2403501_en-US
2403501_en-US
2403501_en-US
IMX8MP Self Designed Board system crash after booting in the system
Hi everyone,
We designed a custom board using the i.MX8M Plus (IMX8MP) CPU with 4GB LPDDR4 RAM and 128GB eMMC storage.
Below is our boot log. As you can see, after booting into Linux, we can briefly enter commands in the console, but the system freezes almost immediately and becomes completely unresponsive.
We suspect this issue might be caused by the EXT4-fs error shown in the log.
Has anyone encountered a similar issue, or could you give us some advice on how to troubleshoot this? Any help would be greatly appreciated!
Thanks in advance.
U-Boot SPL 2020.04 (Aug 10 2026 - 12:59:20 +0800)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3200MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC2
Authentication key not yet programmed
keyslot package magic error, do nothing here!
NOTICE:  BL31: v2.2(release):fc5b00e8fa-dirty
NOTICE:  BL31: Built : 12:59:31, Aug 10 2026
welcome to lk/MP
boot args 0x2000000 0x56000000 0x2000 0x0
initializing trusty (Built: 12:16:06 Nov 19 2020)
Initializing Trusted OS SMC handler
avb: Initializing AVB App
hwcrypto: Initializing
hwrng_caam: Init HWRNG service provider
hwrng_srv: Start HWRNG service
hwcrypto_caam: Init HWCRYPTO service provider
hwcrypto_srv: Start HWCRYPTO service
hwkey_caam: Init HWKEY service provider
hwkey_caam: 183: Invalid magic, unpack key package fail.
hwkey_srv: Start HWKEY service
hwcrypto: enter main event loop
trusty_gatekeeper: Initializing
U-Boot 2020.04 (Aug 10 2026 - 12:59:20 +0800)
CPU:   i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
Model: NXP i.MX8MPlus abcd LPDDR4 EVK board
DRAM:  4 GiB
tcpc_init: Can't find device id=0x50
setup_typec: tcpc port2 init failed, err=-19
setup_typec: tcpc port1 init failed, err=-19
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... *** Warning - bad CRC, using default environment
[*]-Video Link 0Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
fail to get display timings
probe video device failed, ret -19
        [0] lcd-controller@32e80000, video
        [1] mipi_dsi@32e60000, video_bridge
        [2] adv7535@3d, panel
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - ATF
  - U-Boot 2020.04
flash target is MMC:2
Net:
Error: ethernet@30bf0000 address not set.
No ethernet found.
INFO Initializing Trusty device
INFO selected trusty api version: 3 (requested 3)
ss: get_rpmb_auth_key: failed to get key: -2
ss: proxy_connect: can't get storage auth key: (-2)
ss-ipc: 105: do_connect: failure initializing channel state (1001)
rpmb_proxy.c:312: ERROR rpmb_storage_proxy_init: unexpected proxy channel close
libtipc.c:92: ERROR Initlializing RPMB storage proxy service failed (-8)
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot:  0
avb.c:86: ERROR avb_do_tipc: AVB TIPC client not initialized
fsl_validate_vbmeta_public_key_rpmb: Read public key error
avb_slot_verify.c:900: ERROR: vbmeta_a: Public key used to sign data rejected.
fsl_read_rollback_index_rpmb: read rollback from Trusty error!
avb_slot_verify.c:482: ERROR: dtbo_a: Hash of data does not match digest in descriptor.
Writing A/B metadata to disk.
 verify FAIL, state: UNLOCK
 boot 'boot_a' still
kernel   @ 40480000 (36925952)
ramdisk  @ 44680000 (7268024)
fdt      @ 44480000 (65027)
Device is unlocked, press power key to skip warning logo...
no video device found!
can't show unlock warning.
ERROR - failed to read public key for keymaster
keymaster.c:318: ERROR Keymaster TIPC client not initialized!
ipc_dev.c:306: ERROR trusty_ipc_dev_close: secure OS returned (-7)
## Flattened Device Tree blob at 44480000
   Booting using the fdt blob at 0x44480000
   Using Device Tree in place at 0000000044480000, end 0000000044492e02
Found /vpu_g1@38300000 node
Modify /vpu_g1@38300000:status disabled
Found /vpu_g2@38310000 node
Modify /vpu_g2@38310000:status disabled
Found /vpu_vc8000e@38320000 node
Modify /vpu_vc8000e@38320000:status disabled
Found /vipsi@38500000 node
Modify /vipsi@38500000:status disabled
Found /soc@0/bus@32c00000/camera/isp@32e10000 node
Modify /soc@0/bus@32c00000/camera/isp@32e10000:status disabled
Found /soc@0/bus@32c00000/camera/isp@32e20000 node
Modify /soc@0/bus@32c00000/camera/isp@32e20000:status disabled
Found /dsp@3b6e8000 node
Modify /dsp@3b6e8000:status disabled
Starting kernel ...
unable to select a mode
device_remove: Device '[email protected]' failed to remove, but children are gone
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.70 (forenex@forenex20) (Android (5271481 based on r349610) clang version 8.0.8 (https://android.googlesource.com/toolchain/clang 4dba9ad555eabb40b39dc53c12d09423e9faea7b) (https://android.googlesource.com/toolchain/llvm ab552995647d484a712bf15f77e6c6f4e8ac532b) (based on LLVM 8.0.8svn), GNU ld (binutils-2.27-44492f8e) 2.27.0.20170315) #96 SMP PREEMPT Mon Aug 10 12:43:56 CST 2026
[    0.000000] Machine model: NXP i.MX8MPlus EVK board
[    0.000000] earlycon: ec_imx6q0 at MMIO 0x0000000030890000 (options '115200')
[    0.000000] printk: bootconsole [ec_imx6q0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[    0.000000] cma: Reserved 800 MiB at 0x0000000060000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000017fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x17f7cc500-0x17f7cdfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000557fffff]
[    0.000000]   node   0: [mem 0x0000000058000000-0x00000000923fffff]
[    0.000000]   node   0: [mem 0x0000000094410000-0x00000000bfffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000017fffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 32 pages/cpu s93400 r8192 d29480 u131072
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1014032
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboot.hardware=freescale firmware_class.path=/vendor/firmware loop.max_part=7 transparent_hugepage=never androidboot.lcd_density=240 androidboot.primary_display=imx-drm androidboot.wificountrycode=CN androidboot.selinux=permissive cma=800M@0x400M-0xb80M buildvariant=userdebug androidboot.serialno=0926980055347a54 androidboot.btmacaddr=09:26:98:00:55:34 androidboot.soc_type=imx8mp androidboot.boot_device_root=mmcblk2 androidboot.boottime=1BLL:0,1BLE:4332,KL:0,KD:0,AVB:671,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=orange androidboot.flash.locked=0 androidboot.slot_suffix=_a androidboot.vbmeta.device=PARTUUID=a670210c-8754-426c-a5b2-440a72068e31 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3456 androidboot.vbmeta.digest=6f86b17aea6
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0xbc000000-0xc0000000] (64MB)
[    0.000000] Memory: 3110948K/4120512K available (19388K kernel code, 1884K rwdata, 10296K rodata, 4416K init, 589K bss, 190364K reserved, 819200K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 160 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] random: get_random_bytes called from start_kernel+0x1e0/0x3a4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[    0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[    0.008586] Console: colour dummy device 80x25
[    0.012580] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.022843] pid_max: default: 32768 minimum: 301
[    0.027543] LSM: Security Framework initializing
[    0.032144] SELinux:  Initializing.
[    0.035679] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043064] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.052153] ASID allocator initialised with 32768 entries
[    0.056453] rcu: Hierarchical SRCU implementation.
[    0.062588] EFI services will not be available.
[    0.065940] smp: Bringing up secondary CPUs ...
[    0.070740] Detected VIPT I-cache on CPU1
[    0.070762] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.070788] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.071277] Detected VIPT I-cache on CPU2
[    0.071293] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.071308] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.071758] Detected VIPT I-cache on CPU3
[    0.071772] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.071787] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.071847] smp: Brought up 1 node, 4 CPUs
[    0.126892] SMP: Total of 4 processors activated.
[    0.131607] CPU features: detected: 32-bit EL0 Support
[    0.136784] CPU features: detected: CRC32 instructions
[    0.141964] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.150345] CPU: All CPU(s) started at EL2
[    0.154458] alternatives: patching kernel code
[    0.160090] CPU3: update max cpu_capacity 1024
[    0.161162] devtmpfs: initialized
[    0.171950] CPU3: update max cpu_capacity 1024
[    0.177065] Initilizing CustomIPI irq domain
[    0.181854] Registered cp15_barrier emulation handler
[    0.186900] Registered setend emulation handler
[    0.191752] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.201261] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.230348] pinctrl core: initialized pinctrl subsystem
[    0.233519] DMI not present or invalid.
[    0.236972] NET: Registered protocol family 16
[    0.241723] schedtune: configured to support 5 boost groups
[    0.253931] DMA: preallocated 256 KiB pool for atomic allocations
[    0.257232] audit: initializing netlink subsys (disabled)
[    0.262846] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.270434] cpuidle: using governor menu
[    0.275031] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.282334] Serial: AMBA PL011 UART driver
[    0.285353] imx mu driver is registered.
[    0.289231] imx rpmsg driver is registered.
[    0.330534] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.355197] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.359088] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.365812] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.372548] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.380290] cryptd: max_cpu_qlen set to 1000
[    0.386907] ACPI: Interpreter disabled.
[    0.389749] iommu: Default domain type: Translated
[    0.392979] vgaarb: loaded
[    0.395797] SCSI subsystem initialized
[    0.399630] usbcore: registered new interface driver usbfs
[    0.404821] usbcore: registered new interface driver hub
[    0.410185] usbcore: registered new device driver usb
[    0.416258] mc: Linux media interface: v0.10
[    0.419511] videodev: Linux video capture interface: v2.00
[    0.425062] pps_core: LinuxPPS API ver. 1 registered
[    0.429985] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[    0.439183] PTP clock support registered
[    0.443476] trusty trusty: trusty version: Built: 12:16:06 Nov 19 2020
[    0.449684] trusty trusty: selected api version: 3 (requested 3)
[    0.462140] EDAC MC: Ver: 3.0.0
[    0.463513] FPGA manager framework
[    0.465936] Advanced Linux Sound Architecture Driver Initialized.
[    0.472339] Bluetooth: Core ver 2.22
[    0.475559] NET: Registered protocol family 31
[    0.480018] Bluetooth: HCI device and connection manager initialized
[    0.486408] Bluetooth: HCI socket layer initialized
[    0.491305] Bluetooth: L2CAP socket layer initialized
[    0.496381] Bluetooth: SCO socket layer initialized
[    0.502651] clocksource: Switched to clocksource arch_sys_counter
[    0.581807] VFS: Disk quotas dquot_6.6.0
[    0.582934] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.589959] pnp: PnP ACPI: disabled
[    0.599613] thermal_sys: Registered thermal governor 'step_wise'
[    0.599616] thermal_sys: Registered thermal governor 'power_allocator'
[    0.603184] NET: Registered protocol family 2
[    0.614167] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.622368] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.630475] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.638103] TCP: Hash tables configured (established 32768 bind 32768)
[    0.644288] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.650996] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.658273] NET: Registered protocol family 1
[    0.662906] PCI: CLS 0 bytes, default 64
[    0.666612] Trying to unpack rootfs image as initramfs...
[    0.969042] Freeing initrd memory: 7096K
[    0.971205] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.978368] kvm [1]: IPA Size Limit: 40bits
[    0.982977] kvm [1]: GICv3: no GICV resource entry
[    0.986931] kvm [1]: disabling GICv2 emulation
[    0.991384] kvm [1]: GIC system register CPU interface enabled
[    0.997313] kvm [1]: vgic interrupt IRQ1
[    1.001294] kvm [1]: Hyp mode initialized successfully
[    1.009715] Initialise system trusted keyrings
[    1.011415] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.023899] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.027035] Registering sdcardfs 0.1
[    1.030681] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.036976] fuse: init (API version 7.31)
[    1.040947] 9p: Installing v9fs 9p2000 file system support
[    1.061195] Key type asymmetric registered
[    1.062439] Asymmetric key parser 'x509' registered
[    1.067377] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.074786] io scheduler mq-deadline registered
[    1.079335] io scheduler kyber registered
[    1.086444] /ubuntu20/imx8_data/imx8_an10/android_build/vendor/nxp-opensource/kernel_imx/drivers/gpio/dido.c dido_get_of_properties() line 65, cannot get device_node
[    1.109693] i.MX8MP clock driver probe done
[    1.115607] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[    1.120533] mxs-dma 33000000.dma-apbh: initialized
[    1.123274] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[    1.129738] Bus freq driver module loaded
[    1.145963] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.151900] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 27, base_baud = 5000000) is a IMX
[    1.158772] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 28, base_baud = 5000000) is a IMX
[    1.167481] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 29, base_baud = 1500000) is a IMX
[    1.175960] printk: console [ttymxc1] enabled
[    1.184631] printk: bootconsole [ec_imx6q0] disabled
[    1.215387] brd: module loaded
[    1.225099] loop: module loaded
[    1.228659] zram: Added device: zram0
[    1.245575] imx ahci driver is registered.
[    1.253618] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    1.260560] spi-nor: probe of spi0.0 failed with error -2
[    1.267745] libphy: Fixed MDIO Bus: probed
[    1.272662] tun: Universal TUN/TAP device driver, 1.6
[    1.278971] thunder_xcv, ver 1.0
[    1.282228] thunder_bgx, ver 1.0
[    1.285499] nicpf, ver 1.0
[    1.290093] hclge is initializing
[    1.293427] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.300654] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.306006] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.313062] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.318842] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.324682] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.330695] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.337666] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.343278] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.351114] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.357260] sky2: driver version 1.30
[    1.361899] PPP generic driver version 2.4.2
[    1.366319] PPP BSD Compression module registered
[    1.371035] PPP Deflate Compression module registered
[    1.376113] PPP MPPE Compression module registered
[    1.380912] NET: Registered protocol family 24
[    1.385361] PPTP driver version 0.8.5
[    1.389257] usbcore: registered new interface driver r8152
[    1.394782] usbcore: registered new interface driver asix
[    1.400239] usbcore: registered new interface driver ax88179_178a
[    1.406370] usbcore: registered new interface driver cdc_ether
[    1.412238] usbcore: registered new interface driver net1080
[    1.417931] usbcore: registered new interface driver cdc_subset
[    1.423885] usbcore: registered new interface driver zaurus
[    1.429508] usbcore: registered new interface driver cdc_ncm
[    1.435352] VFIO - User Level meta-driver version: 0.3
[    1.445715] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.452309] ehci-pci: EHCI PCI platform driver
[    1.456815] ehci-platform: EHCI generic platform driver
[    1.462338] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.468535] ohci-pci: OHCI PCI platform driver
[    1.473034] ohci-platform: OHCI generic platform driver
[    1.479307] usbcore: registered new interface driver uas
[    1.484672] usbcore: registered new interface driver usb-storage
[    1.490764] usbcore: registered new interface driver usbserial_generic
[    1.497316] usbserial: USB Serial support registered for generic
[    1.503356] usbcore: registered new interface driver ftdi_sio
[    1.509129] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.516472] usbcore: registered new interface driver usb_serial_simple
[    1.523022] usbserial: USB Serial support registered for carelink
[    1.529140] usbserial: USB Serial support registered for zio
[    1.534827] usbserial: USB Serial support registered for funsoft
[    1.540859] usbserial: USB Serial support registered for flashloader
[    1.547233] usbserial: USB Serial support registered for google
[    1.553176] usbserial: USB Serial support registered for libtransistor
[    1.559725] usbserial: USB Serial support registered for vivopay
[    1.565755] usbserial: USB Serial support registered for moto_modem
[    1.572042] usbserial: USB Serial support registered for motorola_tetra
[    1.578677] usbserial: USB Serial support registered for novatel_gps
[    1.585051] usbserial: USB Serial support registered for hp4x
[    1.590818] usbserial: USB Serial support registered for suunto
[    1.596762] usbserial: USB Serial support registered for siemens_mpi
[    1.603158] usbcore: registered new interface driver usb_ehset_test
[    1.612942] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[    1.626318] usbcore: registered new interface driver xpad
[    1.631778] usbcore: registered new interface driver usb_acecad
[    1.637740] usbcore: registered new interface driver aiptek
[    1.643351] usbcore: registered new interface driver gtco
[    1.648784] usbcore: registered new interface driver hanwang
[    1.654478] usbcore: registered new interface driver kbtab
[    1.661884] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[    1.668105] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    1.677317] i2c /dev entries driver
[    1.682145] uvcvideo: Unable to create debugfs directory
[    1.687515] usbcore: registered new interface driver uvcvideo
[    1.693270] USB Video Class driver (1.1.1)
[    1.698293] __power_supply_register: Expected proper parent device for 'battery'
[    1.706033] __power_supply_register: Expected proper parent device for 'usb'
[    1.721398] trusty-virtio trusty:trusty-virtio: initializing
[    1.727285] trusty_ipc virtio0: vring0: va(pa)  (____ptrval____)(0) qsz 32 notifyid 1
[    1.735140] trusty_ipc virtio0: vring1: va(pa)  (____ptrval____)(0) qsz 32 notifyid 2
[    1.743200] trusty-virtio trusty:trusty-virtio: initializing done
[    1.743335] trusty_ipc virtio0: is online
[    1.750259] device-mapper: uevent: version 1.0.3
[    1.758225] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[    1.766887] Bluetooth: HCI UART driver ver 2.3
[    1.771348] Bluetooth: HCI UART protocol H4 registered
[    1.776497] Bluetooth: HCI UART protocol BCSP registered
[    1.781837] Bluetooth: HCI UART protocol LL registered
[    1.786983] Bluetooth: HCI UART protocol ATH3K registered
[    1.792407] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.798892] Bluetooth: HCI UART protocol Broadcom registered
[    1.804577] Bluetooth: HCI UART protocol QCA registered
[    1.810129] EDAC MC: ECC not enabled
[    1.816509] sdhci: Secure Digital Host Controller Interface driver
[    1.822704] sdhci: Copyright(c) Pierre Ossman
[    1.827336] Synopsys Designware Multimedia Card Interface Driver
[    1.834244] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.840630] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    1.852990] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    1.860139] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    1.872837] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    1.880695] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    1.920203] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    1.931108] ledtrig-cpu: registered to indicate activity on CPUs
[    1.937923] hidraw: raw HID events driver (C) Jiri Kosina
[    1.945993] usbcore: registered new interface driver usbhid
[    1.951586] usbhid: USB HID core driver
[    1.956991] mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
[    1.964353] mxc-mipi-csi2-sam 32e40000.csi: 32e40000.csi supply mipi-phy not found, using dummy regulator
[    1.974260] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
[    1.986232] ashmem: initialized
[    1.993860] optee: probing for conduit method from DT.
[    1.999031] optee: api uid mismatch
[    2.004745] Galcore version 6.4.3.p1.305572
[    2.051739] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    2.059265] mmcblk2: mmc2:0001 AKL11X 115 GiB
[    2.063988] mmcblk2boot0: mmc2:0001 AKL11X partition 1 4.00 MiB
[    2.070180] mmcblk2boot1: mmc2:0001 AKL11X partition 2 4.00 MiB
[    2.077029] mmcblk2rpmb: mmc2:0001 AKL11X partition 3 4.00 MiB, chardev (236:0)
[    2.090822] Alternate GPT is invalid, using primary GPT.
[    2.096206]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    2.115512] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[    2.126011] usbcore: registered new interface driver snd-usb-audio
[    2.134183] OF: /sound-bt-sco/simple-audio-card,cpu: could not get #sound-dai-cells for /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000
[    2.146639] asoc-simple-card sound-bt-sco: parse error -22
[    2.152158] asoc-simple-card: probe of sound-bt-sco failed with error -22
[    2.164837] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    2.172301] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    2.179588] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    2.186746] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    2.193608] imx-xcvr sound-xcvr: ASoC: failed to init link XCVR PCM: -517
[    2.200412] imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
[    2.206794] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.218070] drop_monitor: Initializing network drop monitor service
[    2.224432] NET: Registered protocol family 26
[    2.228889] netem: version 1.3
[    2.231955] u32 classifier
[    2.234668]     input device check on
[    2.238328]     Actions configured
[    2.242384] xt_time: kernel timezone is -0000
[    2.246881] gre: GRE over IPv4 demultiplexor driver
[    2.251769] IPv4 over IPsec tunneling driver
[    2.256576] Initializing XFRM netlink socket
[    2.260876] IPsec XFRM device driver
[    2.264908] NET: Registered protocol family 10
[    2.270517] Segment Routing with IPv6
[    2.274279] mip6: Mobile IPv6
[    2.278148] NET: Registered protocol family 17
[    2.282622] NET: Registered protocol family 15
[    2.288131] Bluetooth: RFCOMM TTY layer initialized
[    2.293026] Bluetooth: RFCOMM socket layer initialized
[    2.298177] Bluetooth: RFCOMM ver 1.11
[    2.301934] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.307254] Bluetooth: BNEP filters: protocol multicast
[    2.312488] Bluetooth: BNEP socket layer initialized
[    2.317458] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.323406] Bluetooth: HIDP socket layer initialized
[    2.328414] l2tp_core: L2TP core driver, V2.0
[    2.332789] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.337591] 8021q: 802.1Q VLAN Support v1.8
[    2.341797] lib80211: common routines for IEEE802.11 drivers
[    2.347864] 9pnet: Installing 9P2000 support
[    2.352169] tsn generic netlink module v1 init...
[    2.357961] registered taskstats version 1
[    2.362078] Loading compiled-in X.509 certificates
[    2.367003] Key type ._fscrypt registered
[    2.371023] Key type .fscrypt registered
[    2.374950] Key type fscrypt-provisioning registered
[    2.384645] i2c i2c-0: IMX I2C adapter registered
[    2.390402] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator
[    2.397803] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator
[    2.405134] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator
[    2.412464] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator
[    2.419883] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator
[    2.427227] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator
[    2.436243] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e60000' disabled
[    2.444589] i2c i2c-1: IMX I2C adapter registered
[    2.450457] pca953x 2-0020: using no AI
[    2.455251] pca953x 2-0020: failed writing register
[    2.467882] nvmem pcf85063_nvram0: nvmem: invalid reg on /soc@0/bus@30800000/i2c@30a40000/rtc@51/clock
[    2.483902] rtc rtc1: Power loss detected, invalid time
[    2.489497] rtc-pcf85063 2-0051: registered as rtc1
[    2.494436] i2c i2c-2: IMX I2C adapter registered
[    2.500085] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    2.512449] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    2.519598] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    2.532318] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    2.540175] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    2.548202] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    2.554176] imx-dwmac 30bf0000.ethernet: no reset control found
[    2.560913] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    2.567720] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    2.572522] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[    2.579667] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[    2.586808] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    2.593518] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    2.599647] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.607321] imx-dwmac 30bf0000.ethernet: device MAC address 7e:46:32:ef:7e:37
[    2.614471] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    2.620843] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.628566] libphy: stmmac: probed
[    2.632216] mdio_bus stmmac-1: MDIO device at address 1 is missing.
[    2.654401] imx8mq-usb-phy 381f0040.usb-phy: 381f0040.usb-phy supply vbus not found, using dummy regulator
[    2.664384] imx8mq-usb-phy 382f0040.usb-phy: 382f0040.usb-phy supply vbus not found, using dummy regulator
[    2.674860] pwm-backlight lvds_backlight: aaaaaaaaaaaaaaaaaaaaaa
[    2.680888] pwm-backlight lvds_backlight: bbbbbbbbbbbbbbbbbbbbbbb
[    2.686988] pwm-backlight lvds_backlight: cccccccccccccccccccccccc
[    2.693178] pwm-backlight lvds_backlight: dddddddddddddddddddddd
[    2.699211] pwm-backlight lvds_backlight: eeeeeeeeeeeeeeeeeeee
[    2.705061] pwm-backlight lvds_backlight: lvds_backlight supply power not found, using dummy regulator
[    2.714430] pwm-backlight lvds_backlight: gggggggggggggggggggggg
[    2.720500] pwm-backlight lvds_backlight: hhhhhhhhhhhhhhhhhhhhhhh
[    2.726606] pwm-backlight lvds_backlight: iiiiiiiiiiiiiiiiiiiiiii
[    2.732715] pwm-backlight lvds_backlight: jjjjjjjjjjjjjjjjjjjjj
[    2.738674] pwm-backlight lvds_backlight: kkkkkkkkkkkkkkkkkkkkk
[    2.744663] pwm-backlight lvds_backlight: llllllllllllllllll
[    2.756906] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.763562] [drm] No driver support for vblank timestamp query.
[    2.769555] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    2.777523] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    2.785486] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    2.793504] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    2.800520] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    2.808799] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    2.816470] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    2.828193] panel-lvds lvds0_panel: 11111111111111 width-mm DT property
[    2.834866] panel-lvds lvds0_panel: 22222222222 width-mm DT property
[    2.841242] panel-lvds lvds0_panel: 333333333333 width-mm DT property
[    2.847738] panel-lvds lvds0_panel: 44444444444 width-mm DT property
[    2.854127] panel-lvds lvds0_panel: 55555555555555 width-mm DT property
[    2.860765] panel-lvds lvds0_panel: 6666666666666 width-mm DT property
[    2.867895] OF: graph: no port node found in /usb-phy@381f0040
[    2.874515] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.880033] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    2.888052] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002001810010
[    2.897492] xhci-hcd xhci-hcd.1.auto: irq 69, io mem 0x38200000
[    2.903561] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.911848] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.919083] usb usb1: Product: xHCI Host Controller
[    2.923969] usb usb1: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.929376] usb usb1: SerialNumber: xhci-hcd.1.auto
[    2.934977] hub 1-0:1.0: USB hub found
[    2.938762] hub 1-0:1.0: 1 port detected
[    2.942938] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.948445] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    2.956134] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.962730] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.970936] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    2.979208] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.986439] usb usb2: Product: xHCI Host Controller
[    2.991330] usb usb2: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.996735] usb usb2: SerialNumber: xhci-hcd.1.auto
[    3.002458] hub 2-0:1.0: USB hub found
[    3.006247] hub 2-0:1.0: 1 port detected
[    3.010740] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[    3.020530] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    3.027944] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    3.035275] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    3.042426] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    3.049774] imx-xcvr sound-xcvr: snd-soc-dummy-dai <-> 30cc0000.xcvr mapping ok
[    3.057106] imx-xcvr sound-xcvr: ASoC: no DMI vendor name!
[    3.067515] spi_imx 30830000.spi: probed
[    3.073457] pca9450 0-0025: Device ID=0x31
[    3.077570] pca9450 0-0025: gpio_intr = 3
[    3.081588] pca9450 0-0025: chip_irq=74
[    3.155658] random: fast init done
[    3.175508] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_GPIO1_IO15 already requested by 30670000.pwm; cannot claim for 1-003c
[    3.187356] imx8mp-pinctrl 30330000.pinctrl: pin-20 (1-003c) status -22
[    3.193987] imx8mp-pinctrl 30330000.pinctrl: could not request pin 20 (MX8MP_IOMUXC_GPIO1_IO15) from group csi_mclk_grp  on device 30330000.pinctrl
[    3.207206] ov5640 1-003c: Error applying setting, reverse things back
[    3.213754] ov5640: probe of 1-003c failed with error -22
[    3.225436] wm8960 2-0034: Failed to issue reset
[    3.235935] rpmsg-audio-codec-wm8960 2-0034: Failed to issue reset
[    3.243295] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[    3.278992] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.280297] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    3.298940] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 45
[    3.304195] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 46
[    3.309441] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 47
[    3.314688] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 48
[    3.323324] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
[    3.323334] reg-fixed-voltage regulator-usb4-vbus: nonexclusive access to GPIO for regulator-usb4-vbus
[    3.332729] imx6q-pcie 33800000.pcie: EXT REF_CLK is used!.
[    3.341994] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb3-vbus
[    3.347966] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked.
[    3.360859] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb3-vbus) status -22
[    3.360865] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.360870] reg-fixed-voltage regulator-usb3-vbus: Error applying setting, reverse things back
[    3.360884] reg-fixed-voltage: probe of regulator-usb3-vbus failed with error -22
[    3.404582] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb2-vbus
[    3.415777] pcie phy pipe clk is not ready
[    3.418075] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb2-vbus) status -22
[    3.422161] phy phy-32f00000.pcie-phy.5: phy init failed --> -110
[    3.429993] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.429997] reg-fixed-voltage regulator-usb2-vbus: Error applying setting, reverse things back
[    3.436117] imx6q-pcie 33800000.pcie: Waiting for PHY PLL ready timeout!
[    3.448887] reg-fixed-voltage: probe of regulator-usb2-vbus failed with error -22
[    3.472322] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb1-vbus
[    3.478038] imx6q-pcie 33800000.pcie: PCIe PLL lock timeout
[    3.485811] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb1-vbus) status -22
[    3.491464] imx6q-pcie 33800000.pcie: host bridge /pcie@33800000 ranges:
[    3.499220] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.505958] imx6q-pcie 33800000.pcie:   No bus range found for /pcie@33800000, using [bus 00-ff]
[    3.518724] reg-fixed-voltage regulator-usb1-vbus: Error applying setting, reverse things back
[    3.527842] imx6q-pcie 33800000.pcie:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[    3.528112] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.528120] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.536116] reg-fixed-voltage: probe of regulator-usb1-vbus failed with error -22
[    3.543526] imx6q-pcie 33800000.pcie:   MEM 0x18000000..0x1fefffff -> 0x18000000
[    3.552546] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_SS0 already requested by 30830000.spi; cannot claim for regulator-rtc-en
[    3.571709] hub 1-1:1.0: USB hub found
[    3.573724] imx8mp-pinctrl 30330000.pinctrl: pin-127 (regulator-rtc-en) status -22
[    3.587067] hub 1-1:1.0: 4 ports detected
[    3.590172] imx8mp-pinctrl 30330000.pinctrl: could not request pin 127 (MX8MP_IOMUXC_ECSPI2_SS0) from group rtcreggrp  on device 30330000.pinctrl
[    3.614781] reg-fixed-voltage regulator-rtc-en: Error applying setting, reverse things back
[    3.623164] reg-fixed-voltage: probe of regulator-rtc-en failed with error -22
[    3.631132] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_MISO already requested by 30830000.spi; cannot claim for regulator-sd2-vsel
[    3.644102] imx8mp-pinctrl 30330000.pinctrl: pin-126 (regulator-sd2-vsel) status -22
[    3.651862] imx8mp-pinctrl 30330000.pinctrl: could not request pin 126 (MX8MP_IOMUXC_ECSPI2_MISO) from group sd2vselgrp  on device 30330000.pinctrl
[    3.665086] reg-fixed-voltage regulator-sd2-vsel: Error applying setting, reverse things back
[    3.673626] reg-fixed-voltage: probe of regulator-sd2-vsel failed with error -22
[    3.683227] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.689860] [drm] No driver support for vblank timestamp query.
[    3.695843] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    3.703798] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    3.711761] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    3.719811] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    3.726396] Hot alarm is canceled. GPU3D clock will return to 64/64
[    3.726844] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    3.741328] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    3.749001] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    3.756928] imx-drm display-subsystem: bound 32c00000.bus:ldb@32ec005c (ops imx8mp_ldb_ops)
[    3.765498] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
[    3.776543] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.787290] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
[    3.795561] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[    3.854942] Console: switching to colour frame buffer device 160x50
[    3.876866] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
[    3.894739] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30ca0000.micfil mapping ok
[    3.902602] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[    3.909889] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30cb0000.aud2htx mapping ok
[    3.916973] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[    3.923539] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card2/input1
[    3.936137] isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
[    3.943234] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.956605] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.963238] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.971866] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    3.988180] mx8-img-md: Registered mxc_isi.0.capture as /dev/video1
[    3.994611] unregister ISI channel: mxc_isi.0
[    3.999832] ALSA device list:
[    4.002832]   #0: imx-audio-xcvr
[    4.006061]   #1: imx-audio-micfil
[    4.009500]   #2: audio-hdmi
[    4.559295] imx6q-pcie 33800000.pcie: Phy link never came up
[    4.564996] imx6q-pcie 33800000.pcie: failed to initialize host
[    4.570954] imx6q-pcie 33800000.pcie: unable to add pcie port.
[    4.579502] Freeing unused kernel memory: 4416K
[    4.584124] Run /init as init process
[    4.615576] init: init first stage started!
[    4.620061] init: Switching root to '/first_stage_ramdisk'
[    4.627770] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.666891] init: [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
[    4.675120] init: [libfs_mgr]Skipping zero-length logical partition: system_b
[    4.684424] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    4.692721] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    4.700948] init: [libfs_mgr]Created logical partition product_a on device /dev/block/dm-2
[    4.709248] init: [libfs_mgr]Skipping zero-length logical partition: product_b
[    4.719499] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.731226] EXT4-fs (mmcblk2p6): warning: mounting unchecked fs, running e2fsck is recommended
[    4.740441] EXT4-fs (mmcblk2p6): mounted filesystem without journal. Opts: discard
[    4.758741] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.770638] EXT4-fs (dm-3): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.789439] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.801749] EXT4-fs (dm-4): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.813824] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.827263] EXT4-fs (dm-5): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.855174] printk: init: 21 output lines suppressed due to ratelimiting
[    4.873812] random: init: uninitialized urandom read (40 bytes read)
[    5.030090] random: init: uninitialized urandom read (40 bytes read)
[    5.055733] init: Loading SELinux policy
[    5.096641] SELinux:  Permission nlmsg_readpriv in class netlink_route_socket not defined in policy.
[    5.106121] SELinux: the above unknown classes and permissions will be denied
[    5.113311] SELinux:  policy capability network_peer_controls=1
[    5.119234] SELinux:  policy capability open_perms=1
[    5.124200] SELinux:  policy capability extended_socket_class=1
[    5.130122] SELinux:  policy capability always_check_network=0
[    5.135956] SELinux:  policy capability cgroup_seclabel=0
[    5.141356] SELinux:  policy capability nnp_nosuid_transition=1
[    5.229817] audit: type=1403 audit(13.056:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    5.229854] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    5.229854]
[    5.257929] selinux: SELinux: Loaded file_contexts
[    5.257929]
[    5.269706] random: init: uninitialized urandom read (40 bytes read)
[    5.309469] init: init second stage started!
[    5.341372] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.353855] selinux: SELinux: Loaded file_contexts
[    5.353855]
[    5.360210] init: Running restorecon...
[    5.384418] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'quicken'
[    5.396721] init: Couldn't load property file '/product_services/build.prop': open() failed: No such file or directory: No such file or directory
[    5.409834] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
[    5.424334] init: Setting product property ro.product.brand to 'Android' (from ro.product.product.brand)
[    5.433862] init: Setting product property ro.product.device to 'evk_8mp' (from ro.product.product.device)
[    5.443560] init: Setting product property ro.product.manufacturer to 'freescale' (from ro.product.product.manufacturer)
[    5.588309] ueventd: ueventd started!
[    5.595405] selinux: SELinux: Loaded file_contexts
[    5.595405]
[    5.601997] ueventd: Parsing file /ueventd.rc...
[    5.607871] ueventd: Parsing file /vendor/ueventd.rc...
[    5.614863] ueventd: Parsing file /odm/ueventd.rc...
[    5.620044] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.620658] apexd: Bootstrap subcommand detected
[    5.629864] ueventd: Parsing file /ueventd.freescale.rc...
[    5.640068] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[    5.823101] ueventd: firmware: loading 'regulatory.db' for '/devices/platform/regulatory.0/firmware/regulatory.db'
[    5.830381] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/soc@0/30800000.bus/30bd0000.dma-controller/firmware/imx!sdma!sdma-imx7d.bin'
[    5.842111] apexd: wait for '/dev/loop-control' took 170ms
[    5.854176] apexd: Pre-allocated 9 loopback devices
[    5.857406] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[    5.859661] apexd: Scanning /system/apex for embedded keys
[    5.873197] apexd: Scanning /product/apex for embedded keys
[    5.879013] apexd: ... does not exist. Skipping
[    5.883675] apexd: Scanning /system/apex looking for APEX packages.
[    5.890177] apexd: Found /system/apex/com.android.conscrypt.apex
[    5.896773] apexd: Skipped when bootstrapping
[    5.901300] apexd: Found /system/apex/com.android.runtime.debug.apex
[    5.990229] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
[    6.065499] EXT4-fs (loop1): mounted filesystem without journal. Opts: (null)
[    6.078921] printk: apexd: 13 output lines suppressed due to ratelimiting
[    6.194159] Registered swp emulation handler
[    6.229608] Console: switching to colour dummy device 80x25
[    6.245412] watchdogd: watchdogd started (interval 10, margin 20)!
[    6.252055] watchdogd: Failed to open /dev/watchdog: No such file or directory
[    6.292389] logd.auditd: start
[    6.297725] logd.klogd: 6187058250
[    6.344294] usbcore: registered new interface driver rtk_btusb
[    6.400504] zram0: detected capacity change from 0 to 629145600
[    6.403018] vvcam_video: loading out-of-tree module taints kernel.
[    6.413714] enter viv_video_init_module
[    6.430540] mkswap: Swapspace size: 614396k, UUID=1839bbda-a0e1-41ad-b8fd-80cf76215e06
[    6.455206] enter viv_isp_init_module
[    6.458752] Adding 614396k swap on /dev/block/zram0.  Priority:-2 extents:1 across:614396k SS
[    6.489640] enter viv_dwe_init_module
[    6.572752] type=1400 audit(14.400:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    6.592182] type=1400 audit(14.400:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    6.611451] type=1400 audit(14.400:4): avc: denied { search } for comm="android.hardwar" name="gsi" dev="mmcblk2p6" ino=16 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:gsi_metadata_file:s0 tclass=dir permissive=1
[    9.301272] random: crng init done
[    9.304683] random: 7 urandom warning(s) missed due to ratelimiting
[   11.166976] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
[   11.196453] init: /dev/block/by-name/userdata is not dm device: No such file or directory
[   11.205523] type=1400 audit(14.400:4): avc: denied { search } for comm="android.hardwar" name="gsi" dev="mmcblk2p6" ino=16 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:gsi_metadata_file:s0 tclass=dir permissive=1
[   11.225437] type=1400 audit(19.032:5): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.241480] type=1400 audit(19.032:5): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.257240] type=1400 audit(19.032:6): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=259 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.261452] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   11.282321] init: [libfs_mgr]Filesystem on /dev/block/dm-6 was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x10046
[   11.295483] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   11.308061] EXT4-fs (dm-6): recovery complete
[   11.312460] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[   11.322803] init: [libfs_mgr]check_fs(): mount(/dev/block/dm-6,/data,ext4)=0: Success
[   11.344142] init: [libfs_mgr]check_fs(): unmount(/data) succeeded
[   11.350511] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/dm-6
[   12.208005] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
[   12.208005]
[   12.214257] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   12.214257]
[   12.221593] e2fsck: Pass 2: Checking directory structure
[   12.221593]
[   12.228397] e2fsck: Pass 3: Checking directory connectivity
[   12.228397]
[   12.235483] e2fsck: Pass 4: Checking reference counts
[   12.235483]
[   12.242027] e2fsck: Pass 5: Checking group summary information
[   12.242027]
[   12.249412] e2fsck: /dev/block/dm-6: 11/383520 files (0.0% non-contiguous), 43458/1531904 blocks
[   12.249412]
[   12.262962] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   12.270187] init: [libfs_mgr]Reserved blocks 32768 is too large; capping to 30638
[   12.278488] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   12.289376] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[   12.300575] init: [libfs_mgr]__mount(source=/dev/block/dm-6,target=/data,type=ext4)=0: Success
[   12.326738] watchdogd: watchdogd started (interval 10, margin 20)!
[   12.333094] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   12.351440] device-mapper: bow: Switching to state Checkpoint
[   12.824103] init (pid 1) is setting deprecated v1 encryption policy; recommend upgrading to v2.
[   12.873926] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
[   12.952712] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
[   12.965509] apexd: Marking APEXd as starting
[   12.971175] apexd: Scanning /system/apex for embedded keys
[   12.980847] apexd: Scanning /product/apex for embedded keys
[   13.054212] EXT4-fs (loop2): mounted filesystem without journal. Opts: (null)
[   13.121384] EXT4-fs (loop3): mounted filesystem without journal. Opts: (null)
[   13.201140] EXT4-fs (loop4): mounted filesystem without journal. Opts: (null)
[   13.278465] EXT4-fs (loop5): mounted filesystem without journal. Opts: (null)
[   13.369859] EXT4-fs (loop6): mounted filesystem without journal. Opts: (null)
[   13.446070] EXT4-fs (loop7): mounted filesystem without journal. Opts: (null)
[   13.540168] EXT4-fs (loop8): mounted filesystem without journal. Opts: (null)
[   17.487386] init: Command 'load_persist_props' action=load_persist_props_action (/init.rc:306) took 1573ms and succeeded
[   17.498409] init: starting service 'watchdogd'...
[   17.504934] init: Service 'exec 9 (/system/bin/recovery-persist)' (pid 292) exited with status 0
[   17.514329] init: starting service 'logd-reinit'...
[   17.515365] watchdogd: watchdogd started (interval 10, margin 20)!
[   17.521007] init: processing action (load_persist_props_action) from (/system/etc/init/flags_health_check.rc:1)
[   17.525576] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   17.543363] init: Setting policy on /data/server_configurable_flags
[   17.549900] init: Policy for /data/server_configurable_flags set to 15cd3c2eedde1152 modes 1/4
[   17.558841] init: Service 'watchdogd' (pid 294) exited with status 1
[   17.564727] logd.daemon: reinit
[   17.565318] init: Sending signal 9 to service 'watchdogd' (pid 294) process group...
[   17.576279] libprocessgroup: Successfully killed process cgroup uid 0 pid 294 in 0ms
[   17.727752] update_verifier: Started with arg 1: nonencrypted
[   17.737000] update_verifier: Booting slot 0: isSlotMarkedSuccessful=0
[   17.743599] update_verifier: /data/ota_package/care_map.pb doesn't exist
[   17.750332] update_verifier: Failed to parse the care map file, skipping verification
[   17.759028] update_verifier: Deferred marking slot 0 as booted successfully.
[   17.766136] update_verifier: Leaving update_verifier.
[   17.801249] type=1400 audit(19.032:6): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=259 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   17.819167] type=1400 audit(25.628:7): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.837972] type=1400 audit(25.628:7): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.855959] type=1400 audit(25.628:8): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.873981] type=1400 audit(25.628:8): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=16343 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   17.891921] type=1400 audit(25.636:9): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=16347 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.288744] Mass Storage Function, version: 2009/09/11
[   18.293986] LUN: removable file: (no medium)
[   18.300648] using random self ethernet address
[   18.305189] using random host ethernet address
[   18.312666] file system registered
[   18.785370] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   18.814364] watchdogd: watchdogd started (interval 10, margin 20)!
[   18.833075] watchdogd: Failed to open /dev/watchdog: No such file or directory
[   18.854269] type=1400 audit(25.636:9): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=16347 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.890064] init: Setting policy on /data/eGalax
[   18.901792] init: Policy for /data/eGalax set to 15cd3c2eedde1152 modes 1/4
[   18.951266] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   18.975692] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.012033] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.063087] type=1400 audit(26.680:10): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=16327 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
evk_8mp:/ $ [   19.743098] type=1400 audit(26.680:10): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=16327 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
[   19.855768] read descriptors
[   19.868579] read strings
[   20.553363] printk: Binder:260_1: 99 output lines suppressed due to ratelimiting
[   20.564030] binder: release 320:320 transaction 809 in, still active
[   20.568042] kvm: exiting hardware virtualization
[   20.570716] binder: send failed reply for transaction 809 to 337:337
[   20.606405] trusty-virtio trusty:trusty-virtio: removing
Androidi.MX 8 Family | i.MX 8QuadMax (8QM) | 8QuadPlusi.MX 8M | i.MX 8M Mini | i.MX 8M NanoRe: IMX8MP Self Designed Board system crash after booting in the system
The log is the first time booting.
But when I reboot the system again, it will generate another log as below.
Normal Boot
welcome to lk/MP
Reset cause: POR
DRAM:  4 GiB
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - ATF
  - U-Boot 2020.04
Net:
No ethernet found.
Fastboot: Normal
Normal Boot
 boot 'boot_a' still
fdt      @ 44480000 (65023)
   Using Device Tree in place at 0000000044480000, end 0000000044492dfe
Starting kernel ...
[    0.000000] Kernel command line: console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboot.hardware=freescale firmware_class.path=/vendor/firmware loop.max_part=7 transparent_hugepage=never androidboot.lcd_density=240 androidboot.primary_display=imx-drm androidboot.wificountrycode=CN androidboot.selinux=permissive cma=800M@0x400M-0xb80M buildvariant=userdebug androidboot.serialno=0926980055347a54 androidboot.btmacaddr=09:26:98:00:55:34 androidboot.soc_type=imx8mp androidboot.boot_device_root=mmcblk2 androidboot.boottime=1BLL:0,1BLE:4324,KL:0,KD:0,AVB:664,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=orange androidboot.flash.locked=0 androidboot.slot_suffix=_a androidboot.vbmeta.device=PARTUUID=a670210c-8754-426c-a5b2-440a72068e31 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3456 androidboot.vbmeta.digest=6f86b17aea6
[    0.008572] Console: colour dummy device 80x25
[    0.012575] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.027545] LSM: Security Framework initializing
[    0.032145] SELinux:  Initializing.
[    0.035678] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.043065] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.052141] ASID allocator initialised with 32768 entries
[    0.056458] rcu: Hierarchical SRCU implementation.
[    0.062537] EFI services will not be available.
[    0.070748] Detected VIPT I-cache on CPU1
[    0.070770] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.070796] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.071291] Detected VIPT I-cache on CPU2
[    0.071306] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.071322] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.071770] Detected VIPT I-cache on CPU3
[    0.071786] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.071801] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.071861] smp: Brought up 1 node, 4 CPUs
[    0.126891] SMP: Total of 4 processors activated.
[    0.131608] CPU features: detected: 32-bit EL0 Support
[    0.136786] CPU features: detected: CRC32 instructions
[    0.150343] CPU: All CPU(s) started at EL2
[    0.154457] alternatives: patching kernel code
[    0.161163] devtmpfs: initialized
[    0.171948] CPU2: update max cpu_capacity 1024
[    0.178462] Initilizing CustomIPI irq domain
[    0.181852] Registered cp15_barrier emulation handler
[    0.186898] Registered setend emulation handler
[    0.191748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.201257] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.230326] pinctrl core: initialized pinctrl subsystem
[    0.233494] DMI not present or invalid.
[    0.236946] NET: Registered protocol family 16
[    0.241705] schedtune: configured to support 5 boost groups
[    0.253909] DMA: preallocated 256 KiB pool for atomic allocations
[    0.257210] audit: initializing netlink subsys (disabled)
[    0.262826] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.270413] cpuidle: using governor menu
[    0.275007] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.282273] Serial: AMBA PL011 UART driver
[    0.285327] imx mu driver is registered.
[    0.289209] imx rpmsg driver is registered.
[    0.330552] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.354998] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.358882] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.365610] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.372351] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.380069] cryptd: max_cpu_qlen set to 1000
[    0.386706] ACPI: Interpreter disabled.
[    0.389562] iommu: Default domain type: Translated
[    0.392773] vgaarb: loaded
[    0.395630] SCSI subsystem initialized
[    0.399402] usbcore: registered new interface driver usbfs
[    0.404626] usbcore: registered new interface driver hub
[    0.410157] usbcore: registered new device driver usb
[    0.416056] mc: Linux media interface: v0.10
[    0.419305] videodev: Linux video capture interface: v2.00
[    0.424850] pps_core: LinuxPPS API ver. 1 registered
[    0.429781] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
[    0.438979] PTP clock support registered
[    0.443266] trusty trusty: trusty version: Built: 12:16:06 Nov 19 2020
[    0.449481] trusty trusty: selected api version: 3 (requested 3)
[    0.461975] EDAC MC: Ver: 3.0.0
[    0.463348] FPGA manager framework
[    0.465802] Advanced Linux Sound Architecture Driver Initialized.
[    0.472177] Bluetooth: Core ver 2.22
[    0.475398] NET: Registered protocol family 31
[    0.479853] Bluetooth: HCI device and connection manager initialized
[    0.486240] Bluetooth: HCI socket layer initialized
[    0.491140] Bluetooth: L2CAP socket layer initialized
[    0.496213] Bluetooth: SCO socket layer initialized
[    0.502473] clocksource: Switched to clocksource arch_sys_counter
[    0.581760] VFS: Disk quotas dquot_6.6.0
[    0.582890] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.589906] pnp: PnP ACPI: disabled
[    0.599523] thermal_sys: Registered thermal governor 'step_wise'
[    0.599527] thermal_sys: Registered thermal governor 'power_allocator'
[    0.603101] NET: Registered protocol family 2
[    0.614092] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.622278] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.630391] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    0.638013] TCP: Hash tables configured (established 32768 bind 32768)
[    0.644197] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.650910] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.658183] NET: Registered protocol family 1
[    0.662794] PCI: CLS 0 bytes, default 64
[    0.666544] Trying to unpack rootfs image as initramfs...
[    0.968860] Freeing initrd memory: 7096K
[    0.971029] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.978177] kvm [1]: IPA Size Limit: 40bits
[    0.982797] kvm [1]: GICv3: no GICV resource entry
[    0.986748] kvm [1]: disabling GICv2 emulation
[    0.991201] kvm [1]: GIC system register CPU interface enabled
[    0.997133] kvm [1]: vgic interrupt IRQ1
[    1.001111] kvm [1]: Hyp mode initialized successfully
[    1.009394] Initialise system trusted keyrings
[    1.011102] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.023604] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.026737] Registering sdcardfs 0.1
[    1.030372] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.036685] fuse: init (API version 7.31)
[    1.040636] 9p: Installing v9fs 9p2000 file system support
[    1.060571] Key type asymmetric registered
[    1.061815] Asymmetric key parser 'x509' registered
[    1.066755] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.074159] io scheduler mq-deadline registered
[    1.078713] io scheduler kyber registered
[    1.085722] /ubuntu20/imx8_data/imx8_an10/android_build/vendor/nxp-opensource/kernel_imx/drivers/gpio/dido.c dido_get_of_properties() line 65, cannot get device_node
[    1.108788] i.MX8MP clock driver probe done
[    1.114677] imx-sdma 30bd0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[    1.120214] mxs-dma 33000000.dma-apbh: initialized
[    1.122338] imx-sdma 30bd0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[    1.128691] Bus freq driver module loaded
[    1.145031] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.150879] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 28, base_baud = 5000000) is a IMX
[    1.157844] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 29, base_baud = 5000000) is a IMX
[    1.166555] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 30, base_baud = 1500000) is a IMX
[    1.175023] printk: console [ttymxc1] enabled
[    1.183706] printk: bootconsole [ec_imx6q0] disabled
[    1.214047] brd: module loaded
[    1.223859] loop: module loaded
[    1.227381] zram: Added device: zram0
[    1.244283] imx ahci driver is registered.
[    1.252219] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
[    1.259130] spi-nor: probe of spi0.0 failed with error -2
[    1.266262] libphy: Fixed MDIO Bus: probed
[    1.271224] tun: Universal TUN/TAP device driver, 1.6
[    1.277448] thunder_xcv, ver 1.0
[    1.280720] thunder_bgx, ver 1.0
[    1.283992] nicpf, ver 1.0
[    1.288493] hclge is initializing
[    1.291822] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.299048] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.304400] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.311457] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.317246] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.323083] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.329075] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.336049] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.341660] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.349497] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.355640] sky2: driver version 1.30
[    1.360226] PPP generic driver version 2.4.2
[    1.364657] PPP BSD Compression module registered
[    1.369372] PPP Deflate Compression module registered
[    1.374450] PPP MPPE Compression module registered
[    1.379250] NET: Registered protocol family 24
[    1.383697] PPTP driver version 0.8.5
[    1.387587] usbcore: registered new interface driver r8152
[    1.393116] usbcore: registered new interface driver asix
[    1.398569] usbcore: registered new interface driver ax88179_178a
[    1.404697] usbcore: registered new interface driver cdc_ether
[    1.410567] usbcore: registered new interface driver net1080
[    1.416266] usbcore: registered new interface driver cdc_subset
[    1.422228] usbcore: registered new interface driver zaurus
[    1.427847] usbcore: registered new interface driver cdc_ncm
[    1.433690] VFIO - User Level meta-driver version: 0.3
[    1.443948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.450523] ehci-pci: EHCI PCI platform driver
[    1.455026] ehci-platform: EHCI generic platform driver
[    1.460530] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.466725] ohci-pci: OHCI PCI platform driver
[    1.471217] ohci-platform: OHCI generic platform driver
[    1.477425] usbcore: registered new interface driver uas
[    1.482795] usbcore: registered new interface driver usb-storage
[    1.488880] usbcore: registered new interface driver usbserial_generic
[    1.495435] usbserial: USB Serial support registered for generic
[    1.501487] usbcore: registered new interface driver ftdi_sio
[    1.507259] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.514605] usbcore: registered new interface driver usb_serial_simple
[    1.521158] usbserial: USB Serial support registered for carelink
[    1.527273] usbserial: USB Serial support registered for zio
[    1.532954] usbserial: USB Serial support registered for funsoft
[    1.538985] usbserial: USB Serial support registered for flashloader
[    1.545364] usbserial: USB Serial support registered for google
[    1.551306] usbserial: USB Serial support registered for libtransistor
[    1.557859] usbserial: USB Serial support registered for vivopay
[    1.563890] usbserial: USB Serial support registered for moto_modem
[    1.570178] usbserial: USB Serial support registered for motorola_tetra
[    1.576814] usbserial: USB Serial support registered for novatel_gps
[    1.583185] usbserial: USB Serial support registered for hp4x
[    1.588954] usbserial: USB Serial support registered for suunto
[    1.594898] usbserial: USB Serial support registered for siemens_mpi
[    1.601294] usbcore: registered new interface driver usb_ehset_test
[    1.610921] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[    1.624304] usbcore: registered new interface driver xpad
[    1.629762] usbcore: registered new interface driver usb_acecad
[    1.635721] usbcore: registered new interface driver aiptek
[    1.641330] usbcore: registered new interface driver gtco
[    1.646767] usbcore: registered new interface driver hanwang
[    1.652467] usbcore: registered new interface driver kbtab
[    1.659881] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[    1.666103] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    1.675320] i2c /dev entries driver
[    1.680139] uvcvideo: Unable to create debugfs directory
[    1.685501] usbcore: registered new interface driver uvcvideo
[    1.691258] USB Video Class driver (1.1.1)
[    1.696261] __power_supply_register: Expected proper parent device for 'battery'
[    1.704023] __power_supply_register: Expected proper parent device for 'usb'
[    1.719391] trusty-virtio trusty:trusty-virtio: initializing
[    1.725244] trusty_ipc virtio0: vring0: va(pa)  (____ptrval____)(0) qsz 32 notifyid 1
[    1.733105] trusty_ipc virtio0: vring1: va(pa)  (____ptrval____)(0) qsz 32 notifyid 2
[    1.741162] trusty-virtio trusty:trusty-virtio: initializing done
[    1.741297] trusty_ipc virtio0: is online
[    1.748265] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0)
[    1.758108] device-mapper: uevent: version 1.0.3
[    1.762979] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: [email protected]
[    1.771659] Bluetooth: HCI UART driver ver 2.3
[    1.776122] Bluetooth: HCI UART protocol H4 registered
[    1.781269] Bluetooth: HCI UART protocol BCSP registered
[    1.786614] Bluetooth: HCI UART protocol LL registered
[    1.791760] Bluetooth: HCI UART protocol ATH3K registered
[    1.797185] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.803657] Bluetooth: HCI UART protocol Broadcom registered
[    1.809341] Bluetooth: HCI UART protocol QCA registered
[    1.814878] EDAC MC: ECC not enabled
[    1.821131] sdhci: Secure Digital Host Controller Interface driver
[    1.827337] sdhci: Copyright(c) Pierre Ossman
[    1.831984] Synopsys Designware Multimedia Card Interface Driver
[    1.838884] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.845231] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    1.857594] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    1.864741] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    1.877442] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    1.885297] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    1.924707] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    1.935293] ledtrig-cpu: registered to indicate activity on CPUs
[    1.942052] hidraw: raw HID events driver (C) Jiri Kosina
[    1.950140] usbcore: registered new interface driver usbhid
[    1.955731] usbhid: USB HID core driver
[    1.961117] mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
[    1.968481] mxc-mipi-csi2-sam 32e40000.csi: 32e40000.csi supply mipi-phy not found, using dummy regulator
[    1.978376] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 500000000
[    1.990351] ashmem: initialized
[    1.997949] optee: probing for conduit method from DT.
[    2.003122] optee: api uid mismatch
[    2.008786] Galcore version 6.4.3.p1.305572
[    2.055455] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    2.062951] mmcblk2: mmc2:0001 AKL11X 115 GiB
[    2.067666] mmcblk2boot0: mmc2:0001 AKL11X partition 1 4.00 MiB
[    2.073836] mmcblk2boot1: mmc2:0001 AKL11X partition 2 4.00 MiB
[    2.080685] mmcblk2rpmb: mmc2:0001 AKL11X partition 3 4.00 MiB, chardev (236:0)
[    2.093403] Alternate GPT is invalid, using primary GPT.
[    2.098799]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[    2.120362] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
[    2.130834] usbcore: registered new interface driver snd-usb-audio
[    2.139047] OF: /sound-bt-sco/simple-audio-card,cpu: could not get #sound-dai-cells for /soc@0/bus@30c00000/spba-bus@30c00000/sai@30c20000
[    2.151502] asoc-simple-card sound-bt-sco: parse error -22
[    2.157006] asoc-simple-card: probe of sound-bt-sco failed with error -22
[    2.169543] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    2.176958] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    2.184216] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    2.191366] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    2.198239] imx-xcvr sound-xcvr: ASoC: failed to init link XCVR PCM: -517
[    2.205040] imx-xcvr sound-xcvr: snd_soc_register_card failed: -517
[    2.211425] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.221559] drop_monitor: Initializing network drop monitor service
[    2.227921] NET: Registered protocol family 26
[    2.232386] netem: version 1.3
[    2.235459] u32 classifier
[    2.238166]     input device check on
[    2.241834]     Actions configured
[    2.245894] xt_time: kernel timezone is -0000
[    2.250369] gre: GRE over IPv4 demultiplexor driver
[    2.255256] IPv4 over IPsec tunneling driver
[    2.260056] Initializing XFRM netlink socket
[    2.264358] IPsec XFRM device driver
[    2.268398] NET: Registered protocol family 10
[    2.273902] Segment Routing with IPv6
[    2.277657] mip6: Mobile IPv6
[    2.281532] NET: Registered protocol family 17
[    2.286005] NET: Registered protocol family 15
[    2.290912] Bluetooth: RFCOMM TTY layer initialized
[    2.295807] Bluetooth: RFCOMM socket layer initialized
[    2.300956] Bluetooth: RFCOMM ver 1.11
[    2.304719] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.310036] Bluetooth: BNEP filters: protocol multicast
[    2.315270] Bluetooth: BNEP socket layer initialized
[    2.320245] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.326191] Bluetooth: HIDP socket layer initialized
[    2.331192] l2tp_core: L2TP core driver, V2.0
[    2.335565] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.340362] 8021q: 802.1Q VLAN Support v1.8
[    2.344574] lib80211: common routines for IEEE802.11 drivers
[    2.350654] 9pnet: Installing 9P2000 support
[    2.354962] tsn generic netlink module v1 init...
[    2.360756] registered taskstats version 1
[    2.364872] Loading compiled-in X.509 certificates
[    2.369791] Key type ._fscrypt registered
[    2.373811] Key type .fscrypt registered
[    2.377742] Key type fscrypt-provisioning registered
[    2.387356] i2c i2c-0: IMX I2C adapter registered
[    2.393083] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator
[    2.400481] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator
[    2.407832] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator
[    2.415162] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator
[    2.422575] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator
[    2.429923] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator
[    2.438658] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e60000' disabled
[    2.446987] i2c i2c-1: IMX I2C adapter registered
[    2.452859] pca953x 2-0020: using no AI
[    2.457041] pca953x 2-0020: failed writing register
[    2.464232] nvmem pcf85063_nvram0: nvmem: invalid reg on /soc@0/bus@30800000/i2c@30a40000/rtc@51/clock
[    2.475722] rtc rtc1: Power loss detected, invalid time
[    2.481668] rtc-pcf85063 2-0051: registered as rtc1
[    2.486611] i2c i2c-2: IMX I2C adapter registered
[    2.492243] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SD1_CLK already requested by 30860000.serial; cannot claim for 30b40000.mmc
[    2.504608] imx8mp-pinctrl 30330000.pinctrl: pin-35 (30b40000.mmc) status -22
[    2.511760] imx8mp-pinctrl 30330000.pinctrl: could not request pin 35 (MX8MP_IOMUXC_SD1_CLK) from group usdhc1grp  on device 30330000.pinctrl
[    2.524464] sdhci-esdhc-imx 30b40000.mmc: Error applying setting, reverse things back
[    2.532338] sdhci-esdhc-imx: probe of 30b40000.mmc failed with error -22
[    2.540344] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    2.546330] imx-dwmac 30bf0000.ethernet: no reset control found
[    2.552775] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    2.559581] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    2.564388] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[    2.571534] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[    2.578679] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    2.585385] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    2.591518] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.599191] imx-dwmac 30bf0000.ethernet: device MAC address e6:c8:4a:db:83:6d
[    2.606338] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    2.612708] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    2.620431] libphy: stmmac: probed
[    2.624079] mdio_bus stmmac-1: MDIO device at address 1 is missing.
[    2.646673] imx8mq-usb-phy 381f0040.usb-phy: 381f0040.usb-phy supply vbus not found, using dummy regulator
[    2.656589] imx8mq-usb-phy 382f0040.usb-phy: 382f0040.usb-phy supply vbus not found, using dummy regulator
[    2.667021] pwm-backlight lvds_backlight: aaaaaaaaaaaaaaaaaaaaaa
[    2.673050] pwm-backlight lvds_backlight: bbbbbbbbbbbbbbbbbbbbbbb
[    2.679156] pwm-backlight lvds_backlight: cccccccccccccccccccccccc
[    2.685345] pwm-backlight lvds_backlight: dddddddddddddddddddddd
[    2.691385] pwm-backlight lvds_backlight: eeeeeeeeeeeeeeeeeeee
[    2.697234] pwm-backlight lvds_backlight: lvds_backlight supply power not found, using dummy regulator
[    2.706611] pwm-backlight lvds_backlight: gggggggggggggggggggggg
[    2.712686] pwm-backlight lvds_backlight: hhhhhhhhhhhhhhhhhhhhhhh
[    2.718791] pwm-backlight lvds_backlight: iiiiiiiiiiiiiiiiiiiiiii
[    2.724894] pwm-backlight lvds_backlight: jjjjjjjjjjjjjjjjjjjjj
[    2.730835] pwm-backlight lvds_backlight: kkkkkkkkkkkkkkkkkkkkk
[    2.736819] pwm-backlight lvds_backlight: llllllllllllllllll
[    2.749185] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.755846] [drm] No driver support for vblank timestamp query.
[    2.761849] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    2.769812] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    2.777777] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    2.785795] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    2.792804] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    2.801080] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    2.808753] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    2.820444] panel-lvds lvds0_panel: 11111111111111 width-mm DT property
[    2.827103] panel-lvds lvds0_panel: 22222222222 width-mm DT property
[    2.833481] panel-lvds lvds0_panel: 333333333333 width-mm DT property
[    2.839956] panel-lvds lvds0_panel: 44444444444 width-mm DT property
[    2.846331] panel-lvds lvds0_panel: 55555555555555 width-mm DT property
[    2.852978] panel-lvds lvds0_panel: 6666666666666 width-mm DT property
[    2.860119] OF: graph: no port node found in /usb-phy@381f0040
[    2.866780] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.872297] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[    2.880315] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000002001810010
[    2.889753] xhci-hcd xhci-hcd.1.auto: irq 70, io mem 0x38200000
[    2.895825] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    2.904100] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.911333] usb usb1: Product: xHCI Host Controller
[    2.916217] usb usb1: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.921624] usb usb1: SerialNumber: xhci-hcd.1.auto
[    2.927206] hub 1-0:1.0: USB hub found
[    2.931002] hub 1-0:1.0: 1 port detected
[    2.935166] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.940672] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[    2.948341] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.954954] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.963154] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    2.971428] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.978660] usb usb2: Product: xHCI Host Controller
[    2.983548] usb usb2: Manufacturer: Linux 5.4.70 xhci-hcd
[    2.988960] usb usb2: SerialNumber: xhci-hcd.1.auto
[    2.994495] hub 2-0:1.0: USB hub found
[    2.998272] hub 2-0:1.0: 1 port detected
[    3.002762] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[    3.012521] imx-micfil sound-micfil: ASoC: failed to init link micfil hifi: -517
[    3.019936] imx-micfil sound-micfil: snd_soc_register_card failed (-517)
[    3.027248] imx-cdnhdmi sound-hdmi: ASoC: failed to init link imx8 hdmi: -517
[    3.034399] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    3.041709] imx-xcvr sound-xcvr: snd-soc-dummy-dai <-> 30cc0000.xcvr mapping ok
[    3.049041] imx-xcvr sound-xcvr: ASoC: no DMI vendor name!
[    3.056399] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_ECSPI2_MOSI already requested by 30280000.watchdog; cannot claim for 30830000.spi
[    3.069306] imx8mp-pinctrl 30330000.pinctrl: pin-125 (30830000.spi) status -22
[    3.076542] imx8mp-pinctrl 30330000.pinctrl: could not request pin 125 (MX8MP_IOMUXC_ECSPI2_MOSI) from group ecspi2grp  on device 30330000.pinctrl
[    3.089677] spi_imx 30830000.spi: Error applying setting, reverse things back
[    3.096833] spi_imx: probe of 30830000.spi failed with error -22
[    3.104008] pca9450 0-0025: Device ID=0x31
[    3.108122] pca9450 0-0025: gpio_intr = 3
[    3.112145] pca9450 0-0025: chip_irq=75
[    3.146015] random: fast init done
[    3.150358] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_GPIO1_IO15 already requested by 30670000.pwm; cannot claim for 1-003c
[    3.162202] imx8mp-pinctrl 30330000.pinctrl: pin-20 (1-003c) status -22
[    3.168830] imx8mp-pinctrl 30330000.pinctrl: could not request pin 20 (MX8MP_IOMUXC_GPIO1_IO15) from group csi_mclk_grp  on device 30330000.pinctrl
[    3.182072] ov5640 1-003c: Error applying setting, reverse things back
[    3.188620] ov5640: probe of 1-003c failed with error -22
[    3.197068] wm8960 2-0034: Failed to issue reset
[    3.204584] rpmsg-audio-codec-wm8960 2-0034: Failed to issue reset
[    3.211913] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[    3.247183] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    3.260582] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 46
[    3.265841] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 47
[    3.270802] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    3.271089] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 48
[    3.282891] fsl-micfil-dai 30ca0000.micfil: GET IRQ: 49
[    3.291199] imx6q-pcie 33800000.pcie: 33800000.pcie supply epdev_on not found, using dummy regulator
[    3.291234] reg-fixed-voltage regulator-usb4-vbus: nonexclusive access to GPIO for regulator-usb4-vbus
[    3.300617] imx6q-pcie 33800000.pcie: EXT REF_CLK is used!.
[    3.309860] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb3-vbus
[    3.315838] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked.
[    3.328757] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb3-vbus) status -22
[    3.342858] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.355642] reg-fixed-voltage regulator-usb3-vbus: Error applying setting, reverse things back
[    3.364271] reg-fixed-voltage: probe of regulator-usb3-vbus failed with error -22
[    3.372454] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb2-vbus
[    3.383918] pcie phy pipe clk is not ready
[    3.385952] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb2-vbus) status -22
[    3.390031] phy phy-32f00000.pcie-phy.5: phy init failed --> -110
[    3.390036] imx6q-pcie 33800000.pcie: Waiting for PHY PLL ready timeout!
[    3.397889] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.423465] reg-fixed-voltage regulator-usb2-vbus: Error applying setting, reverse things back
[    3.424486] imx6q-pcie 33800000.pcie: PCIe PLL lock timeout
[    3.432107] reg-fixed-voltage: probe of regulator-usb2-vbus failed with error -22
[    3.437706] imx6q-pcie 33800000.pcie: host bridge /pcie@33800000 ranges:
[    3.445800] imx8mp-pinctrl 30330000.pinctrl: pin MX8MP_IOMUXC_SAI2_RXD0 already requested by regulator-usb4-vbus; cannot claim for regulator-usb1-vbus
[    3.451851] imx6q-pcie 33800000.pcie:   No bus range found for /pcie@33800000, using [bus 00-ff]
[    3.451870] imx6q-pcie 33800000.pcie:    IO 0x1ff80000..0x1ff8ffff -> 0x00000000
[    3.465372] imx8mp-pinctrl 30330000.pinctrl: pin-105 (regulator-usb1-vbus) status -22
[    3.474158] imx6q-pcie 33800000.pcie:   MEM 0x18000000..0x1fefffff -> 0x18000000
[    3.474451] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.474459] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.481549] imx8mp-pinctrl 30330000.pinctrl: could not request pin 105 (MX8MP_IOMUXC_SAI2_RXD0) from group usb1grp  on device 30330000.pinctrl
[    3.524928] reg-fixed-voltage regulator-usb1-vbus: Error applying setting, reverse things back
[    3.533569] reg-fixed-voltage: probe of regulator-usb1-vbus failed with error -22
[    3.541497] hub 1-1:1.0: USB hub found
[    3.544112] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.551912] [drm] No driver support for vblank timestamp query.
[    3.552207] hub 1-1:1.0: 4 ports detected
[    3.557909] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    3.569820] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[    3.577801] imx-drm display-subsystem: bound imx-lcdifv3-crtc.2 (ops lcdifv3_crtc_ops)
[    3.585856] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[    3.592859] imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[    3.601147] imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -19
[    3.608838] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops)
[    3.616772] imx-drm display-subsystem: bound 32c00000.bus:ldb@32ec005c (ops imx8mp_ldb_ops)
[    3.625366] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
[    3.636270] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.646497] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
[    3.654770] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[    3.714197] Console: switching to colour frame buffer device 160x50
[    3.726141] Hot alarm is canceled. GPU3D clock will return to 64/64
[    3.742385] imx-drm display-subsystem: fb0: imx-drmdrmfb frame buffer device
[    3.757814] imx-micfil sound-micfil: snd-soc-dummy-dai <-> 30ca0000.micfil mapping ok
[    3.765684] imx-micfil sound-micfil: ASoC: no DMI vendor name!
[    3.773594] imx-cdnhdmi sound-hdmi: i2s-hifi <-> 30cb0000.aud2htx mapping ok
[    3.780673] imx-cdnhdmi sound-hdmi: ASoC: no DMI vendor name!
[    3.787847] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card2/input1
[    3.800414] isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
[    3.807510] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.819216] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.825875] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.834524] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    3.844672] mx8-img-md: Registered mxc_isi.0.capture as /dev/video1
[    3.851321] unregister ISI channel: mxc_isi.0
[    3.856848] ALSA device list:
[    3.859839]   #0: imx-audio-xcvr
[    3.863093]   #1: imx-audio-micfil
[    3.866503]   #2: audio-hdmi
[    4.483422] imx6q-pcie 33800000.pcie: Phy link never came up
[    4.489122] imx6q-pcie 33800000.pcie: failed to initialize host
[    4.495078] imx6q-pcie 33800000.pcie: unable to add pcie port.
[    4.503316] Freeing unused kernel memory: 4416K
[    4.507936] Run /init as init process
[    4.539282] init: init first stage started!
[    4.543755] init: Switching root to '/first_stage_ramdisk'
[    4.551461] init: Using Android DT directory /proc/device-tree/firmware/android/
[    4.590101] init: [libfs_mgr]Created logical partition system_a on device /dev/block/dm-0
[    4.598440] init: [libfs_mgr]Skipping zero-length logical partition: system_b
[    4.606853] init: [libfs_mgr]Created logical partition vendor_a on device /dev/block/dm-1
[    4.615122] init: [libfs_mgr]Skipping zero-length logical partition: vendor_b
[    4.623959] init: [libfs_mgr]Created logical partition product_a on device /dev/block/dm-2
[    4.632256] init: [libfs_mgr]Skipping zero-length logical partition: product_b
[    4.642553] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[    4.653330] EXT4-fs (mmcblk2p6): warning: mounting unchecked fs, running e2fsck is recommended
[    4.662603] EXT4-fs (mmcblk2p6): mounted filesystem without journal. Opts: discard
[    4.670348] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.681057] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.701152] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.713628] EXT4-fs (dm-3): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.731825] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.745097] EXT4-fs (dm-4): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.757210] device-mapper: verity: sha1 using implementation "sha1-ce"
[    4.771831] EXT4-fs (dm-5): mounted filesystem without journal. Opts: errors=panic,barrier=1,inode_readahead_blks=8
[    4.783872] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.796143] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    4.824474] printk: init: 21 output lines suppressed due to ratelimiting
[    4.845592] random: init: uninitialized urandom read (40 bytes read)
[    4.987323] random: init: uninitialized urandom read (40 bytes read)
[    5.010594] init: Loading SELinux policy
[    5.048657] SELinux:  Permission nlmsg_readpriv in class netlink_route_socket not defined in policy.
[    5.058130] SELinux: the above unknown classes and permissions will be denied
[    5.065335] SELinux:  policy capability network_peer_controls=1
[    5.071258] SELinux:  policy capability open_perms=1
[    5.076250] SELinux:  policy capability extended_socket_class=1
[    5.082178] SELinux:  policy capability always_check_network=0
[    5.088052] SELinux:  policy capability cgroup_seclabel=0
[    5.093472] SELinux:  policy capability nnp_nosuid_transition=1
[    5.181619] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[    5.181619]
[    5.181622] audit: type=1403 audit(13.012:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
[    5.210320] selinux: SELinux: Loaded file_contexts
[    5.210320]
[    5.222363] random: init: uninitialized urandom read (40 bytes read)
[    5.262211] init: init second stage started!
[    5.294525] init: Using Android DT directory /proc/device-tree/firmware/android/
[    5.307148] selinux: SELinux: Loaded file_contexts
[    5.307148]
[    5.313510] init: Running restorecon...
[    5.337875] init: Overriding previous 'ro.' property 'pm.dexopt.boot':'verify' with new value 'quicken'
[    5.349533] init: Couldn't load property file '/product_services/build.prop': open() failed: No such file or directory: No such file or directory
[    5.362648] init: Couldn't load property file '/factory/factory.prop': open() failed: No such file or directory: No such file or directory
[    5.377155] init: Setting product property ro.product.brand to 'Android' (from ro.product.product.brand)
[    5.386703] init: Setting product property ro.product.device to 'evk_8mp' (from ro.product.product.device)
[    5.396406] init: Setting product property ro.product.manufacturer to 'freescale' (from ro.product.product.manufacturer)
[    5.470744] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    5.551985] ueventd: ueventd started!
[    5.559108] selinux: SELinux: Loaded file_contexts
[    5.559108]
[    5.565679] ueventd: Parsing file /ueventd.rc...
[    5.571500] apexd: Bootstrap subcommand detected
[    5.572588] ueventd: Parsing file /vendor/ueventd.rc...
[    5.582424] ueventd: Parsing file /odm/ueventd.rc...
[    5.587529] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
[    5.597399] ueventd: Parsing file /ueventd.freescale.rc...
[    5.602952] ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
[    5.773052] ueventd: firmware: loading 'imx/sdma/sdma-imx7d.bin' for '/devices/platform/soc@0/30800000.bus/30bd0000.dma-controller/firmware/imx!sdma!sdma-imx7d.bin'
[    5.787758] ueventd: firmware: loading 'regulatory.db' for '/devices/platform/regulatory.0/firmware/regulatory.db'
[    5.789442] apexd: wait for '/dev/loop-control' took 191ms
[    5.804387] apexd: Pre-allocated 9 loopback devices
[    5.810451] apexd: Scanning /system/apex for embedded keys
[    5.818133] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[    5.820667] apexd: Scanning /product/apex for embedded keys
[    5.830259] apexd: ... does not exist. Skipping
[    5.834912] apexd: Scanning /system/apex looking for APEX packages.
[    5.841436] apexd: Found /system/apex/com.android.conscrypt.apex
[    5.848043] apexd: Skipped when bootstrapping
[    5.852559] apexd: Found /system/apex/com.android.runtime.debug.apex
[    5.944272] EXT4-fs (loop0): mounted filesystem without journal. Opts: (null)
[    6.033780] EXT4-fs (loop1): mounted filesystem without journal. Opts: (null)
[    6.047251] printk: apexd: 13 output lines suppressed due to ratelimiting
[    6.185804] Registered swp emulation handler
[    6.217701] Console: switching to colour dummy device 80x25
[    6.236828] watchdogd: watchdogd started (interval 10, margin 20)!
[    6.252843] logd.auditd: start
[    6.259590] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.263556] logd.klogd: 6185073500
[    6.271990] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.293012] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.306361] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[    6.319633] usbcore: registered new interface driver rtk_btusb
[    6.377240] vvcam_video: loading out-of-tree module taints kernel.
[    6.384991] enter viv_video_init_module
[    6.397209] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm vold: deleted inode referenced: 16
[    6.434220] zram0: detected capacity change from 0 to 629145600
[    6.434222] enter viv_isp_init_module
[    6.469312] mkswap: Swapspace size: 614396k, UUID=7977a225-d8ae-44c0-856b-35e5f3c7cd0c
[    6.477597] enter viv_dwe_init_module
[    6.502594] Adding 614396k swap on /dev/block/zram0.  Priority:-2 extents:1 across:614396k SS
[    6.594117] type=1400 audit(14.424:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[    9.333839] random: crng init done
[    9.337248] random: 6 urandom warning(s) missed due to ratelimiting
[   11.052162] init: Calling: /system/bin/vdc checkpoint needsCheckpoint
[   11.082738] init: /dev/block/by-name/userdata is not dm device: No such file or directory
[   11.091763] type=1400 audit(14.424:3): avc: denied { search } for comm="android.hardwar" name="/" dev="mmcblk2p6" ino=2 scontext=u:r:hal_bootctl_default:s0 tcontext=u:object_r:metadata_file:s0 tclass=dir permissive=1
[   11.111065] type=1400 audit(18.924:4): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.127099] type=1400 audit(18.924:4): avc: denied { create } for comm="kdevtmpfs" name="dm-6" scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.142897] type=1400 audit(18.924:5): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=2623 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   11.147871] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   11.168067] init: [libfs_mgr]Filesystem on /dev/block/dm-6 was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x10046
[   11.181011] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   11.191665] EXT4-fs (dm-6): recovery complete
[   11.196048] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[   11.206324] init: [libfs_mgr]check_fs(): mount(/dev/block/dm-6,/data,ext4)=0: Success
[   11.224886] init: [libfs_mgr]check_fs(): unmount(/data) succeeded
[   11.231260] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/dm-6
[   12.055154] e2fsck: e2fsck 1.44.4 (18-Aug-2018)
[   12.055154]
[   12.061376] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   12.061376]
[   12.068716] e2fsck: Pass 2: Checking directory structure
[   12.068716]
[   12.075517] e2fsck: Pass 3: Checking directory connectivity
[   12.075517]
[   12.082578] e2fsck: Pass 4: Checking reference counts
[   12.082578]
[   12.089130] e2fsck: Pass 5: Checking group summary information
[   12.089130]
[   12.096455] e2fsck: /dev/block/dm-6: 11/383520 files (0.0% non-contiguous), 43458/1531904 blocks
[   12.096455]
[   12.110022] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/dm-6
[   12.117235] init: [libfs_mgr]Reserved blocks 32768 is too large; capping to 30638
[   12.125742] EXT4-fs (dm-6): Ignoring removed nomblk_io_submit option
[   12.137066] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
[   12.148282] init: [libfs_mgr]__mount(source=/dev/block/dm-6,target=/data,type=ext4)=0: Success
[   12.157755] EXT4-fs error: 11 callbacks suppressed
[   12.157762] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm init: deleted inode referenced: 16
[   12.211235] device-mapper: bow: Switching to state Checkpoint
[   12.687278] init (pid 1) is setting deprecated v1 encryption policy; recommend upgrading to v2.
[   12.736174] fscrypt: AES-256-CTS-CBC using implementation "cts-cbc-aes-ce"
[   12.817697] fscrypt: AES-256-XTS using implementation "xts-aes-ce"
[   12.830521] apexd: Marking APEXd as starting
[   12.836092] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm Binder:215_2: deleted inode referenced: 12
[   12.847794] apexd: Scanning /system/apex for embedded keys
[   12.857712] apexd: Scanning /product/apex for embedded keys
[   12.944911] EXT4-fs (loop2): mounted filesystem without journal. Opts: (null)
[   13.033454] EXT4-fs (loop3): mounted filesystem without journal. Opts: (null)
[   13.101408] EXT4-fs (loop4): mounted filesystem without journal. Opts: (null)
[   13.193804] EXT4-fs (loop5): mounted filesystem without journal. Opts: (null)
[   13.289426] EXT4-fs (loop6): mounted filesystem without journal. Opts: (null)
[   13.372860] EXT4-fs (loop7): mounted filesystem without journal. Opts: (null)
[   13.454231] EXT4-fs (loop8): mounted filesystem without journal. Opts: (null)
[   17.191207] init: Command 'load_persist_props' action=load_persist_props_action (/init.rc:306) took 1382ms and succeeded
[   17.202241] init: Service 'exec 9 (/system/bin/recovery-persist)' (pid 291) exited with status 0
[   17.211551] init: starting service 'logd-reinit'...
[   17.218311] init: processing action (load_persist_props_action) from (/system/etc/init/flags_health_check.rc:1)
[   17.231005] init: Setting policy on /data/server_configurable_flags
[   17.237613] init: Policy for /data/server_configurable_flags set to c5db7d5efd01df3f modes 1/4
[   17.246839] init: starting service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)'...
[   17.259332] init: SVC_EXEC service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)' pid 293 (uid 1000 gid 1000+0 context default) started; waiting...
[   17.275469] logd.daemon: reinit
[   17.278776] init: Service 'logd-reinit' (pid 292) exited with status 0
[   17.867637] init: Service 'exec 10 (/system/bin/flags_health_check BOOT_FAILURE)' (pid 293) exited with status 0 waiting took 0.608000 seconds
[   17.915069] update_verifier: Started with arg 1: nonencrypted
[   17.923696] update_verifier: Booting slot 0: isSlotMarkedSuccessful=0
[   17.930282] update_verifier: /data/ota_package/care_map.pb doesn't exist
[   17.937036] update_verifier: Failed to parse the care map file, skipping verification
[   17.945629] update_verifier: Deferred marking slot 0 as booted successfully.
[   17.952744] update_verifier: Leaving update_verifier.
[   17.997383] type=1400 audit(18.924:5): avc: denied { setattr } for comm="kdevtmpfs" name="dm-6" dev="devtmpfs" ino=2623 scontext=u:r:kernel:s0 tcontext=u:object_r:device:s0 tclass=blk_file permissive=1
[   18.015458] type=1400 audit(25.828:6): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.033953] type=1400 audit(25.828:6): avc: denied { setattr } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.052070] type=1400 audit(25.828:7): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.070346] type=1400 audit(25.828:7): avc: denied { search } for comm="init" name="wifi" dev="dm-6" ino=228503 scontext=u:r:vendor_init:s0 tcontext=u:object_r:wifi_data_file:s0 tclass=dir permissive=1
[   18.088377] type=1400 audit(25.832:8): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=228507 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   18.596543] Mass Storage Function, version: 2009/09/11
[   18.601843] LUN: removable file: (no medium)
[   18.611636] using random self ethernet address
[   18.616182] using random host ethernet address
[   18.622366] file system registered
[   18.908336] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.004762] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.085698] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   19.193446] healthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
[   19.254622] type=1400 audit(25.832:8): avc: denied { setattr } for comm="init" name="dhcp" dev="dm-6" ino=228507 scontext=u:r:vendor_init:s0 tcontext=u:object_r:dhcp_data_file:s0 tclass=dir permissive=1
[   19.283218] init: Setting policy on /data/eGalax
[   19.296075] init: Policy for /data/eGalax set to c5db7d5efd01df3f modes 1/4
[   19.355259] type=1400 audit(27.084:9): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=228487 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
evk_8mp:/ $ [   19.512630] type=1400 audit(27.084:9): avc: denied { setattr } for comm="init" name="bluetooth" dev="dm-6" ino=228487 scontext=u:r:vendor_init:s0 tcontext=u:object_r:bluetooth_data_file:s0 tclass=dir permissive=1
[   19.596086] EXT4-fs error (device mmcblk2p6): ext4_lookup:1789: inode #2: comm gsid: deleted inode referenced: 16
[   19.840037] isi-m2m 32e00000.isi:m2m_device: ISI channel[0] is busy
[   20.246930] read descriptors
[   20.262966] read strings
[   20.618795] EXT4-fs error (device dm-6): ext4_find_dest_de:2030: inode #228492: block 918033: comm Binder:296_3: bad entry in directory: rec_len is smaller than minimal - offset=0, inode=0, rec_len=0, lblk=0, size=4096 fake=1
[   20.620421] printk: Binder:260_2: 99 output lines suppressed due to ratelimiting
[   20.637013] binder: release 318:352 transaction 680 in, still active
[   20.637019] binder: send failed reply for transaction 680 to 334:334
[   20.647166] Aborting journal on device dm-6-8.
[   20.678647] Kernel panic - not syncing: EXT4-fs (device dm-6): panic forced after error
[   20.686666] CPU: 2 PID: 296 Comm: Binder:296_3 Tainted: G           O      5.4.70 #96
[   20.694503] Hardware name: NXP i.MX8MPlus EVK board (DT)
[   20.699829] Call trace:
[   20.702291]  dump_backtrace+0x0/0x134
[   20.705955]  show_stack+0x14/0x1c
[   20.709271]  dump_stack+0xa0/0xd8
[   20.712587]  panic+0x148/0x350
[   20.715642]  __ext4_error_inode+0x0/0x214
[   20.719652]  __ext4_error_inode+0x154/0x214
[   20.723848]  __ext4_check_dir_entry+0x23c/0x284
[   20.728381]  ext4_find_dest_de+0xa8/0x154
[   20.732390]  add_dirent_to_buf+0x9c/0x218
[   20.736397]  ext4_add_entry+0x1fc/0xe60
[   20.740229]  ext4_create+0x104/0x20c
[   20.743804]  path_openat+0x9e0/0xe1c
[   20.747376]  do_filp_open+0x74/0x11c
[   20.750948]  do_sys_open+0x130/0x24c
[   20.754521]  __arm64_sys_openat+0x24/0x2c
[   20.758528]  el0_svc_common+0x98/0x160
[   20.762275]  el0_svc_handler+0x68/0x80
[   20.766021]  el0_svc+0x8/0xc
[   20.768903] SMP: stopping secondary CPUs
[   21.772823] SMP: failed to stop secondary CPUs 0-2
[   21.777611] Kernel Offset: disabled
[   21.781096] CPU features: 0x00010002,2000200c
[   21.785449] Memory Limit: none
[   21.788501] trusty-log panic notifier - trusty version Built: 12:16:06 Nov 19 2020
[   21.788509] Rebooting in 5 seconds..
It will show this log, It seems the emmc problem is here.
Hi @VictorWang129
Based on your logs, it doesn't seem to be an issue with eMMC or DDR.  Please check if your DTS file configuration is correct. What modifications did you make to the code?
B.R
タグ(1)
評価なし
バージョン履歴
最終更新日:
水曜日
更新者:
