Exporting S32CT .mex configuration to EB TresosHello NXP support,
is there a way to export/transform an S32CT configuration .mex file into something that can be read/imported/consumed by EB TRESOS? I need to switch to EB tresos without manually transferring every configuration item.
I have attached an example .mex file from my projects as references.
Re: Exporting S32CT .mex configuration to EB TresosHello @DirkEtzler
Unfortunately, there is no automatic conversion tool or plugin to migrate S32DS (.mex) configurations into EB tresos (.arxml) format.
S32 Configuration Tools use the .mex format, while EB Tresos follows the .arxml AUTOSAR standard and differs significantly in schema and constraints.
The recommended approach is to recreate the configuration in EB tresos manually, using the .mex configuration and generated driver code as a reference. You can follow the RTD MCAL Based in Tresos Training for some guidance.
In case you come up with any issues during migration, you submit your query and we will be happy to assist.
Julián
Re: Exporting S32CT .mex configuration to EB TresosHello @Julián_AragónM ,
thanks for the quick reply. I will follow the guidelines, and when I hit a roadblock post my question(s).
