2396702_en-US
2396702_en-US
2396702_en-US
How to let S32G3 LLCE CAN driver run in freertos
Hello everyone,
     I am working on S32G-VNP-RDB3 board and try to use LLCE CAN  in this module. I search the NXP website, but only find S32G2's porting method in S32DS3.4, and have no S32DS3.5 S32G3's porting method. My setup is S32DS3.5, RTD is 4.4.4. For EB Tresos Studio and LLCE,  which version should I use to let CAN2CAN code compile pass?Where can I find the porting method for S32G-VNP-RDB3(S32G399A)? The following is my S32DS.3.5's install details.
GoldVIPRe: How to let S32G3 LLCE CAN driver run in freertos
Hello, @Jimmybai
Thanks for your post.
Would you mind sharing your setup?
1. What is the LLCE version used in your test? which RTD version used?(since there is not RTD4.4.4)
2. So you want to implement a CAN2CAN application within FreeRTOS on RDB3?
Chenyin
Hi Chenyin,
        Actually, I don't know what your RTD version refer to, maybe you refer to LLCE RTD? I know little about how to setup LLCE environment. My setup is S32G399A bench, and S32G3 RTD is 4.0.0. Can you give me a recommended LLCE and RTD version for S32G399A setup and download position? Really, I need a LLCE setup guide for S32G3. Thanks.
Hello, @Jimmybai
Thanks for your reply.
If there are not dedicated version dependencies, I suggest firstly following the AN13423 to learn the basic usage for using CAN2CAN on S32G platforms
Chenyin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-23-2026 03:27 AM
更新者:
