2396758_en-US
2396758_en-US
2396758_en-US
Segmentation fault when using ReadPipeUIntArray via Python
I am running into issues currently where I want to use a pipe to stream data packets (header+payload) from target to host.
When using ReadPipeUIntArray to read the binary data I am running into fmlite crashes frequently. I attached a python example and fmlite output as reference.
Thanks in advance
Re: Segmentation fault when using ReadPipeUIntArray via Python
Hi @tschue-nxt,
We are looking into this issue and will get back to you once we have an update.
Hi @tschue-nxt,
Could you check the attached fmlite binary and let us know if it works in your case.
Re: Segmentation fault when using ReadPipeUIntArray via PythonHi @iulian_stan,
looks good, working smoothly for quite some minutes now. Thanks for the fast fix!
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-22-2026 02:32 AM
更新者:
