2394721_en-US
2394721_en-US
2394721_en-US
FlexCAN(S32K348) bit timing calculation for TJA1445
I downloaded the attachment from the MPC5xxx/S32Kxx/LPCxxxx: CAN / CAN FD bit timing calculation knowledge base document to configure my settings.
However, I cannot find the option for the TJA1445 transceiver in the calculator, so I am unable to proceed with the configuration for my S32K348 board.
Could you please advise if there is an updated version of the calculator that includes the TJA1445 transceiver? If not, which alternative transceiver from the existing dropdown list would be the most compatible or closest option to select instead?
Thank you in advance for your help!
Re: FlexCAN(S32K348) bit timing calculation for TJA1445
Hi @Penta7,
By selecting Transceiver, propagation delay parameter is also loaded, but can be simply overwritten by user value. You can refer to TJA1445's datasheet and overwrite propTXRX to 220 ns:
Julián
Do you try FlexGUI for TJA14XX Family? Not sure it has timing setting information for your request
Current version is NXP_TJA14XX_GUI_1.1.0 and can be downloaded from NXP official website
No ratings
Version history
Last update:
‎07-15-2026 03:28 AM
Updated by:
