      5.4.70 #96
[   20.694503] Hardware name: NXP i.MX8MPlus EVK board (DT)
[   20.699829] Call trace:
[   20.702291]  dump_backtrace+0x0/0x134
[   20.705955]  show_stack+0x14/0x1c
[   20.709271]  dump_stack+0xa0/0xd8
[   20.712587]  panic+0x148/0x350
[   20.715642]  __ext4_error_inode+0x0/0x214
[   20.719652]  __ext4_error_inode+0x154/0x214
[   20.723848]  __ext4_check_dir_entry+0x23c/0x284
[   20.728381]  ext4_find_dest_de+0xa8/0x154
[   20.732390]  add_dirent_to_buf+0x9c/0x218
[   20.736397]  ext4_add_entry+0x1fc/0xe60
[   20.740229]  ext4_create+0x104/0x20c
[   20.743804]  path_openat+0x9e0/0xe1c
[   20.747376]  do_filp_open+0x74/0x11c
[   20.750948]  do_sys_open+0x130/0x24c
[   20.754521]  __arm64_sys_openat+0x24/0x2c
[   20.758528]  el0_svc_common+0x98/0x160
[   20.762275]  el0_svc_handler+0x68/0x80
[   20.766021]  el0_svc+0x8/0xc
[   20.768903] SMP: stopping secondary CPUs
[   21.772823] SMP: failed to stop secondary CPUs 0-2
[   21.777611] Kernel Offset: disabled
[   21.781096] CPU features: 0x00010002,2000200c
[   21.785449] Memory Limit: none
[   21.788501] trusty-log panic notifier - trusty version Built: 12:16:06 Nov 19 2020
[   21.788509] Rebooting in 5 seconds..
它会显示这条日志,看来是eMMC的问题出在这里。
你好@VictorWang129
根据你的日志,这似乎不是eMMC或DDR的问题。请检查您的DTS文件配置是否正确。你对代码做了哪些修改?
B.R
No ratings
Version history
Last update:
Thursday
Updated by:
