When using GUIGuider-2.0.0 on Windows 11 to generate C code, the folders under the "generated" folder are all empty, even though the logs show successful generation. This happens on the same computer as GUI-Guider-1.10.1-GA, which generates the code perfectly. I've tried various methods, including disabling antivirus software and running it as administrator, but the problem persists. Has anyone encountered the same issue? I would appreciate any help.
I reinstalled the system but it still didn't work; GUI Guider 1.10 works fine. I added a button to a blank project.
Hello @IFYINT ,
Sorry to keep you waiting. Could you please share the project where the problem occurred? We'll try to reproduce it.
Celeste
I tried it on my Windows 11 PC, but I couldn't reproduce your problem:
Would it be convenient for you to try a different computer?
It works on a different computer and can generate files normally, but it's not working on this computer. It worked fine on version 1.10 before.
I tried again, but I still couldn't reproduce your situation. Could you check your project path? Did you generate a "generated" folder? If not, could you create it manually and then regenerate the code?
We still suggest you export the project and send it to us for review.
