2402801_en-US
2402801_en-US
2402801_en-US
I.MX93 - UUU emmc/sdcard LIBUSB_ERROR_TIMEOUT Error
Hi NXP Team,
We are trying to flash an i.MX93 board using a .wic image file provided by our team. We have two i.MX93 boards with the same hardware revision (SCH-96411 REV_B2).
On one board, we are able to successfully flash the .wic image. However, when attempting to flash the same image on the second board, we encounter an error.
We have tested both:
  • emmc_all (for eMMC flashing)
  • sd_all (using an SD card)
    In both cases, the same issue occurs on the second board.
We would appreciate your support in troubleshooting and resolving this issue. Please let us know if you need any additional logs, error messages, or board information.
Providing both uuu command and debugProviding both uuu command and debugProviding both uuu command and debuguuu supported listuuu supported listuuu supported listi.mx93 usb identifiedi.mx93 usb identifiedi.mx93 usb identified
Re: I.MX93 - UUU emmc/sdcard LIBUSB_ERROR_TIMEOUT Error
Thank you for your interest in NXP Semiconductor products,
It's good to have schematic identification, I would recommend confirming i.MX 93 top marking though. Confirm that they share TOP marking.
Please download latest prebuilt image release from Linux.
Finally, you are trying to flash both of them in serial download and do they have any fuses blown?
タグ(1)
評価なし
バージョン履歴
最終更新日:
昨日
更新者:
