2396184_en-US
2396184_en-US
2396184_en-US
i.MX8MP_EVK: YOCTO Compilation Error do_package() (Issue: tar & *at())
These are my yocto build parameters:
  • Release: imx-linux-walnascar
  • BSP Version: imx-6.12.49-2.2.0
  • MACHINE: imx8mpevk
  • DISTRO: fsl-imx-xwayland
I have been using this build environment successfully for the past couple of months. However, I suddenly started encountering the attached error.
To troubleshoot, I completely cleaned the build environment, reinitialized the repository (repo init), synced everything again, and performed a fresh build. Unfortunately, I am still facing the same issue.
Please find the attached log file for your reference. I would appreciate your help in identifying the root cause and suggesting a solution.
i.MX 8M | i.MX 8M Mini | i.MX 8M NanoRe: i.MX8MP_EVK: YOCTO Compilation Error do_package() (Issue: tar & *at())bitbake imx-image-coreRe: i.MX8MP_EVK: YOCTO Compilation Error do_package() (Issue: tar & *at())
What "bitbake command" are you using?
I will do verification.
Thank you for your response.
I verified my build environment, and it already matches the configuration you recommended.
Host OS:
  • Ubuntu 22.04.5 LTS (Jammy)
GNU tar version:
  • GNU tar 1.34
    $ cat /etc/os-release
    PRETTY_NAME="Ubuntu 22.04.5 LTS"
    $ tar --version
    tar (GNU tar) 1.34
However, I still encounter the same failure
Please check the tar version, if the host is Ubuntu 24.04 and tar is 1.35
Build inside a container or VM with:
Ubuntu 22.04 LTS
GNU tar 1.34
Please find file below,
Here i am pasting the some lines of error
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are ['/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.44.bb:do_populate_sysroot', '/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/gcc/gcc-cross_14.3.bb:do_populate_sysroot', '/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.68.bb:do_populate_sysroot', '/home/vvdn/LWT_Build/sources/poky/meta/recipes-kernel/kern-tools/kern-tools-native_git.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-core/coreutils/coreutils_9.6.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/bison/bison_3.8.2.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/dwarfsrcfiles/dwarfsrcfiles.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/flex/flex_2.6.4.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-devtools/rpm/rpm_4.20.0.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-extended/bc/bc_1.08.1.bb:do_populate_sysroot', 'virtual:native:/home/vvdn/LWT_Build/sources/poky/meta/recipes-kernel/kmod/kmod_34.1.bb:do_populate_sysroot']
NOTE: Installed into sysroot: []
NOTE: Skipping as already exists in sysroot: ['gettext-minimal-native', 'binutils-cross-aarch64', 'cmake-native', 'gcc-cross-aarch64', 'libtool-native', 'm4-native', 'quilt-native', 'texinfo-dummy-native', 'kern-tools-native', 'linux-libc-headers', 'file-native', 'openssl-native', 'coreutils-native', 'expat-native', 'ncurses-native', 'readline-native', 'util-linux-libuuid-native', 'zlib-native', 'bison-native', 'dwarfsrcfiles-native', 'elfutils-native', 'flex-native', 'git-native', 'gnu-config-native', 'json-c-native', 'libedit-native', 'lua-native', 'make-native', 'patch-native', 'perl-native', 'pkgconfig-native', 'pseudo-native', 'python3-native', 'rpm-native', 'bc-native', 'bzip2-native', 'libarchive-native', 'libidn2-native', 'lzlib-native', 'xz-native', 'zstd-native', 'kmod-native', 'acl-native', 'attr-native', 'curl-native', 'gdbm-native', 'gmp-native', 'gnutls-native', 'libtasn1-native', 'libcap-native', 'libffi-native', 'libgcrypt-native', 'libgpg-error-native', 'libmicrohttpd-native', 'libmpc-native', 'libunistring-native', 'mpfr-native', 'nettle-native', 'p11-kit-native', 'popt-native', 'sqlite3-native']
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing python function sstate_task_prefunc
DEBUG: Python function sstate_task_prefunc finished
DEBUG: Executing python function do_package
DEBUG: Executing python function package_setup_pkgv
DEBUG: Python function package_setup_pkgv finished
DEBUG: Executing python function package_convert_pr_autoinc
DEBUG: Python function package_convert_pr_autoinc finished
DEBUG: Executing python function package_prepare_pkgdata
NOTE: Installed into pkgdata-sysroot: []
DEBUG: Python function package_prepare_pkgdata finished
DEBUG: Executing python function perform_packagecopy
ERROR: Error executing a python function in exec_func_python() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_func_python() autogenerated', lineno: 2, function:
0001:
*** 0002:perform_packagecopy(d)
0003:
File: '/home/vvdn/LWT_Build/sources/poky/meta/classes-global/package.bbclass', lineno: 363, function: perform_packagecopy
0359: rpath_replace (dvar, d)
0360:}
0361:perform_packagecopy[cleandirs] = "${PKGD}"
0362:perform_packagecopy[dirs] = "${PKGD}"
*** 0363:
0364:python populate_packages () {
0365: oe.package.populate_packages(d)
0366:}
0367:populate_packages[dirs] = "${D}"
File: '/usr/lib/python3.10/subprocess.py', lineno: 421, function: check_output
0417: else:
0418: empty = b''
0419: kwargs['input'] = empty
0420:
*** 0421: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
0422: **kwargs).stdout
0423:
0424:
0425:class CompletedProcess(object):
File: '/usr/lib/python3.10/subprocess.py', lineno: 526, function: run
0522: # We don't call process.wait() as .__exit__ does that for us.
0523: raise
0524: retcode = process.poll()
0525: if check and retcode:
*** 0526: raise CalledProcessError(retcode, process.args,
0527: output=stdout, stderr=stderr)
0528: return CompletedProcess(process.args, retcode, stdout, stderr)
0529:
0530:
Exception: subprocess.CalledProcessError: Command 'tar --exclude=./sysroot-only -cf - -C /home/vvdn/LWT_Build/build/tmp/work/imx8mpevk-poky-linux/linux-imx/6.12.34+git/image -p -S . | tar -xf - -C /home/vvdn/LWT_Build/build/tmp/work/imx8mpevk-poky-linux/linux-imx/6.12.34+git/package' returned non-zero exit status 2.
Subprocess output:
got *at() syscall for unknown directory, fd 4
unknown base path for fd 4, path lib
couldn't allocate absolute path for 'lib'.
tar: ./usr/lib: Cannot mkdir: Bad address
tar: ./usr/lib/modules: Cannot mkdir: No such file or directory
It seems that I don't have the permission to download the attachment.
Would you please resend it again?
Hi @yipingwang
Awaiting for your prompt support in further debugging.
On your ubuntu PC, use the command "sudo apt install tar=1.34+dfsg-1build3"
@Sanjiv_MnsDid this resolve the issue ?
Hi @abannish
Please try below commands this works for me...
Thanks! That solved the issue also in my side! FYI, everything worked perfectly until some autoupdate from the Ubuntu service...
No ratings
Version history
Last update:
3 weeks ago
Updated by:
