2398416_en-US
2398416_en-US
2398416_en-US
Getting a Dev Board PCB imported to Altium
Our team is working with the S32K148-Q176 Evaluation Board RevB. We are designing a board to interface with the evaluation board and were trying to get a model of it to aid in that endeavor. The files are saved as a BRD when downloaded from your site. We use Altium here and so we cannot import that file. Would your engineering team be able to convert the .BRD to an ASCII .alg file, or another file format that altium can import?
Re: Getting a Dev Board PCB imported to Altium
Hi @rollypoli
Unfortunately, I do not have a way to convert the Allegro BRD database into Altium format.
For similar requests in the past, I have typically recommended using the free Cadence Allegro viewer. Cadence provides a free viewer that can open BRD files and allows you to inspect the PCB database directly.
Using the measurement and inspection tools available in the viewer, you should be able to accurately determine the placement and spacing of the connectors, mounting holes, and other mechanical features. This is usually sufficient to reproduce the board outline and connector locations on your own Altium design so that the new PCB remains mechanically compatible with the original board.
The free Cadence viewer can be downloaded from:
https://www.cadence.com/en_US/home/tools/pcb-design-and-analysis/allegro-downloads-start.html
While this is not as convenient as having a native Altium design file, it has worked well for customers who needed to reference an Allegro PCB layout and recreate the relevant mechanical dimensions in another CAD tool.
Lukas
Do you have the ability to convert it from a .brd to a .alg (ascII) allegro file?
I will look at the viewer
I'm sorry but I do not have such possibility.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-28-2026 02:35 AM
更新者:
