2395476_en-US
2395476_en-US
2395476_en-US
Online Provisioning
I have successfully completed the online Provisioning on my board , now what I have to do is I have extract the cert or key or possible read the blob which is created  after the edge2lock provisioning so is it possible to do that ?
Using Frdm i.mx93
Re: Online Provisioning
You may use pkcs11-tool for this, please have a look to the documentation here:
https://github.com/nxp-imx/imx-smw/blob/release/version_5.x/Documentations/user_guide/pkcs11/pkcs11_...
Also, I would suggest to have a look to the SMW user manual:
https://github.com/nxp-imx/imx-smw/blob/release/version_5.x/Documentations/user_manual/SMW_UserManua...
Best regards/Saludos,
Aldo.
Re: Online ProvisioningHi Aldo,
Thank you for your reply.
I have already tried using pkcs11-tool with the SMW PKCS#11 provider after successful online provisioning on the FRDM i.MX93, but I cannot see or read the provisioned certificate or key.
Could you please clarify:
Are the provisioned certificate and private key expected to be accessible through the PKCS#11 interface?
If not, are they stored securely in ELE and intended to be used only through PSA Crypto/SMW APIs without being exported?
My goal is to use the provisioned credentials for mutual TLS.
Thank you.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-21-2026 02:34 AM
更新者:
