2398632_en-US
2398632_en-US
2398632_en-US
FRDM-S32K344 manual error
There is a mistake on page 11 of FRDM-A-S32K344 development board manual (UM12406) . I'm posting this comment for the community and for anyone who runs into the same problem I did.
"Specifically, resistor R43 is populated by default to keep the FS26 in debug mode. To enable normal mode, R43 must be removed and R42 must be populated instead."
Should be:
"Specifically, resistor R43 is populated by default to keep the FS26 in debug mode. To enable normal mode, R43 must be removed. and R42 must be populated instead."
or:
"Specifically, resistor R43 is populated by default to keep the FS26 in debug mode. To enable normal mode, R43 must be removed. R42 must be populated to enter in OTP emulation mode."
Re: FRDM-S32K344 manual error
Thank you for the report!
When R43 is removed and R42 is populated, the voltage of FS26_VDEBUG will be within the VOTP (OTP emulation mode) range of the FS26 DataSheet. Therefore, I agree with your point of view, and I think the second statement is more comprehensive.
Let me contact the author to report this issue.
Robin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-28-2026 03:30 AM
更新者:
