2399253_en-US
2399253_en-US
2399253_en-US
MRF13750H Input Matching Design Simulation
Hello!
I am trying to simulate the input matching network of the MRF13750H-915MHz reference circuit board using Usimmics (I don't have ADS neither AWR)
I am using the same width and length traces as those in NXP datasheet, but the results do not correspond to 915MHz. Does anyone know what I am doing wrong?
Best,
Luis Villanueva
RFRe: MRF13750H Input Matching Design Simulation
Thank you for the information!
Hello Luis_V
Good day!
Unfortunately, I haven't used the simulator you're using, so I can't make a complete comparison, but from what I can see, I can tell you the following:
In ADS/AWR, the original layout includes:
  • tee discontinuities,
  • mitered bends,
  • open-end effects,
  • coupling effects.
Your schematic uses ideal MLIN sections connected directly.
Furthermore, I understand that the AWR simulation "takes into account" the parasitic effects that may be present in the package.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
No ratings
Version history
Last update:
a month ago
Updated by:
