2396832_en-US
2396832_en-US
2396832_en-US
RF Power Amplifier Design - MRF13750H
Hello! I am designing an 805 MHz RF power amplifier using the MRF13750H, and my design is based on the 915 MHz reference circuit found in the datasheet. However, I only have access to Usimmics for simulating the matching networks; I do not have access to the software NXP uses to open their design files.
Therefore, to design the matching networks, I am requesting the complete schematic for the MRF13750H 915 MHz reference circuit from NXP, including the microstrip line dimensions, as this information is not provided in the datasheet. If possible, I would also like to request the large-signal model impedances at 805 MHz; otherwise, I will base my design on the values ​​provided for 915 MHz. The reference circuit at 915Mhz and the datasheet is attached below.
On the other hand, if anyone knows a different method for designing the matching networks at 805 MHz, I would appreciate the input.
タグ(1)
評価なし
バージョン履歴
最終更新日:
3 週間前
更新者:
