2395230_en-US
2395230_en-US
2395230_en-US
EB tresos error "Failed to verify license" and "The signature of file is invalid"
I use EB tresos to config S32K344 base RTD version SW32K3_S32M27x_RTD_R21-11_4.0.0_P19SW32K3_S32M27x_RTD_R21-11_4.0.0_P19.
But when generate, EB report error like below, about "Failed to verify license" and "The signature of file is invalid":
I didn't modify the RTD files, so what might be the reason, how to solve that?
Re: EB tresos error "Failed to verify license" and "The signature of file is invalid&
Please make sure that you didn't modify any file in the package, otherwise the modification will lead to license violation. You can also try to uninstall and install again. Also, make sure that you  are using EB Tresos Studio 29.0.0.
S32K3 Standard Software -> Automotive SW - S32K3/S32M27x - Real-Time Drivers for Cortex-M -> S32K3_S32M27x Real-Time Drivers ASR R21-11 Version 4.0.0 P19
S32K3 Standard Software -> Automotive SW - EB tresos Studio / AUTOSAR Configuration Tool -> EB tresos Studio 29.0.0
I haven't encountered any problems importing Hse_Ip_AesEncAsyncIrq_S32K344 and Wdg_Example_S32K344.
Please check if the file SW32K3_S32M27x_RTD_R21-11_4.0.0_P19.link exists in the links folder under your EBTresos installation path. I have previously encountered cases where the presence of multiple versions of S32K3 RTD .link files in the links folder of certain EBTresos versions could cause errors.
Robin
No ratings
Version history
Last update:
‎07-16-2026 02:27 AM
Updated by:
