2403314_en-US
2403314_en-US
2403314_en-US
dpaa2_net: FS table with 1 entries full
hi creating 1 dpni and dpdmux.
on Port 0 creating 2 RXQ .
Adding rte_flow as below
memset(&udp_spec, 0, sizeof(udp_spec));
memset(&udp_mask, 0, sizeof(udp_mask));
udp_spec.hdr.dst_port = rte_cpu_to_be_16(udp_port);
udp_mask.hdr.dst_port = 0xffff;
pattern[0].type = RTE_FLOW_ITEM_TYPE_UDP;
pattern[0].spec = &udp_spec;
pattern[0].mask = &udp_mask;
pattern[1].type = RTE_FLOW_ITEM_TYPE_END;
action[0].type = RTE_FLOW_ACTION_TYPE_QUEUE;
action[0].conf = &queue;
action[1].type = RTE_FLOW_ACTION_TYPE_END;
struct rte_flow *flow =
rte_flow_create(port_id,
&attr,
pattern,
action,
&error);
Creating 2 flow on port 0 for RXQ 0 and RXQ 1
create_udp_queue_flow(port_id, 5000, 0);
create_udp_queue_flow(port_id, 5001, 1);
Getting below error.
Re: dpaa2_net: FS table with 1 entries full
The logs and restool output tell a clear story. The DPNI object was provisioned with only 1 fs_entry, which gets consumed by the first flow rule (UDP 5000 → RXQ 0). Any subsequent rte_flow_create() call fails immediately because the hardware FS table has no room left.
Port 0 started with 2 RX queues and 7 TX queues UDP port 5000 -> RXQ 0 created dpaa2_net: FS table with 1 entries full dpaa2_net: Failure to create flow, return code (-1) Flow create failed: unknown fslmc: dpaa2_get_qbman_swp(): New Portal 0x17ffebbc0 (2) affined thread - 8602 fslmc: dpaa2_configure_stashing(): Portal= 2 CPU= 1 SDEST= 0 fslmc: DPAA Portal=0x17ffebbc0 (2) is affined for eth rx to thread 8602root@localhost:/home/user# restool dpni info dpni.1 dpni version: 8.2 dpni id: 1 plugged state: plugged endpoint state: 0 endpoint: dpdmux.0.2, link is down link status: 0 - down mac address: ce:8a:4d:82:e7:dc max frame length: 1536 dpni_attr.options value is: 0x80000310 Unrecognized options found... num_queues: 16 num_cgs: 24 num_rx_tcs: 8 num_tx_tcs: 16 mac_entries: 16 vlan_entries: 16 qos_entries: 64 fs_entries: 1 qos_key_size: 56 fs_key_size: 56
10:53 AM
DPAA2 Flow Steering Table Full — Root Cause & Fix
Root Cause
Confirmed by restool:
fs_entries: 1    ← only 1 hardware flow-steering slot
The DPNI was created (either via DPL or restool dpni create) without explicitly setting fs-entries, so it defaulted to 1.
Fix — Recreate the DPNI with More FS Entries
Option 1 — Dynamically via restool (no reflash needed):
# Destroy the existing DPNI
restool dpni destroy dpni.1
# Recreate it with sufficient FS entries (e.g., 16 or 64)
restool dpni create \
  --options=DPNI_OPT_HAS_KEY_MASKING \
  --num-queues=16 \
  --fs-entries=64 \
  --num-rx-traffic-classes=8 \
  --num-tx-traffic-classes=16
# Re-bind to the DPDMUX endpoint
restool dpdmux connect dpdmux.0.2 --endpoint=dpni.X
Replace dpni.X with the newly created ID shown after dpni create.
Option 2 — Edit the DPL (Data Path Layout) file:
Find the dpni@1 object block in your DPL (.dts / .dpl) and increase fs_entries:
dpni@1 {
    compatible = "fsl,dpni";
    fs_entries = <64>;     /* was 1, increase as needed */
Then reload the DPL:
restool dprc load dprc.1
 Your DPNI already has qos_entries: 64 and qos_key_size: 56, so the hardware supports it — only the provisioned FS table size was too small.
Quick Validation After Fix
# Confirm new fs_entries value
restool dpni info dpni. | grep fs_entries
# Expected: fs_entries: 64  (or whatever you set)
Then retry your DPDK application — the Flow create failed error should be gone.
regards
dpni version: 8.2
dpni id: 1
endpoint state: 0
num_queues: 16
num_cgs: 24
num_rx_tcs: 8
num_tx_tcs: 16
mac_entries: 16
vlan_entries: 16
qos_entries: 64
fs_entries: 1
qos_key_size: 56
fs_key_size: 56
./dpdk-multirxq-sample-prog  -l 1-3 -n 1 --log-level=fslmc,8 --huge-dir /dev/hugepages --proc-type=auto -b fslmc:dpio.16 -b fslmc:dpio.17 -b fslmc:dpio.18 -b fslmc:dpio.19 -b fslmc:dpio.20 -b fslmc:dpio.21 -b fslmc:dpio.22 -b fslmc:dpio.23 -b fslmc:dpmcp.38 -b fslmc:dpmcp.39
EAL: Detected 16 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Auto-detected process type: PRIMARY
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.16)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.17)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.18)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.19)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.20)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.21)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.22)
fslmc: rte_fslmc_parse(): Parsing dev=(dpio.23)
fslmc: rte_fslmc_parse(): Parsing dev=(dpmcp.38)
fslmc: rte_fslmc_parse(): Parsing dev=(dpmcp.39)
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
fslmc: fslmc_get_container_group(): Container: dprc.2 has VFIO iommu group id = 11
fslmc: **Devargs matched dpmcp.39
fslmc: **Devargs matched dpio.18
fslmc: **Devargs matched dpio.16
fslmc: Skipping invalid device (power)
fslmc: **Devargs matched dpio.22
fslmc: **Devargs matched dpio.20
fslmc: **Devargs matched dpio.19
fslmc: **Devargs matched dpmcp.38
fslmc: **Devargs matched dpio.17
fslmc: **Devargs matched dpio.23
fslmc: **Devargs matched dpio.21
fslmc: FSLMC Bus scan completed
fslmc: List of devices scanned on bus:
fslmc: dpni.1
fslmc: dpseci.1
fslmc: dpseci.2
fslmc: dpseci.3
fslmc: dpseci.4
fslmc: dpseci.5
fslmc: dpseci.6
fslmc: dpseci.7
fslmc: dpseci.8
fslmc: dpseci.9
fslmc: dpseci.10
fslmc: dpseci.11
fslmc: dpseci.12
fslmc: dpseci.13
fslmc: dpseci.14
fslmc: dpseci.15
fslmc: dpseci.16
fslmc: dpcon.32
fslmc: dpcon.33
fslmc: dpcon.34
fslmc: dpcon.35
fslmc: dpcon.36
fslmc: dpcon.37
fslmc: dpcon.38
fslmc: dpcon.39
fslmc: dpbp.2
fslmc: dpbp.3
fslmc: dpbp.4
fslmc: dpbp.5
fslmc: dpbp.6
fslmc: dpbp.7
fslmc: dpbp.8
fslmc: dpbp.9
fslmc: dpbp.10
fslmc: dpbp.11
fslmc: dpbp.12
fslmc: dpbp.13
fslmc: dpbp.14
fslmc: dpbp.15
fslmc: dpbp.16
fslmc: dpbp.17
fslmc: dpio.16
fslmc: dpio.17
fslmc: dpio.18
fslmc: dpio.19
fslmc: dpio.20
fslmc: dpio.21
fslmc: dpio.22
fslmc: dpio.23
fslmc: dpio.24
fslmc: dpio.25
fslmc: dpio.26
fslmc: dpio.27
fslmc: dpio.28
fslmc: dpio.29
fslmc: dpio.30
fslmc: dpio.31
fslmc: dpci.0
fslmc: dpci.1
fslmc: dpmcp.37
fslmc: dpmcp.38
fslmc: dpmcp.39
fslmc: dpdmai.0
fslmc: dpdmai.1
fslmc: dpdmai.2
fslmc: dpdmai.3
fslmc: dpdmai.4
fslmc: dpdmai.5
fslmc: dpdmai.6
fslmc: dpdmai.7
fslmc: dpdmux.0
fslmc: dprc.2
EAL: Selected IOVA mode 'VA'
EAL: No available hugepages reported in hugepages-2048kB
EAL: No available hugepages reported in hugepages-32768kB
EAL: No available hugepages reported in hugepages-64kB
EAL: Probing VFIO support...
EAL: VFIO support initialized
fslmc: fslmc_vfio_setup_group(): VFIO Container FD is [0x1B]
fslmc: fslmc_map_dma(): --> Map address: 0x140000000, size: 1073741824
fslmc: rte_fslmc_vfio_dmamap(): Installed memory callback handler
fslmc: rte_fslmc_vfio_dmamap(): Total 1 segments found.
fslmc: Unable to map region (errno = 22)
fslmc: dpmcp.38 Blacklisted, skipping
fslmc: dpmcp.39 Blacklisted, skipping
fslmc: Device (dprc.2) abstracted from VFIO
fslmc: Device (dpni.1) abstracted from VFIO
fslmc: Device (dpseci.1) abstracted from VFIO
fslmc: Device (dpseci.2) abstracted from VFIO
fslmc: Device (dpseci.3) abstracted from VFIO
fslmc: Device (dpseci.4) abstracted from VFIO
fslmc: Device (dpseci.5) abstracted from VFIO
fslmc: Device (dpseci.6) abstracted from VFIO
fslmc: Device (dpseci.7) abstracted from VFIO
fslmc: Device (dpseci.8) abstracted from VFIO
fslmc: Device (dpseci.9) abstracted from VFIO
fslmc: Device (dpseci.10) abstracted from VFIO
fslmc: Device (dpseci.11) abstracted from VFIO
fslmc: Device (dpseci.12) abstracted from VFIO
fslmc: Device (dpseci.13) abstracted from VFIO
fslmc: Device (dpseci.14) abstracted from VFIO
fslmc: Device (dpseci.15) abstracted from VFIO
fslmc: Device (dpseci.16) abstracted from VFIO
fslmc: Device (dpcon.32) abstracted from VFIO
fslmc: Device (dpcon.33) abstracted from VFIO
fslmc: Device (dpcon.34) abstracted from VFIO
fslmc: Device (dpcon.35) abstracted from VFIO
fslmc: Device (dpcon.36) abstracted from VFIO
fslmc: Device (dpcon.37) abstracted from VFIO
fslmc: Device (dpcon.38) abstracted from VFIO
fslmc: Device (dpcon.39) abstracted from VFIO
fslmc: Device (dpbp.2) abstracted from VFIO
fslmc: Device (dpbp.3) abstracted from VFIO
fslmc: Device (dpbp.4) abstracted from VFIO
fslmc: Device (dpbp.5) abstracted from VFIO
fslmc: Device (dpbp.6) abstracted from VFIO
fslmc: Device (dpbp.7) abstracted from VFIO
fslmc: Device (dpbp.8) abstracted from VFIO
fslmc: Device (dpbp.9) abstracted from VFIO
fslmc: Device (dpbp.10) abstracted from VFIO
fslmc: Device (dpbp.11) abstracted from VFIO
fslmc: Device (dpbp.12) abstracted from VFIO
fslmc: Device (dpbp.13) abstracted from VFIO
fslmc: Device (dpbp.14) abstracted from VFIO
fslmc: Device (dpbp.15) abstracted from VFIO
fslmc: Device (dpbp.16) abstracted from VFIO
fslmc: Device (dpbp.17) abstracted from VFIO
fslmc: dpio.16 Blacklisted, skipping
fslmc: dpio.17 Blacklisted, skipping
fslmc: dpio.18 Blacklisted, skipping
fslmc: dpio.19 Blacklisted, skipping
fslmc: dpio.20 Blacklisted, skipping
fslmc: dpio.21 Blacklisted, skipping
fslmc: dpio.22 Blacklisted, skipping
fslmc: dpio.23 Blacklisted, skipping
fslmc: dpaa2_create_dpio_device(): LX2160 Platform Detected
fslmc: Device (dpio.24) abstracted from VFIO
fslmc: Device (dpio.25) abstracted from VFIO
fslmc: Device (dpio.26) abstracted from VFIO
fslmc: Device (dpio.27) abstracted from VFIO
fslmc: Device (dpio.28) abstracted from VFIO
fslmc: Device (dpio.29) abstracted from VFIO
fslmc: Device (dpio.30) abstracted from VFIO
fslmc: Device (dpio.31) abstracted from VFIO
fslmc: Device (dpci.0) abstracted from VFIO
fslmc: Device (dpci.1) abstracted from VFIO
fslmc: Device (dpdmai.0) abstracted from VFIO
fslmc: Device (dpdmai.1) abstracted from VFIO
fslmc: Device (dpdmai.2) abstracted from VFIO
fslmc: Device (dpdmai.3) abstracted from VFIO
fslmc: Device (dpdmai.4) abstracted from VFIO
fslmc: Device (dpdmai.5) abstracted from VFIO
fslmc: Device (dpdmai.6) abstracted from VFIO
fslmc: Device (dpdmai.7) abstracted from VFIO
fslmc: Device (dpdmux.0) abstracted from VFIO
PMD: dpni.1: netdev created, connected to dpdmux.0
fslmc: dpaa2_get_qbman_swp(): New Portal 0x17fff3280 (1) affined thread - 8602
fslmc: dpaa2_configure_stashing(): Portal= 1 CPU= 1 SDEST= 0
fslmc: DPAA Portal=0x17fff3280 (1) is affined to thread 8602
タグ(1)
評価なし
バージョン履歴
最終更新日:
火曜日
更新者:
