Hi NXP team,
I'm working on a custom board based on the i.MX95 (MIMX9596, 19x19 package, LPDDR5), using the PPF0900AMBA1ES PMIC.
Could you please confirm:
1.Does this part number ship with OTP already programmed, or is it a non-programmed engineering sample?
2.If it is non-programmed, what is the recommended procedure to program (or emulate) the OTP configuration for bring-up and evaluation purposes?
3.Is a reference OTP configuration file (.CFG) available for an i.MX95 + LPDDR5 (19x19) implementation that we could use as a starting point?
For context, our schematic closely follows the i.MX95 EVK reference design (PF09 + PF5301 + PF5302), and we're currently doing initial power-on bring-up.
Thank you.
