2399623_en-US
2399623_en-US
2399623_en-US
NXP S32g399ardb3 build issue
i am trying to build BSP 46 for NXP s32g399ardb3 but i am getting an error. I have attached the error below
Could you please let me know what the issue might be?
abhi@abhi:~/fsl-auto-yocto-bsp$ bitbake fsl-image-auto
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:01
Loaded 5814 entries from dependency cache.
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:01
Parsing of 3705 .bb files complete (3704 cached, 1 parsed). 5817 targets, 626 skipped, 2 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "2.8.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "aarch64-fsl-linux"
MACHINE = "s32g399ardb3"
DISTRO = "fsl-auto"
DISTRO_VERSION = "46.0"
TUNE_FEATURES = "aarch64 crc cortexa53 crypto"
TARGET_FPU = ""
meta
meta-poky
meta-yocto-bsp = "HEAD:ec220ae083dba35c279192b2249ad03fe238446e"
meta-oe
meta-multimedia
meta-python
meta-networking
meta-gnome
meta-filesystems
meta-webserver
meta-perl
meta-xfce = "HEAD:e621da947048842109db1b4fd3917a02e0501aa2"
meta-virtualization = "HEAD:af1db2042caf8021d767dce1b26c08b59b96f3d1"
meta-security = "HEAD:bc865c5276c2ab4031229916e8d7c20148dfbac3"
meta-freescale = "HEAD:62423c69631d7f7cffe2bd20997412d76caa94ef"
meta-rust-bin = "HEAD:63d677de912551b8f5606ce459748532c6ae529d"
meta-alb-bsp
meta-alb-sdk = "HEAD:ff4d84b23d5887aaff3a18043e4322e9ee3fa7ab"
Sstate summary: Wanted 2989 Local 1513 Mirrors 0 Missed 1476 Current 0 (50% match, 0% complete)############################################################################# | ETA: 0:00:00
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:05
NOTE: Executing Tasks
ERROR: base-files-3.0.14-r0 do_package: Error executing a python function in exec_func_python() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_func_python() autogenerated', lineno: 2, function:
0001:
*** 0002:perform_packagecopy(d)
0003:
File: '/home/abhi/fsl-auto-yocto-bsp/sources/poky/meta/classes-global/package.bbclass', lineno: 363, function: perform_packagecopy
0359: rpath_replace (dvar, d)
0360:}
0361:perform_packagecopy[cleandirs] = "${PKGD}"
0362:perform_packagecopy[dirs] = "${PKGD}"
*** 0363:
0364:python populate_packages () {
0365: oe.package.populate_packages(d)
0366:}
0367:populate_packages[dirs] = "${D}"
File: '/usr/lib/python3.10/subprocess.py', lineno: 421, function: check_output
0417: else:
0418: empty = b''
0419: kwargs['input'] = empty
0420:
*** 0421: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
0422: **kwargs).stdout
0423:
0424:
0425:class CompletedProcess(object):
File: '/usr/lib/python3.10/subprocess.py', lineno: 526, function: run
0522: # We don't call process.wait() as .__exit__ does that for us.
0523: raise
0524: retcode = process.poll()
0525: if check and retcode:
*** 0526: raise CalledProcessError(retcode, process.args,
0527: output=stdout, stderr=stderr)
0528: return CompletedProcess(process.args, retcode, stdout, stderr)
0529:
0530:
Exception: subprocess.CalledProcessError: Command 'tar --exclude=./sysroot-only -cf - -C /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/s32g399ardb3-fsl-linux/base-files/3.0.14/image -p -S . | tar -xf - -C /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/s32g399ardb3-fsl-linux/base-files/3.0.14/package' returned non-zero exit status 2.
Subprocess output:
got *at() syscall for unknown directory, fd 4
unknown base path for fd 4, path hostname
couldn't allocate absolute path for 'hostname'.
tar: ./etc/hostname: Cannot open: Bad address
unknown base path for fd 4, path skel
couldn't allocate absolute path for 'skel'.
tar: ./etc/skel: Cannot mkdir: Bad address
tar: ./etc/skel/.profile: Cannot open: No such file or directory
tar: ./etc/skel/.bashrc: Cannot open: No such file or directory
unknown base path for fd 4, path host.conf
couldn't allocate absolute path for 'host.conf'.
tar: ./etc/host.conf: Cannot open: Bad address
unknown base path for fd 4, path nsswitch.conf
couldn't allocate absolute path for 'nsswitch.conf'.
tar: ./etc/nsswitch.conf: Cannot open: Bad address
unknown base path for fd 4, path hosts
couldn't allocate absolute path for 'hosts'.
tar: ./etc/hosts: Cannot open: Bad address
unknown base path for fd 4, path shells
couldn't allocate absolute path for 'shells'.
tar: ./etc/shells: Cannot open: Bad address
unknown base path for fd 4, path issue
couldn't allocate absolute path for 'issue'.
tar: ./etc/issue: Cannot open: Bad address
unknown base path for fd 4, path mtab
couldn't allocate absolute path for 'mtab'.
tar: ./etc/mtab: Cannot open: Bad address
unknown base path for fd 4, path default
couldn't allocate absolute path for 'default'.
tar: ./etc/default: Cannot mkdir: Bad address
unknown base path for fd 4, path motd
couldn't allocate absolute path for 'motd'.
tar: ./etc/motd: Cannot open: Bad address
unknown base path for fd 4, path issue.net
couldn't allocate absolute path for 'issue.net'.
tar: ./etc/issue.net: Cannot open: Bad address
unknown base path for fd 4, path profile
couldn't allocate absolute path for 'profile'.
tar: ./etc/profile: Cannot open: Bad address
unknown base path for fd 4, path fstab
couldn't allocate absolute path for 'fstab'.
tar: ./etc/fstab: Cannot open: Bad address
unknown base path for fd 4, path lib
couldn't allocate absolute path for 'lib'.
tar: ./var/lib: Cannot mkdir: Bad address
tar: ./var/lib/misc: Cannot mkdir: No such file or directory
unknown base path for fd 4, path log
couldn't allocate absolute path for 'log'.
tar: ./var/log: Cannot create symlink to ‘volatile/log’: Bad address
unknown base path for fd 4, path lock
couldn't allocate absolute path for 'lock'.
tar: ./var/lock: Cannot open: Bad address
unknown base path for fd 4, path run
couldn't allocate absolute path for 'run'.
tar: ./var/run: Cannot open: Bad address
unknown base path for fd 4, path backups
couldn't allocate absolute path for 'backups'.
tar: ./var/backups: Cannot mkdir: Bad address
unknown base path for fd 4, path local
couldn't allocate absolute path for 'local'.
tar: ./var/local: Cannot mkdir: Bad address
unknown base path for fd 4, path tmp
couldn't allocate absolute path for 'tmp'.
tar: ./var/tmp: Cannot create symlink to ‘volatile/tmp’: Bad address
unknown base path for fd 4, path volatile
couldn't allocate absolute path for 'volatile'.
tar: ./var/volatile: Cannot mkdir: Bad address
tar: ./var/volatile/log: Cannot mkdir: No such file or directory
tar: ./var/volatile/tmp: Cannot mkdir: No such file or directory
unknown base path for fd 4, path spool
couldn't allocate absolute path for 'spool'.
tar: ./var/spool: Cannot mkdir: Bad address
unknown base path for fd 4, path bin
couldn't allocate absolute path for 'bin'.
tar: ./usr/bin: Cannot mkdir: Bad address
unknown base path for fd 4, path include
couldn't allocate absolute path for 'include'.
tar: ./usr/include: Cannot mkdir: Bad address
tar: ./usr/lib: Cannot mkdir: Bad address
unknown base path for fd 4, path sbin
couldn't allocate absolute path for 'sbin'.
tar: ./usr/sbin: Cannot mkdir: Bad address
unknown base path for fd 4, path games
couldn't allocate absolute path for 'games'.
tar: ./usr/games: Cannot mkdir: Bad address
unknown base path for fd 4, path share
couldn't allocate absolute path for 'share'.
tar: ./usr/share: Cannot mkdir: Bad address
tar: ./usr/share/dict: Cannot mkdir: No such file or directory
tar: ./usr/share/misc: Cannot mkdir: No such file or directory
tar: ./usr/share/doc: Cannot mkdir: No such file or directory
tar: ./usr/share/doc/base-files-3.0.14: Cannot mkdir: No such file or directory
tar: ./usr/share/man: Cannot mkdir: No such file or directory
tar: ./usr/share/common-licenses: Cannot mkdir: No such file or directory
tar: ./usr/share/info: Cannot mkdir: No such file or directory
unknown base path for fd 4, path src
couldn't allocate absolute path for 'src'.
tar: ./usr/src: Cannot mkdir: Bad address
tar: Exiting with failure status due to previous errors
ERROR: Logfile of failure stored in: /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/s32g399ardb3-fsl-linux/base-files/3.0.14/temp/log.do_package.1528834
ERROR: Task (/home/abhi/fsl-auto-yocto-bsp/sources/poky/meta/recipes-core/base-files/base-files_3.0.14.bb:do_package) failed with exit code '1'
ERROR: wayland-protocols-1.33-r0 do_package: Error executing a python function in exec_func_python() autogenerated:
0001:
0003:
0360:}
*** 0363:
0366:}
0417: else:
0418: empty = b''
0420:
0423:
0424:
0523: raise
0529:
0530:
Exception: subprocess.CalledProcessError: Command 'tar --exclude=./sysroot-only -cf - -C /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/all-fsl-linux/wayland-protocols/1.33/image -p -S . | tar -xf - -C /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/all-fsl-linux/wayland-protocols/1.33/package' returned non-zero exit status 2.
Subprocess output:
tar: ./usr/share/wayland-protocols: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/cursor-shape: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/cursor-shape/cursor-shape-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/single-pixel-buffer: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/single-pixel-buffer/single-pixel-buffer-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-foreign-toplevel-list: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-foreign-toplevel-list/ext-foreign-toplevel-list-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/content-type: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/content-type/content-type-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/fractional-scale: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/fractional-scale/fractional-scale-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/xdg-activation: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/xdg-activation/xdg-activation-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/tearing-control: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/tearing-control/tearing-control-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-session-lock: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-session-lock/ext-session-lock-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-idle-notify: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-idle-notify/ext-idle-notify-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-transient-seat: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/ext-transient-seat/ext-transient-seat-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/security-context: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/security-context/security-context-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/drm-lease: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/drm-lease/drm-lease-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/staging/xwayland-shell: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/staging/xwayland-shell/xwayland-shell-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/linux-explicit-synchronization: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/linux-explicit-synchronization/linux-explicit-synchronization-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/keyboard-shortcuts-inhibit: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/keyboard-shortcuts-inhibit/keyboard-shortcuts-inhibit-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/input-method: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/input-method/input-method-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-shell: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-shell/xdg-shell-unstable-v6.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-shell/xdg-shell-unstable-v5.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/linux-dmabuf: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/linux-dmabuf/linux-dmabuf-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/fullscreen-shell: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/fullscreen-shell/fullscreen-shell-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/input-timestamps: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/input-timestamps/input-timestamps-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/relative-pointer: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/relative-pointer/relative-pointer-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/pointer-constraints: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/pointer-constraints/pointer-constraints-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-foreign: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-foreign/xdg-foreign-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-foreign/xdg-foreign-unstable-v2.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xwayland-keyboard-grab: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xwayland-keyboard-grab/xwayland-keyboard-grab-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-output: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-output/xdg-output-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/pointer-gestures: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/pointer-gestures/pointer-gestures-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/text-input: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/text-input/text-input-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/text-input/text-input-unstable-v3.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/primary-selection: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/primary-selection/primary-selection-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/idle-inhibit: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/idle-inhibit/idle-inhibit-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-decoration: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/xdg-decoration/xdg-decoration-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/tablet: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/tablet/tablet-unstable-v2.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/unstable/tablet/tablet-unstable-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/stable: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/stable/xdg-shell: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/stable/xdg-shell/xdg-shell.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/stable/linux-dmabuf: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/stable/linux-dmabuf/linux-dmabuf-v1.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/stable/presentation-time: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/stable/presentation-time/presentation-time.xml: Cannot open: No such file or directory
tar: ./usr/share/wayland-protocols/stable/viewporter: Cannot mkdir: No such file or directory
tar: ./usr/share/wayland-protocols/stable/viewporter/viewporter.xml: Cannot open: No such file or directory
tar: ./usr/share/pkgconfig: Cannot mkdir: No such file or directory
tar: ./usr/share/pkgconfig/wayland-protocols.pc: Cannot open: No such file or directory
ERROR: Logfile of failure stored in: /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/all-fsl-linux/wayland-protocols/1.33/temp/log.do_package.1532859
ERROR: Task (/home/abhi/fsl-auto-yocto-bsp/sources/poky/meta/recipes-graphics/wayland/wayland-protocols_1.33.bb:do_package) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1515 tasks of which 1237 didn't need to be rerun and 2 failed.
Summary: 2 tasks failed:
log: /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/s32g399ardb3-fsl-linux/base-files/3.0.14/temp/log.do_package.1528834
log: /home/abhi/fsl-auto-yocto-bsp/build_s32g399ardb3/tmp/work/all-fsl-linux/wayland-protocols/1.33/temp/log.do_package.1532859
Summary: There were 2 ERROR messages, returning a non-zero exit code.
Re: NXP S32g399ardb3 build issue
Hi,Abhiram_m_s
Thank you for contacting us.
Previous customers have encountered similar problems, please try to refer to the following link to solve this problem.
Compilation failure occurs with BSP46 paired with linux-libc-headers 6.6.
Joey
标记 (1)
无评分
版本历史
最后更新:
星期三
更新人:
