lx2080(yocto image and debug)i need information regarding how to configure lx2080a nxp image build using yocto and if we want use custom bord then how to make changes
Re: lx2080(yocto image and debug)Layerscape Yocto BSP v26.06:
The release includes both source code and prebuilt images as listed below:
Branch: walnascar-lsdk
- Linux BSP Supported boards, Features, Known Issues, please refer to Release Notes
- Layerscape Software Development Kit User Guide for Yocto: UG10374.pdf
Layerscape Linux SDK User Guide: UG10381.pdf
- Please modify RCW, u-boot, ATF and Linux dts for your custom board, and rebuild images.
Porting steps:
Modify rcw and rebuild rcw:
- $ bitbake rcw -c patch -f
- Go rcw source code folder build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/rcw/git/git/lx2160ardb_rev2/, please modify XGGFF_PP_HHHH_RR_19_5_2/rcw_2200_750_3200_19_5_2.rcw according to your custom board.
- $ bitbake rcw
Modify and rebuild u-boot:
- $ bitbake u-boot -c patch -f
- Please go to u-boot source code folder build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/*/git/, modify u-boot source code according to your custom board.
- $ bitbake u-boot
Modify and rebuild atf:
- $ bitbake qoriq-atf -c patch -f
- Please go to atf source code folder build_lx2160ardb-rev2/tmp/work/lx2160ardb_rev2-fsl-linux/qoriq-atf/*/git/, please modify atf source code according to your custom board.
Modify Linux dts file and rebuild Linux Kernel:
- $ bitbake virtual/kernel -c patch -f
- Please go to Linux Kernel folder build_lx2160ardb-rev2/tmp/work/ lx2160ardb_rev2-fsl-linux /linux-qoriq/*/git, please modify dts file arch/arm64/boot/dts/freescale/fsl-lx2160a-rdb.dts according to custom board.
Re: lx2080(yocto image and debug)for lx2080a yocto (linux 24.04)image building(rcw->tfa->uboot-linux path) and flashing image via sd card or emmc or norflash . code warrire tap jtag debugger can we use.
