2398021_en-US
2398021_en-US
2398021_en-US
GUIGuider 1.10.1 to 2.0.0 migration
We have build our GUIGuider projects in version 1.10.1 and I am interested in migrating to the new 2.0.0 version to check out the new features. I found out the old GUIGuider project file could not be loaded in the new version, and I think it is because of the new JSON structure 2.0.0 projects use.
Is there an easy way to migrate the projects to the newer version of GUIGuider or do we have to manually convert it?
Re: GUIGuider 1.10.1 to 2.0.0 migration
Hi @MJHammers_ICP,
As you correctly mention, due to the redesigned architecture and new project structure of GUI Guider v2.0.0, this new version of GUI Guider is not fully backward compatible with GUI Guider v1.x.
The recommended path would be to recreate the project in GUI Guider v2.0 rather than attempting a file-level conversion. You can find the recommended migration workflow to help you with this task in the following link:
Tutorials — GUI Guider Documentation
BR,
Edwin.
タグ(1)
評価なし
バージョン履歴
最終更新日:
3 週間前
更新者:
